Does the Finite Propagation Speed of Electrostatic Forces Impact Energy in a Closed System?
  • Thread starter Thread starter Smacal1072
    Charge Moon
The discussion centers on the finite propagation speed of electrostatic forces and its implications for energy in a closed system. A scenario is presented involving two positive charges, one on the moon and one on Earth, where their interaction is delayed due to the time it takes for electromagnetic fields to propagate. The key question raised is whether the energy required to bring the charges closer together is less than the energy released when they are separated, given the finite speed of the electric field. It is suggested that accelerating the charges emits electromagnetic radiation, potentially affecting the energy dynamics when both charges are moved simultaneously. The conversation highlights the complexities of energy transfer in systems governed by relativistic effects and electromagnetic radiation.
Smacal1072
Hi All,
Again, thanks to all the Physics Forums gurus.
I posted a question about a year ago concerning the finite propagation speed of information and electrostatic forces between charges, which seemed confusing. I still was hoping to resolve it, so I simplified it a bit :).
Imagine a positive charge on the moon, and an identical positive charge on earth. They faintly repel one another. Also imagine that we have a closed system (maybe a giant Dyson sphere around the system :D), so that all possible radiation from our experiment is accounted for.
Since light takes about a second to travel between the Earth and the moon, changing the location of the charge on the Earth affects the charge on the moon via it's E field a second later, and vice-versa.
Suppose you move the charges slightly closer toward each other, simultaneously, and bring them to rest, in under a second. Because the E field takes a second to propagate, each charge sees that it's partner has not moved during this transition.
Then, suppose you repeat this action to bring the charges back to their initial position. Again, each charge experiences that it's partner has not moved during this transition.
My question is: At first glance, the energy required to push the charges together is less that what is released when they are pushed apart. This is due to the finite speed of propagation of the E field. What is the missing fact to explain this? (Note in my previous post, I did apply the Liénard–Wiechert potential to obtain the relativistic field and force on each charge, but still came up short.)
Thanks
I did not calculate it, just a guess: you accelerate charges, this will emit electromagnetic radiation. And if you do this both on moon and Earth at the same time, you might see less radiation than you get by moving them one by one.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
