A question about relativity of simultaneity
116 replies · 11K views
DmitryS
Hello. I'm new here and very much afraid of breaking rules. I would gladly post this question in the Homework section, because it's homework, but my question doesn't fit the template, it's a theory question. I hoped to find it in Relativity FAQ's, but it's not there.
I can tell you I grasped very well the idea of the relative simultaneity which appears when you use the Lorentz transforms, but I don't understand the illustrations.
In Einstein's train thought experiment, we have two lightnings which simultaneously strike at the front and the back of the car. The textbook says, the observer in the center of the car will get the light of the front lightning earlier than the light from the back lightning.
I don't understand why it happens. It seems intuitive, but the velocity sum will yield the same velocity of light both from the front and the back lightning.
Why are they speaking about this thought experiments? They seem so confusing! It's so much easier to stay with Lorentz transforms.
Do we need these thought experiments at all?
The lightnings strike simultaneously with reference to the rest-frame of the embankment. They strike not simultaneously with reference to the rest-frame of the train.
Source:
https://en.wikisource.org/wiki/Rela..._I#Section_9_-_The_Relativity_of_Simultaneity
That is because, described with reference to the rest-frame of the embankment, the observer in the center of the car is moving towards the light pulse coming from the front. The closing speed between this light pulse and the mentioned observer is ##c+v##. And he is moving away from the light pulse coming from the back side.
I think understanding them they helps to understand and apply the LT.
But that is the problem I'm asking about. The relative speed is greater than the speed of light. Why we can't apply the speed addition formula?
That is not a "relative speed" it is a "rate of closure".
A relative speed is the speed of one thing in the rest frame of another.
A rate of closure is the rate at which the distance between two objects changes as assessed in the rest frame of a third-party observer. In the usual case of objects on a collision course or departing from a shared event, it will be equal to the difference between the two object's velocities and, thus, will be limited to ##2c##.
If I (sitting on the embankment) watch a pulse of light move from the center of a passing train rearward toward the caboose then the rate at which the distance between light pulse and caboose decreases will be a rate of closure (##v - -c = c + v##). Similarly for the rate at which a forward pulse catches up with the engine at the front of the train (##c - v##)
You can get away with just plain old velocity addition in the case of closing velocities because you are adding apples with apples. You are considering two velocities both taken from the same frame of reference. No coordinate transformations to worry about. No length contraction or time dilation as long as everything is measured against the same frame of reference. Just plain old every day positions and velocities.
It is when you are trying to deal with the velocity of object A with respect to the ground and the velocity of object B with respect to object A that you need to start worrying that the two velocities were not drawn from the same frame of reference. Then you need to transform one of the velocities to the same reference frame as the other to be able to add them correctly. That is when time dilation and length contraction (and the relativity of simultaneity) come in. The end result then is the relativistic velocity addition composition formula.
You can't add velocities like that in relativity. If you see an object doing speed ##u## and I see you doing ##v##, I do not see the object doing ##u+v##, but rather$$\frac{u+v}{1+uv/c^2}$$If you feed ##u=c## in then you will find that I also see the object doing ##c##. Note also that if both ##u## and ##v## are much less than ##c## the denominator is nearly 1, which is why you can just add speeds in the Newtonian (low speed) approximation.
As others said, in case of a closing speed, the "addition formula" cannot be applied.
The "addition formula", which has a misleading name, applies only for transforming a velocity ##u= \frac{dx}{dt}## from one inertial frame to another.$$u' = \frac{dx'}{dt'} = \frac{\gamma(dx-vdt)}{\gamma(dt-vdx/c^2)}= \frac{\gamma(\frac{dx}{dt}-v)}{\gamma(\frac{dt}{dt}-\frac{dx}{dt}v/c^2)} = \frac{u-v}{1-uv/c^2}$$
If you understand the difference between closing speed and velocity transformation, then you have already learned something important from this Einstein thought experiment.
I'm afraid I didn't say everything I was thinking. If we use closing speed to assess the time difference, we get coefficients of the time transformation which are not the Lorentz coefficients.
The closing speed is described in one reference frame only, in my posting #3 with reference to the rest-frame of the embankment. There is no LT applied.
So what? That's not what the Lorentz Transformation describes.
But that's the question I am asking, don't you see? The clocks of the moving frame of reference which are located along the line of motion are not synchronous according to the observer at rest. And LT describes how they are asynchronous.
The relativity of simultaneity test like explains why this happens, and I see discrepancy between the LT and the experiment.
I'm not saying you're wrong - I believe you're right. I just can't make these things work together.
And I gave another thought to the closing speed concept, and now I'm not happy with it at all.
Let's don't talk light. Supposing there is a toy car in the middle of the traincar moving towards the back of the train at the speed w. The closing speed will be ##v + w##. So, when the toy car reaches the back of the traincar, time measured by the clock of the motionless frame of reference is $$t = \frac {l} {v + w},$$ where l is a half-length of the traincar measured in the motionless frame. That means that the distance to which the train has shifted in this while is $$x = \frac {lv} {v + w}.$$ This must be the coordinate where the toy car is at the end. The toy car moved to the distance of $$l -\frac {lv} {v + w} = \frac {lw} {v + w}$$ in the stationary frame. But, at the same time, the velocity of the toy car in the stationary frame is $$u=\frac {v-w} {{1 -\frac {wv}{c^2}}$$.
If you divide the distance
$$\delta x = \frac {lw} {v + w}$$
by that, you will have different time.
I'm not sure I got you right what you said when the LT apply or don't apply, but even if you use the proper length of the traincar these don't fit together.
That's my problem, see? I think that the closing speed concept and the Einstein velocity composition cancel out.
Description with reference to the rest-frame of the embankment:
At the time, when both lightnings happen synchronous at positions ##A## and ##B##, the observer in the center ##M'## of the car is at position ##M## in the middle. Shortly afterwards, he ist on the right side of ##M##.
The light-pulse from the front needs the following time-interval to reach the observer in the center of the car:
##\overline{BM}/(c+v)##
The light-pulse from the back needs the following time-interval to reach the observer in the center of the car:
##\overline{AM}/(c-v)##
Because the distances ##\overline{AM}## and ##\overline{BM}## are equal, the observer in the center of the car sees the light-pulse from ##B## earlier than that from ##A##.
Here you mix up two different frames. That is a scenario not to use the closing speed, but the velocity transformation "relativistic velocity addition formula" instead.
I do nothing of the kind! I always stay in the embankment frame of reference, as you said!
If you have the closing speed scenario which is true in the motionless frame, you have this time measured by the stationary clock. If you gave the Einstein velocity composition, you have a different time of the same event.
But if you understood your text correctly, ##w## is the toy car's speed with reference to the train's rest-frame.
Whenever the Einstein lightning thought experiment comes up, I always say that it is particularly confusing and misleading. I always recommend that it should be ignored in favour of the much simpler examples of the RoS.
I don't know whether the experiment is confusing you or you are genuinely confused by the RoS.
The invariance of the speed of light and the invariance of simultaneity are incompatible. That's not too hard to see with a bit of basic kinematics. It doesn't need simultaneous lightning strikes or the Lorentz Transformation.
I must have confused it. First, we calculate the speed of the toy car in the stationary frame, and then we can apply the closing speed scenario?
Even saying the "stationary" frame is misleading - the platform frame is no more a "stationary" frame than the train frame.
Yes.
Yes.
Thanks. What about the first part of my problem?
"The clocks of the moving frame of reference which are located along the line of motion are not synchronous according to the observer at rest. And LT describes how they are asynchronous.
I'm not saying you're wrong - I believe you're right. I just can't make these things work together."
"The clocks of the moving train frame of reference which are located along the line of motion are not synchronous according to the observer at rest on the platform.
From the 1905 paper:
... suggest that the phenomena of electrodynamics as well as of mechanics possesses no properties
corresponding to the idea of absolute rest.
I don't see, because there was a melt-down in your Latex. Can you fix that?
Animations of train experiment as seen by embankment and train observers:
Embankment observer notes that train just fits between red dots, as lightning flashes are emitted.
The train is in motion is in relative motion, so it is length contracted( if it wasn't, it wouldn't fit between the dots). The right flash meets up with the train observer when he is 4 ties past the track observer, and the left flash catches up when he is almost to the right red dot.
For the train observer, it is the tracks that are length contracted, and the train does not fit exactly between the dots. The right dot reaches the front of the train before the left one reaches the rear of the train. The train observer must agree with the track observer that the lightning struck both the ends of the train and the red dots when they were aligned with each other. Since the two ends reach their respective dots at different moments, the strikes cannot be simultaneous. Note that the train observer also agrees that the right flash reaches him when he is 4 ties from the track observer, and the left one when he is near the right red dot.
The same applies to Einstein's train/embankment thought experiment. It describes with reference to the rest-frame of the embankment, why the observer in the center of the car receives the two light-pulses at different times.
The conclusion for the description with reference to the rest-frame of the train:
The train is at rest and the embankment is moving backwards.
The observer is at rest at ##M'##. This location is in the middle between the locations ##A'## and ##B'## in the train, where the lightnings happened. Both light-pulses moved over equal distances with equal speeds ##c## towards this observer at rest at ##M'##. Because the observer receives the two light-pulses at different times and first the light-pulse from ##B##, the lightning at location ##B'## must have happened earlier than the lightning at location ##A'##.
The clocks of the moving embankment-frame, which are located along the line of motion, are not synchronous according to the observer at rest at ##M'## in the train. (And LT describes how they are asynchronous.)
It's MUCH simpler to just do the Lorentz transformations of the trajectories of the wave fronts and the points ##M## and ##M'##. In the embarkment frame those are
$$x_{A/B}=(ct,\mp L/2 \pm c t), \quad x_{M}=(c t,0), \quad x_{M'}=(ct,v t).$$
Now just do the Lorentz transformation and, check when the light signals reach ##M## and ##M'## from the point of view of the observer in the train. As a byproduct you'll also find the length contraction, i.e., the length of the train as seen from the embarkment is shorter than the length in the train's rest frame.
I think we need to put a valid calculation on the table, as it were. We have a train wagon of length ##L##, as measured in a frame in which it is traveling with speed ##v## to the right. A source in the centre of the wagon emits a pulse of light towards both ends. When the light hits each end of the wagon, a clock at each end of the wagon is set to ##0##.
Under the assumption that the light is at the centre of the wagon in the wagon's rest frame (exercise to justify this), in the wagon frame the clocks at either end are set to ##0## simultaneously.
Now, let's look at the scenario in the frame where the wagon is moving.
The light hits the rear of the train at time ##t_1 = \frac{L/2}{c + v}## and the front of the train at time ##t_2 = \frac {L/2}{c-v}##. That's the relativity of simultaneity right there, in a nutshell. No need for miraculously simultaneous lightning strikes!
And, we can calculate $$\Delta t = t_2 - t_1 = \frac{Lv}{c^2 - v^2} = \frac{Lv}{c^2(1 - v^2/c^2)} = \frac{Lv\gamma^2}{c^2}$$Now, if we know about time dilation, then the rear clock will have advanced only$$\Delta t' = \frac{\Delta t}{\gamma} = \frac{Lv\gamma}{c^2}$$And, we can see that when the front clock reads ##0##, the rear clocks reads ##\Delta t' = \frac{Lv\gamma}{c^2}##. Note that ##L## is not the rest length of the wagon here.
Now, let's check the Lorentz transformation. We have two events in the frame in which the wagon is moving: ##(0, 0)## and ##(\Delta t, L+v\Delta t)##. We get this by putting the origin at the rear of the train.
These transform to ##(0,0)## and $$(\gamma(\Delta t - \frac{v(L+v\Delta t)}{c^2}), \gamma(L + v\Delta t - v\Delta t)) = (0, \gamma L)$$ in the wagon frame. As expected. Note that we also get the rest length of the wagon as ##\gamma L## from this. Finally, let's just check that calculation of the time coordinate in the last step:
$$\Delta t - \frac{v(L+v\Delta t)}{c^2} = \Delta t(1 - \frac{v^2}{c^2}) - \frac{vL}{c^2} = \frac{\Delta t}{\gamma^2} - \frac{vL}{c^2} = \frac{vL}{c^2} - \frac{vL}{c^2} = 0$$And everything is hunky dory.
That's right. And if you assess the effect with (c+v) and (c-v), you get the coefficients which are not LT. That's the problem I'm talking.
What don't you understand about post #26? The Lorentz Transformation encapsulates time dilation, length contraction and the RoS. Where's the problem you are talking about?
I don't know, what you want to Lorentz-transform.
You could for example Lorentz-transform the coordinates of the two lightning events from the (unprimed) embankment rest frame into the (primed) train rest frame.
Event A: ##\ \ \ \ \ \ x_A=-\frac{L}{2}##, ##\ \ \ \ \ \ t_A=0##.
Event B: ##\ \ \ \ \ \ x_B=+\frac{L}{2}##, ##\ \ \ \ \ \ t_B=0##.
Transform event A coordinates:
##x'_A = \gamma (x_A - vt_A) = -\gamma \frac{L}{2}##, ##\ \ \ \ \ \ t'_A= \gamma (t_A - vx_A/c^2) =\gamma \frac{L}{2}v/c^2##.
Transform event B coordinates:
##x'_B = \gamma (x_B - vt_B) = +\gamma \frac{L}{2}##, ##\ \ \ \ \ \ t'_B= \gamma (t_B - vx_B/c^2) =-\gamma \frac{L}{2}v/c^2##.
From ##t'_B < t'_A## you see, that events B happens earlier than event A, with reference to the train rest frame.
As noted upthread, ##(c+ v)## and ##(c-v)## are the closing rates of the light pulses and the observer on the train as measured in the embankment frame. The closing rate is not the same thing as the relative speed. The closing rate is the change in the distance I measure in my frame between you and some object. The relative speed is the change in distance you measure from you to an object in your frame (note that there are only two things in this description, while there were three in the description of closing rate). These quantities are distinct. In Newtonian physics they are degenerate and have the same value. In relativity they are not the same.
So you seem to be correctly calculating the closing rate and worrying that it is not the same as the relative velocity. Don't. They are not the same.
You might ask why they are not the same. Fundamentally it is because we are choosing to divide spacetime into space and time in different ways (which is what "using different frames" means). The direct consequence of that is that I see your rulers as length contracted, and your clocks as time dilated and incorrectly synchronized. Thus I am not surprised that you do not measure ##c\pm v## for the speed. You would say the same of my clocks and rulers, so should not be surprised that I don't measure ##c## for the closing rate.
Likes   Reactions: malawi_glenn, vanhees71, Sagittarius A-Star and 1 other person
