A Case Of Momentum Conservation
The discussion centers on the conservation of momentum when a ball collides elastically with a fixed inclined plane. It addresses the confusion surrounding the concept of "common normal" and how gravitational forces affect momentum conservation. The key point is that while the Earth is part of the system, its massive size means its velocity change is negligible, allowing for momentum conservation in the system of the ball and the inclined plane. The conversation emphasizes that momentum is conserved in all directions, but only the component along the normal changes due to the forces involved. Understanding these principles clarifies the momentum conservation process in this scenario.
D_DaYwAlKeR
My question is...
when a ball falls vertically on an inclined plane with a velocity [v][/0] and let it collide elastically with the incline plane...let the angle of inclination be 'β' ...
Now, here we conserve the momentum of the ball in the direction of commomn normal of the two objects...
So we write an equation
initial momentum of the ball (along common normal) = final momentum of the ball (along common normal)...
Assuming that the inclined plane is fixed...
THE REAL QUESTION (CONFUSION)..
i think that the net force on the system (ball + plane) is acting along the common normal ..as gravitational force is acting ..so how are we conserving the momentum along common normal and even along the line tangent to the inclined plane...
Even along that line Gravity is acting...
Sorry for the length of the question...I was too descriptive..:D..
Sorry, I'm a little confused by your use of the term "common normal" in this problem. I have never really heard that term.
Momentum is conserved. Momentum is a vector quantity, so the direction of momentum after must also equal the direction of momentum before, not just the magnitude.
To properly conserve momentum as a vector quantity in this problem, we must realize that the ball imparts a change in momentum in the Earth. Let's consider the Earth at rest in some frame, with the slope firmly attached to it, the ball drops onto the slope and bounces away at a different direction. The momentum of the ball, therefore, has changed. That change in momentum is balanced out by the fact that this change in momentum imparts a change in momentum of the entire Earth. In our previously established reference frame, the Earth is now moving--very slowly, but moving--so the slope is "fixed" only in the sense that its velocity of the Earth is always approximately zero, but p = mv, and the Earth has a lot of mass.
Not sure if that answers your question...it was a little tough for me to understand.
Thnx...@Soothsayer...
I got it now...Since, Earth has very large mass as compared to the ball...its vel. is negligible...and that's why when we give the velocity back to the ball...
So whenever we conserve momentum along y direction ...it is understood that (objects + earth) has been taken as a system...Am i correct here?...
By saying common normal ..i meant that impulse imparted by the ball to the (incline + earth) and by (incline + earth) to the ball is along common normal...
Yes. Earth ends up being part of your system if you want to consider momentum conservation, but it's mass might as well be infinite compared to everything else, so it can absorb any amount of momentum without changing velocity measurably.
By the way, momentum conserved in every direction. But yes, since force is applied along normal, only component along that normal changes.
Right, force is essentially defined as being the change in momentum with respect to time. Forces also come in equal and opposite pairs, so the force the slope imparts on the ball, the ball also imparts on the slope.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
