A Nonlinear Second Order Differential Equation Problem
6 replies · 3K views
overmage
A Nonlinear Second Order Differential Equation Problem: very frustrating please help!
Hello, I am a first year engineering undergraduate student, and this is my question.
A dust particle of negligible mass starts to fall, t=0, under the influence of gravitational force through mist of saturated water vapor. The vapor condenses onto the dust particle at a constant rate of [tex]\lambda[/tex] kilogram per meter of traveled distance. The dust particle thereby develops into a rain droplet with increasing mass.
a) Calculate the acceleration of the droplet as a function of its velocity and covered distance.
b) Determine the equation of motion of the droplet by integrating the expression of the acceleration, neglecting friction, collisions, etc.
I have already solved a). The equation (which I am told is correct) is:
[tex]\frac{dv}{dt} + \frac{v^{2}}{x} =[/tex] g
where g is the gravitational field strength.
I was given the 'hint' of substituting [tex]f(x) = At^{n}[/tex] to solve this equation for the position x, and determine A and n.
I have no idea how to determine A and n, frankly. In fact, I have never done Second Order ODEs before, let alone nonlinear Second Order ODEs. (Before you ask why I would be set a question on Second Order ODEs not having done it before - my professor - let's just say I've had better elementary schools teachers.)
I arrive at this equation:
(2n[tex]^{2}-n)At^{n-2} =[/tex] g
What do I do from here now? Four hours of rearranging to no avail.
P.S. After sleuthing around, I discovered that the usual method for solving such equations is to substitute it to a first order one. This doesn't look like it...
Hi Overmage,
Your equation
[tex] \frac{dv}{dt} + \frac{v^{2}}{x} = g[/tex]
is correct, it was a good job to derive it!
Now it is a first order differential equation (contains first derivative only), but non-linear. Luckily, it does not contain the time itself. There is a trick for such equations, often applied in Mechanics: We will use x as independent variable instead of t.
[tex] \frac{dv}{dt} =\frac{dv}{dx}\frac{dx}{dt}=v\frac{dv}{dx}[/tex]
Substituting for dv/dt, your equation becomes:
[tex] \frac{dv}{dx}v+\frac{v^{2}}{x} = g[/tex]
Now the second trick comes:
[tex] \frac{dv}{dx}v=0.5\frac{d(v^2)}{dx}[/tex]
and we choose v^2 as dependent variable, say y=v^2.
Now we arrived at a totally different-looking equation:
[tex] 0.5 \frac{dy}{dx}+\frac{y}{x} = g[/tex]
This is a linear equation! You can solve it by assuming y in a product form: y=F*G.
Have you learned that method from Maths? If you do not know it yet, I'll explain.
Anyway: the solution will be:
[tex] v^2=\frac{2gx}{3}[/tex]
from where you get the acceleration, and it will be a surprise!
ehild
No, I'm not familiar with that. =( could you give me a general idea of how that works out?
You have a differential equation of form
a(x)y'+b(x)y=c(x) (the prime means differentiation), with initial condition y=0 at x=0, the prime means differentiation.
Assume Y=F(X)G(x).
a(x)(F'G+FG')+b(x)FG =c(x). *
You have the freedom to choose G so that
a(x)FG' + b(x) FG =0
Divide the eq. by F.
a(x)G'+b(X)G=0.
You can solve this equation by separating the variables.
[tex]\int{\frac{dG}{G}}=\int{\frac{-b(x)}{a(x)}dx}[/tex]
Replace back G(x) into eq. *.
a(x)F'G(x) = c(x)
[tex]F(x)=\int{\frac{c(x)}{a(x)G(x)}}+const[/tex]
y=F(x)G(x).
Your equation is :
0.5 y' +y/x =g ---> y'+2y/x=2g
a=1, b=2/x, c=g
[tex]\int{\frac{dG}{G}}=-\int{\frac{2}{x}dx} \rightarrow G(x)=x^{-2}[/tex]
[tex]F'G(x)=c(x)\rightarrow F'=2gx^2 \rightarrow<br /> <br /> F(x)=\frac{2gx^3}{3}+C[/tex]
[tex]y(x)= F(x)G(x)=\frac{2gx}{3}+\frac{C}{x^2}[/tex]
C=0 according to the initial condition.
[tex]y(x)=\frac{2gx}{3}[/tex]
ehild
Hey,
Thanks a lot for the help! I really appreciate it. However, can i clarify just one last thing:
a=1, b=2/x, c=g
shouldn't c be = 2g?
Thanks for the help you've given! Wow, this problem is kinda hard. Think you've pretty much covered it all though.
overmage said:
Hey,
Yes, of course... :)
ehild
