I What is the Function for the Value of a Convergent Series Sum?
The discussion centers on the convergence of the series sum ##\sum_n \frac{1}{n^c}##, which converges for values of ##c > 1##. It highlights that while some values of this sum have known analytic expressions, specifically through the Riemann zeta function, a closed expression for ##\sum_{n=1}^\infty \frac{1}{n^3}## remains unknown and is referred to as Apéry's constant. The Riemann zeta function serves as a key tool for understanding these sums for ##c > 1##. Overall, the topic emphasizes the complexity of finding explicit values for certain convergent series. The discussion concludes with the acknowledgment of the zeta function's role in this context.
mathman
Homework Helper
TL;DR Summary
sum ##\frac{1}{n^c}## where ##c\gt 1##
##\sum_n \frac{1}{n^c}## converges for ##c\gt 1##. Is there an expression for the value of the sum as a function of ##c##?
Mathematics news on Phys.org
No, there is not. A closed expression for ##\sum_{n=1}^\infty \frac{1}{n^3}## is not known. This is Apéry's constant. See https://en.wikipedia.org/wiki/Apéry's_constant for more information.
mfb said:
For some values there are analytic expressions. It's the Riemann zeta function.
I should have known! It is the zeta function for all ##c\gt 1##.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
