A pole, 2 lightyears in length - conceptual question
A pole in zero gravity, two light years long, does not move instantly at the other end when pushed due to the limitations imposed by the speed of light. The movement of one atom in the pole takes time to transmit force to another atom, which is governed by the speed of sound in the material, not light speed. Even in a hypothetical perfectly rigid pole, the transmission of force cannot exceed the speed of light. The discussion also touches on the relationship between elasticity, density, and the speed of sound in materials, indicating that changes in composition can affect force transmission speed. Ultimately, the time it takes for the far end of the pole to move will be significant, potentially taking hundreds of thousands of years depending on the material.
vorcil
A pole in zero gravity, two light years in length
you push it 1m,
does it move instantly at the other end?
its in my physics textbook but dosen't give an explanation as to why it dosen't move?
i know nothing can move faster the speed of light
you push it 1m,
No, it does not move instantly at the other end. Your final answer is the explanation; nothing moves faster than the speed of light. The "pole" is mostly empty space; a collection of atoms held together by electromagnetic forces. It takes time for movement of one atom to result in a force at another.
my reasoning for nothing going faster than the speed of light...
gamma(from special relativity) = 1/(squareroot ( 1-(v^2/c^2)))
if v > c, 1-X which would give a negative number
the negative number becomes a complex number upon square rooting it
and it's not really reasonable to have a complex number
is that why nothing can go faster than the speed of light?
This "gamma" is used to calculate accelerations and times, we can't have them being imaginary >.<
As an object approaches the speed of light, it requires an infinite force to accelerate it any further, so it's impossible to go faster than that.
Even if v=c, the denominator becomes 0 which isn't allowed either.
However, I wouldn't word it exactly in this way. I mean, the equation was "created" (for lack of a better word) to describe the effects of special relativity.
Sure, you could argue that the mathematics of this equation has been supported by experimental evidence, but the equation itself was derived with the intentions of relativity in mind.
I guess what I'm saying is that for e.g. it's not fair to say it's a square because its area is described as s2 where s is a side length. The square came first, not the equation. It can be used as evidence to support it though.
can you link me to some math of this? i looked around wikipedia but couldn't find anything, ended up reading about schrodingers cat lol
Back to your original question:
you push it 1m,
The speed of light has nothing to do with the 'speed' of the force transmission through the pole (other than that the speed of light would be the absolute maximum limiting speed). The 'speed' of the force through the pole is more or less the speed of sound through that medium (material) , for reasons noted in sylas' earlier post. If the pole was made of steel, I expect it would take over 100,000 years for the movement to occur at the other end (relatively speaking :wink:).
This is irrelevant, and misses the point of Special Relativity. Special Relativity makes no claim whatsoever about the existence of such objects (i.e. atoms, and rods composed of atoms), and furthermore applies regardless of the composition of the rod. That is, while Special Relativity originated from electromagnetism, it is not limited thereto.
Suppose a perfectly uniform and continuous "mathematical rod" of length 2-lyrs. This is a continuum (wave) mechanics problem that applies to any hypothetical material. Special Relativity restricts the equations of motion (i.e. the wave equation). Then you must describe the "push" on one end in a covariant way (i.e. promote spatial vectors to Lorentz vectors). Assuming a longitudinal "push", you can do this in a single spatial dimension, so that you can draw a 2-D spacetime diagram of this process. From this, you can put a lower limit on the time delay between the "push" and the resulting motion at the other end.
That was easily the most ridiculous explanation for the mechanics involved I've ever seen. Sorry, but mathematically-correct or not, that post is virtually meaningless and lacking in any sort of educational value for the OP. Posts #2 and #8 had it.
I'll defer to #8 as my favourite, for a simple explanation at an appropriate level.
Agreed. However, I wanted to acknowledge your contribution, as well.
ok they're both unrelated. But if we were wanting to make the transmission speed of the force through this pole move faster, what could we change? e.g. Composition of the pole; amount of force applied;??
Change the composition, specifically, the property sometimes called stiffness which is quantified by Young's modulus.
negitron said:
the property sometimes called stiffness.
and what would be the limit of the transmission speed if this stiffness were increased indefinitely? (Nearing perfect rigidity)
Presumably c, although this is wandering well outside of my expertise. And I suspect the molar mass of the material in question puts a smaller upper bound on it.
Since the molecules of the material make contact with each other at the speed of sound when the force is applied, and since the speed of sound in a solid medium is roughly equal to the sq rt of E/p, where E is the elasticity modulus of the material through which the force is transmitted, and p is its density, then the speed of sound, and the speed of the molecular collisions, would be fastest when E is maximized and p is minimized. E and p are properties of the material. Steel has a high elasticity modulus (doesn't deform very easily), so even though it is rather dense,the speed of sound thru steel is quite high. Aluminum is 1/3 less dense than steel, but also 1/3 less stiff, so the speed of sound in alum is on the same order of magnitude as steel. Now diamond will transmit sound the fastest amongst most common materials, but who can afford it, especially in the 2 light year length?:eek: So only by changing the composition of the material can you increase the force transmission speed. Increasing the force will incease the acceleration of the cm of the pole, but I do not believe it will affect the time it takes for the far end to start moving.
Agree. Try one of Einstein's rigid measuring rods.
Look, I'm not touching Einstein's rigid rod.
And I'm not touching that response. :smile:
lol :smile:
PhanthomJay, thanks, that was a very concise response.
And is E - the elasticity modulus - the same as Young's modulus that negitron mentioned?
Yes, it is.
negitron, your response to my post was quite rude, and, since you claim in a subsequent post that the content of my post is well oustide your area of expertise, I don't understand how you qualify it.
Anyway, I don't want to hijack this thread with a some little dispute, so I would like to hear your explanation for E<ρc, where E is the elastic modulus of the rod, ρ is the density of the rod, and c is the speed of light.
My main point was the irrelevance of a discrete lattice for the explanation. Explanations that involve the speed of sound tend to lead the eager young minds to a misunderstanding about Special Relativity. (Of course, I will admit, I am simply assuming that the question is posed in the context of Special Relativity, and it may very well be a solid-state physics question for all I know.)
If I may interrupt again, the OP needs to clarify the point of the question. I did not view it as a question on Special Relativity, but rather, a question about how long it takes for the far end of a long pole to move when a force is applied to the near end. Maybe I misinterperted it. Nonetheless, I would argue in the following manner: If the pole was say 6000 meters long and made of steel, and the speed of sound in steel is 6000m/s, and an axial pushing force is applied to one end, then it would take at least one second to see any movement at the other end. Movement would certainly not be instantaneous. I would further argue that if the material were completely rigid (that is, undeformable, with infinite stiffness (E modulus), a hypothetical case for sure), then although non relativistic formulas would yield the speed of sound as infinite for this case, implying instantaneous movement at the far end, that in reality, since nothing can go faster than light, the speed of sound would be limited to the speed of light in this hypothetical case. Now if the pole was 2 light years in length, the question of 'how long does it take the far end to move' may get into SR theory, and I'm no expert on that. But I'm guessing, without doing the math, a couple of hundred of thousand years for me to see it as measured by my clock, if steel; and if ideally rigid, 4 years (2 years for the force vibrations to get there and 2 more years for me to see the event thru my powerful telescope). What do you think? And what does Vorcil say about the original question??
It seems to be a contradiction, then. If E=∞, then doesn't that result in an infinite sound speed? Imagine a very simplified model: a lattice of a single spring connecting two masses at a distance of 2 lyrs. Wave propagation in the lattice is based on Newton's laws:
Law 3: Push on mass #1 and then the spring pushes back.
Laws 1 and 2: But the spring only pushes back because the spring itself is connected to another mass, which presents inertia (requires force to be accelerated).
Law 1: (only applicable for many lattice points) The lattice can sustain a wave because, after a given mass in the lattice is pushed, a force is required to return it back to some eq position.
Basically, the claim that "nothing can go faster than light" is simply vacuous, and this kind of thinking leads to confusion about what Special Relativity really says. For example, the concept of simultaneity "goes faster than light", meaning that the two ends of the rod can be said to exist at the same moment in time, even though they are separated by some distance. Granted, there is no single massive object moving faster than light w.r.t. any other massive object; however, note that the issue involves the temporal relation between the spatial position of two spatially separated objects (namely the two ends of the rod).
PhanthomJay said:
Now if the pole was 2 light years in length, the question of 'how long does it take the far end to move' may get into SR theory, and I'm no expert on that. But I'm guessing, without doing the math, a couple of hundred of thousand years for me to see it as measured by my clock, if steel; ...
Yes. Here is the distinction that I suggest. If the purpose of the question is to demonstrate material properties, such as the finite propagation of an impules in one part of a real material to another part of that material, then sure, there will be a delay. However, 2 lyrs is a rather exotic length for any material, and so I assumed that the this question regarded some distant future (in which humankind could actually construct such a rod). That being the case, I did not want to limit the consideration to known materials with such low stiffness-to-density ratios. In other words, if we're allowed to imagine the existence of a 2-lyr rod, then I think we should imagine a perfectly rigid material.
PhanthomJay said:
for me to see it as measured by my clock ... if ideally rigid, 4 years (2 years for the force vibrations to get there and 2 more years for me to see the event thru my powerful telescope).
Just a comment on this: if you set your watch to t=0 at the moment you push your end of the rod, and you know that the rod is 2 lyrs to the other end, then you would automatically know to subtract the 2-yr delay, and this is the idea of simultaneity. So, you would be able to say (assuming that Special Relativity is correct) that the other end of the rod moved 2 yrs after you pushed your end. Then again, if the speed of sound in the rod is infinite, then you would still have to wait 2 yrs to see the other end move. And that's the point. Simultaneity. And the other point is that simultaneity is relative. The problem with the infinite speed of sound is not some specific material property, it is a fundamental property of space and time. You have to ask yourself, "What would an observer in a boosted frame see?" The answer, according to Special Relativity, is that,
if a perfectly rigid rod (E=∞) is pushed at one end, then a boosted observer could actually see the other end of the rod move before the push.
Yes, it does. That is why the formula for the speed of sound in a solid medium, v=sq root E/p, is not valid for hypothetical materials with high E/p ratios. Even the speed of sound in diamond (which is one of the stiffest materials known, transmitting sound waves at 12,000m/s), is only a tiny tiny fraction of light speed. I make no statements as to what the speed of sound would be in near rigid materials, except to say that its speed could nor exceed the speed of light.
Fine, but that does not answer the question as to what time elapses before the far end starts to move.
Are you saying that sound waves in a near rigid material can travel faster than light??
I don't know how you can assign a speed to simultaneity. That's like asking 'what is the speed of time?'. With Einstein as my guide, 2 spatially separated events occurring at points A and B are simultaneous if an observer standing midway between A and B sees both events at the same time. I claim that an observer standing at 1 ly away from points A(the left end) and B (the right end) of the 2 ly length pole, that is, at its midpoint, will not see the events (the application of the force at A, and the movement of the pole at B) at the same time.
I think you'd have to consider a near rigid material, or else there would be no definitive answers.
Which I guess is why perfect rigidity, except in the case of Einstein's rigid rod, makes no sense.
And that is why I claim that discussion of material property is irrelevant.
Why do you claim that it cannot exceed the speed of light?
I was never trying to answer the question of what time ellapses. However, I do claim that Special Relativity imposes an upper limit on the ellapsed time in terms of the spatial distance.
I make no claim about this.
Yes, that was rather vague on my part. What I wanted to convey is that nothing stops you from dividing a spatial distance between events by the time between the events in a given frame of reference, and then labelling this as a speed. And, furthermore, that is what we're talking about. The two events are the push at the near end of the rod, and the motion at the far end of the rod. This issue deals precisely with the ratio of the spatial distance between these two events divided by the time between these two events. What Special Relativity actually says about this situation is that, if this ratio is greater than c, then the push could not have caused the motion (nor vice versa) - the events are not causally connected. So, the simple conclusion to draw from Special Relativity is that the far end will not move instantly in response to a push at the near end.
It is a common misconception (or oversimplification, at least) that Special Relativity prohibits speeds greater than c. Special Relativity separates speeds into categories: timelike, lightlike, and spacelike. The spacelike speeds are the ones that you might call unphysical or disallowed. (Special Relativity further implies that the category is invariant to Lorentz transformation.)
In fact, the travel of particles faster than light is quite commonplace in Quantum Field Theory (however, their interpretation is a different issue).
PhanthomJay said:
Which I guess is why perfect rigidity ... makes no sense.
That is exactly what I'm trying to convey. The reason has nothing to do with the fact that the material is composed of atoms connected by electromagnetic forces. The reason is based on a fundamental property of physics: causality.
If you suddenly move one end, you'll create a shockwave that propagates faster than the speed of sound.
I agree with Turin about special relativity being irrelevant. This is also explained in this article:
http://arxiv.org/abs/gr-qc/0107091
I think that's a contradiction (i.e. that you misunderstood).
you push it 1m,
Wow! This thread makes me laugh. This seems like a simple conceptual question from a basic modern physics course, but it has been severely over-analyzed in this thread.
Your right. The other end does not move, because it would violate one of the postulates of special relativity; nothing travels faster than light speed. Problem solved.
Perhaps, it may help if the OP in the homework section of PF lists the course from which the problem is assigned.
  • #31
You haven't been following along. You'll create a shockwave that will travel at the speed of sound of the material of which the object is made.
buffordboy23 said:
Wow! This post makes me laugh. This seems like a simple conceptual question from a basic modern physics course, but it has been severely over-analyzed in this post.
Obviously you memorized your equations in school and never bothered to understand them. Because if you placed any value in understanding, you would never have posted that.
It is easy to say something violates a law. That doesn't help the OP understand where he's thinking about it wrong. Or lead him to the correct answer.
Which is what we like to do here.
  • #32
Whatever. The solution to the problem does not ask us to think this way b/c it does not give us enough info.
On top of that, the OP never stated any assumptions (of this own choosing or from the text) concerning the properties of the pole. If he assumes (or the text) that it is an ideal rigid body (i.e., the distance between mass elements of the pole is constant, always - which is usually the case in introductory texts), then we have just violated special relativity. However, on the contrary, we must acknowledge the fact that no body is truly an ideal rigid body, and thus the most realistic answer is the one in which you have just prescribed.
This is the answer, but where is the subsequent post from the author of the OP that shares his (or her) thoughts concerning this discussion? Absent. Great work.
  • #33
We don't wait to be told how to think. :rolleyes: In a discussion that can span days instead of seconds, it makes sense to anticipate the next question.
And the question does give us enough info. We know why the end of the pole doesn't instantly move. It's because we know the pole is not rigid. If the OP had been assuming a non-existently rigid pole he would have had to state that.
  • #34
you push it 1m,
There are two answers. Yes, if the pole is an ideal rigid body, which shows that ideal rigid bodies are not compatible with special relativity. No, if the pole is not an ideal rigid body, because the force must transmitted from atom to atom through the pole, which is slower than the speed of light.
The author of the text phrased the problem so that you would recall one of the postulates of special relativity. The "two light-years in length" flips the switch for the student. It's really an awkward question and could be improved by generalization; i.e., the pole can be of any length (say, 1 meter) and when you push the one side causing an incremental displacement dx of that side, does the other side move instantaneously with a displacement of dx. Think about that the next time you are pushing furniture around the house.
  • #35
Well no wonder it takes so long to do so! :biggrin:
  • #36
Why would we assume something that does not exist? With that logic, we might as well assume invisible elves too.
  • #37
Don't shock waves always travel faster than the local velocity of sound? We are not talking about an infinitessimal perturbation of the local density here. We are moving one end of the pole by a finite amount. I would like to see a detail analysis from first principles of this problem. Let's take a cylindrical pole of length L, cross section A with elasticity modulus E, Poisson ratio nu, and density rho.
Then we're going to move one end by a finite amount of d ising some impulse force. So, we have to think about the appropriate initial conditions. We can't just take the stress tensor at the boundary to have some intial value, we must make sure that there is some actual finite displacement in a finite time in the limit that L goes to ininity.
  • #38
Does someone have a grudge?
How about this reason? B/c a large number of the ideas in introductory physics assume such idealized notions, and it becomes part of the student's thinking when solving problems. When the student gets to more advanced classes, these ideals are shown to be adequate. It's illustrative to see why an assumed ideal model can be successful in some domains, but not in others.
  • #39
Not sure, but it does seem that the speed of the shock wave must at least start at the speed of the impacting force, which easily can be faster than the speed of sound in the material. I think the shockwave degenerates to a normal sound wave over time.
  • #40
I think the question of what would "really" happen, in terms of sound propagation, is just too complicated. Notice that the OP does not specify how quickly the near end moves. It could take years to move 1 meter. I think that, if it is moved slowly enough, then the elastic response can be treated linearly. If the near end of the rod is pushed as fast as possible (let's say much faster than the speed of sound in the material of the rod), then I would assume majorly nonlinear phenomena (i.e. shockwave), at least initially, and I wouldn't know how to sort that out. The speed of sound can depend on frequency and amplitude.
  • #41
No, it just means you lay out the multiple cases and state your assumptions in each, as you just did.
  • #42
As someone who entered the thread with "This thread makes me laugh. ... it has been severely over-analyzed..." I think you have no complaint if you don't like the response you get.
I agree, considering an idealized case is a perfectly valid technique, but in this case, the answer is right in front of him; it is unnecessary to idealize (i.e. modify) the scenario. The basic question has a basic answer; the "real" physics case is more valid than the "idealized" case.
  • #43
It wasn't my best post, but its character remains true. Obviously, the student is looking for a simple explanation, but the thinking goes way beyond and requires assumptions (besides the ideal rigid body case) that are not given. You and other PFers even said so in previous posts.
You can criticize the content of my response all you want. This is just one process of how science works. However, when you criticize the individual (me), this is when we will have problems.
Yes, but this is not his thinking in the OP and his subsequent posts. He accepts the notion that nothing can travel faster than the speed of light, yet the solution to the problem does not make sense to him. He doesn't explicitly state the assumptions regarding the problem, but he does assume that the pole is an ideal rigid body. This is evident b/c his inexperience leads him to the equations of special relativity, which is the wrong approach here. These two ideas (speed of light and ideal rigid body) are in conflict, and rightly so. He must abandon the idea that the pole is an ideal rigid body to understand the realistic answer here.
  • #44
I was criticizing the individual, yes. Laughing in derision is not a valid argument, it is an attack.
Anyway, water under the bridge. You've recovered from it.
Yes, which is why your simple answer that it violates relativity doesn't help him much. It is only incidentally a relativity issue. The most important issue is to recognize that the rod is not rigid. This principle would apply even if relativity were not a factor.
For example, if the OP went away thinking this was a relativity issue, he might logically conclude that a normal rod (say, made of wood) of extraordinary length could move both ends almost simultaneously, as long as the transmission was less than c. He would not be much better off; he would still be missing the point by many, many orders of magnitude.
  • #45
At high school level it happens quite often that teacher will give a simple but misleading or even flawed explanation to students.
  • #46
I disagree. It answers his question by illustrating that his belief that the pole is an ideal rigid body is a misconception.
Like I said before, it's a really awkward question. The question would be just as valid if we were talking about a 1 meter^3 block (although the results would vary dramatically); the original problem was designed to make the answer stand out. The only aspect from relativity that comes into play is that no transmission is greater than c.
Yes, I agree. This is great for further understanding but it was not his question. Others already touched on it, so I chose to focus only on the misconception. It is good to discuss though, but it looks like the OP has left the building (this thread) a while ago.
  • #47
I agree. I would also suggest that it often happens where the teacher gives explanations way over the student's head.:biggrin:
