A rather tricky magnetic field problem.
9 replies · 5K views
orionj
A proton moves through a region of space where there is a magnetic field [tex]\vec{B}[/tex]= (0.61[tex]\hat{i}[/tex] + 0.36[tex]\hat{j}[/tex]) T and an electric field
[tex]\vec{E}[/tex]= (2.8[tex]\hat{i}[/tex] - 4.3[tex]\hat{j}[/tex]) *10[tex]^{3}[/tex] V/m. At a given instant, the proton's velocity is [tex]\vec{v}[/tex]= (6.3[tex]\hat{i}[/tex] + 2.9[tex]\hat{j}[/tex] - 4.8[tex]\hat{k}[/tex]) *10[tex]^{3}[/tex] m/s.
Determine the components of the total force on the proton.
F[tex]_{x}[/tex]= ?, F[tex]_{y}[/tex]= ?, F[tex]_{z}[/tex]=?
I assume what needs to be used is the "Lorentz Equation" which is:
[tex]\vec{F}[/tex]= q([tex]\vec{E}[/tex] + [tex]\vec{V}[/tex] * [tex]\vec{B}[/tex])
and use the q of a proton which is 1.6*10[tex]^{-19}[/tex].
I attempted to use a cross product of [tex]\vec{V}[/tex] and [tex]\vec{B}[/tex] and it seemed to be on the right track but I ended up getting stuck on what to do with [tex]\vec{E}[/tex] and honestly I ended up getting stuck on the whole problem and not sure at this point where to start and end.
Your on the right track.
HINT: Try starting by working out the cross product and getting it in terms of components. Then, group all the x component terms together, all the y component terms together, etc. (This includes the E field terms as well.) Do you see how you can get your answer from here on out?
How'd you get stuck on E? V cross B times the scalar q gives you a vector, and q*E is a vector. Do you remember how to add two vectors?
Then you'll have the force vector, with its x, y, and z components
I would say I am a bit rusty when it comes to vectors, I did attempt to do the basic vector addition and the answer I imputed the online homework application disliked lol.
I got the answers
1.715*10[tex]^{-16}[/tex][tex]\hat{i}[/tex]
-2.195*10[tex]^{-16}[/tex][tex]\hat{j}[/tex]
-7.98*10[tex]^{-17}[/tex][tex]\hat{k}[/tex]
and the homework program told me to check my signs, and told me I was incorrect. What did I do wrong?
I keep trying to do the cross product, then adding the vectors together and the third vector never seems to work out right.
I haven't been doing vectors much, but isn't it just possible to take each composant at a time? So for example Fi=Ei*Q + Q*Vk*Bj. Then no vector addition is required.
Out of curiousity, what then would be the setup for Fj and Fk?
What do you get when you work out v X B?
If my theory is correct, it should be like:
Fj=EjQ-BjVkQ
Fk=EkQ+QVjBi-BjViQ
it seems like the the +/- depends on how you define the positive directions for y/x/z in k/i/j, so I am not sure on these.
