A learn's puzzle on transformation equation
atreess
Hi, I'm a new learner of CM and I was stuck at the very beginning. TT
The transformation equation is ri=ri(q1,q2,...,qn,t)
I wonder why t should be in the bracket.
Aren't r determined by these independent coordinates? Isn't t already contained in them?
Certainly the [itex]q_{i}[/itex] can have some time-dependence, and that gives [itex]r_{i}[/itex] implicit time-dependence. But, you can also choose to define some new coordinates [itex]r_{i}[/itex] with explicit dependence on time.
For example, consider a particle in 1-D motion described by [itex]x(t)=v_0t[/itex]. There is no reason you can't define a new variable [itex]q(x,t)=3x+a_0 t^2[/itex], if you have some use for that transformation.
Thanks very much for your reply!
But how about the degrees of freedom? A system with n degrees of freedom just needs n independent coordinates. If adding t, there must be one coordinate(q1, q2,..., or t) which is dependent. :confused:
I guess that t represents the change of the constraint with time. Is it right?
