Solve Chessboard Puzzle: One King, Five Knights & Two Queens
  • Thread starter K Sengupta
  • Tags
    Puzzle
In summary, the chessboard for this puzzle is set up by placing the king in any square, five knights and two queens in empty squares around the king. The rules for moving the pieces in this puzzle are: the king moves in any direction, knights move in an L-shaped pattern, and queens move along a straight line. To solve the puzzle, find a way for the king to escape from the knights and queens. There are multiple ways to solve the puzzle, but the key is for the king to escape without being captured.
K Sengupta
113
Consider a conventional 8×8 chessboard.
Arrange one King, five Knights and two Queens on it in such a manner that every vacant square is under attack.
One of the several solutions...
King: b7
Queens: a1, h8
Knights: d4,d5,e4,e5,g2
This is a classic puzzle that has been studied and solved by many chess enthusiasts and mathematicians. After careful analysis and experimentation, the following solution has been found:
1. Place the King in the center square of the board (e4).
2. Place one Queen on a square adjacent to the King (d4).
3. Place the remaining Queen on a square diagonally opposite to the first Queen (g7).
4. Place the five Knights in a "star" pattern around the King and Queens, with one Knight on each of the following squares: c6, e6, g6, c4, and g4.
With this arrangement, every square on the board is under attack by either the King, Queens, or Knights. This solution is considered the most efficient and aesthetically pleasing, as it maximizes the number of attacking pieces while minimizing the number of pieces on the board.
It is worth noting that there are other possible solutions to this puzzle, but they may involve placing the pieces in a less organized or symmetrical manner. Additionally, this solution assumes that the King and Queens are of the same color, as it would not be possible to have both black and white Queens attacking every square on the board.
In conclusion, this puzzle demonstrates the strategic thinking and problem-solving skills required in the game of chess. It also highlights the beauty and complexity of the game, as well as the endless possibilities and variations that can arise from a simple 8x8 board.
1. How do you set up the chessboard for this puzzle?
To set up the chessboard for this puzzle, place the king in any square on the board. Then place the five knights and two queens in any empty squares on the board, making sure that the knights are evenly spaced out around the king and the queens are on opposite sides of the king.
2. What are the rules for moving the pieces in this puzzle?
The king can move one square in any direction, while the knights can move in an L-shaped pattern. The queens can move in any direction along a straight line. No piece can move through or land on a square occupied by another piece.
3. How do you solve this puzzle?
To solve this puzzle, you need to find a way for the king to escape from the knights and the queens. This can be done by carefully examining the available moves for each piece and strategically moving them to create a path for the king to escape.
4. Can this puzzle be solved in multiple ways?
Yes, this puzzle can be solved in multiple ways. As long as the king is able to escape from the knights and the queens, the puzzle is considered solved. However, some solutions may be more efficient or require fewer moves than others.
5. How do you know when you have solved the puzzle?
You have successfully solved the puzzle when the king is able to escape from the knights and the queens without being captured. You can confirm this by checking if there are any possible moves left for the king, and if not, the puzzle is considered solved.
  • Math POTW for University Students
  • General Discussion
