B A Magnetic Misconception on Divergence 0/Closed Field Lines?
The discussion centers on whether closed magnetic field lines imply that magnetic forces do no net work, questioning the misconception surrounding this concept. It draws a parallel to electric fields, noting that closed field lines between opposite electric charges do not prevent work from being done on those charges. The conversation highlights that while magnetic forces may not do work on charges in a closed loop, electric fields can still perform work despite having closed lines, as seen in the case of an electric dipole. The key takeaway is that the presence of closed field lines does not inherently mean that no work can be done by the associated forces. Understanding the distinction between magnetic and electric fields is crucial in this context.
walkeraj
Question: Can we ultimately atttribute no work or net zero work done by a magnetic force to the closed magnetic field lines that results in Divergence zero of a magnetic field? That is, is it a misconception to say that closed magnetic field lines imply magnetic force will always result in no net work?
(I meant misconception on my part not theory.)
Edit: Why misconception? Now switch to electric field. The field lines between two opposite electric test charges are also closed and resemble that of a bar magnet, though electric in nature. Does it hold? Is it enough to say that since the field lines are closed between the two test charges that no net work can ever be done?
Work done by a magnetic force on what ? Electric charge ?
Electric charge is all I can see (thinking back to Griffith's book).
Consider the electric field of an idealized electric dipole. It has only closed field lines, but it can do work on a charge.
Likes Vanadium 50
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
