A momentum question following collision
In a scenario where two identical motorcycles collide with a stationary object, the question arises about which ejected rider will travel further if one rider is lighter. The discussion highlights that momentum conservation and kinetic energy play crucial roles, but the outcome depends on various factors, including the height of the load and forces acting on the riders post-collision. It is noted that in the absence of friction and air resistance, gravity is the only force influencing the distance traveled after ejection. The complexity of the problem is emphasized, as the initial conditions and energy transfer mechanisms need careful consideration to determine the final distances. Ultimately, the discussion concludes that the setup of the problem significantly affects the interpretation and results.
camcrash11
I think this is a basic question, at least I would hope so.
If two identical motorcycles are going at the same speed but one has a lighter individual. If each individually collides with a stationary object and the driver is ejected. Who will go further and why?
Not enough information. There are too many variables.
How are you thinking about this - show us your best reasoning(?) In what context does the question arise?
I'll simplify the situation ... you have two identical carts traveling at the same speed.
They each have a loose load, and are stopped suddenly in the same way ... so they come to rest in the same very short time. Then, neglecting friction and air resistance, the determining factor for which load travels the furthest before hitting the ground is the height of the load above the ground. ie. all other things equal, both loads travel the same distance before hitting the ground.
This is not a conservation of momentum problem - this is 1st law stuff.
But look at how carefully I had to set up the problem.
Thanks for the reply Simon!
My initial thought was that the momentum before collision will be (mass person + mass motorcycle) x velocity. Since the motorcycle comes to a stop, the momentum after collision will be equal to the momentum before collision but just the mass of the person x new velocity. The lighter the person the greater the velocity.
Then I came back and said that doesn't wound right. If the person on the motorcycle has a certain velocity and the motorcycle is stopped, they will continue moving forward at the same velocity. In this case they would initially move forward at the same velocity but since KE = mv^2. The heavier person should have greater kinetic energy and go further.
I am sure somewhere my logic is not right but for some reason I cannot see it.
The total momentum is conserved - but the motorcycle's momentum is transferred to whatever mechanism caused it to stop.
In your example, that is some sort of barrier.
Include the barrier in the conservation of momentum calculation and you will see all the laws get obeyed.
The initial kinetic energy does not, by itself, determine how far someone goes. You need to know what forces are on the object: ie. what are the mechanisms for energy transfer?
In the absence of air resistance and friction, the only force on the object is gravity. This is a ballistics problem until impact. If you are thinking that the object then slides along the ground, then you have to add friction to the mix (or sliding does not slow the object down). Friction, in the usual model, is proportional to mass - all else remaining equal, the bigger person has more mass.
Again: setting up the problem more carefully...
Object mass m initially has speed u horizontally, falls distance h to the ground, then slides distance d along the ground and comes to rest.
Assuming h is low enough that air resistance can be neglected ...
We just want to know whether a heavier object goes further overall, so we only need d as a function of m.
So all the initial kinetic energy goes to work against friction.
Taking the coefficient of kinetic friction to be ##\mu## - write the equation relating initial kinetic energy to the work against friction moving a distance d ... then solve for d in terms of m. What do you see?
It seems to me that if the driver is ejected cleanly, then effectively he/she is not involved in any collision. He/she simply becomes a projectile.
Likes sophiecentaur and Simon Bridge
That is one interpretation of the setup ... unfortunately, the initial problem statement was not so precise.
See posts #2 and #4.
