A ring with charge Q and radius 'r'
5 replies · 2K views
squelch
Show that ##\vec{E}_x## on the axis of a ring charge [I'm assuming they meant "of charge Q"] of radius "r" has its maximum value at ##x=\pm \frac{r}{\sqrt{2}}##
Linear charge density ##\lambda=\frac{Q}{2\pi R}##
##dQ=\lambda ds = \frac{Qd\theta}{2\pi}##
##\vec{E}=\frac{KQ}{R^2}##
Let the distance between an infinitesimal sector of the ring with charge ##dQ## and a point ##P## be ##a##. Then ##a=\sqrt{x^2+r^2}## where r is the radius of the ring. Note that to save some typing, I will use ##a## and ##\sqrt{x^2+r^2}## interchangeably.
Let ##\theta## be the angle formed by a and the x axis, then:
##cos\theta=\frac{x}{a}=\frac{x}{\sqrt{x^2+r^2}}## and ##sin\theta=\frac{r}{a}=\frac{r}{\sqrt{x^2+r^2}}##
Now, ##d\vec{E}_y=0##, because all forces in the y-component cancel, leaving ##d\vec{E}_{total}=d\vec{E}_x=d\vec{E}cos\theta##
##\therefore d\vec{E}=\frac{KdQ}{a^2} cos\theta##
Because ##dQ= \frac{Qd\theta}{2\pi}## and ##cos\theta=\frac{x}{\sqrt{x^2+r^2}}##
##d\vec{E}=\frac{KQx}{2\pi a^3}d\theta##
Now, integrating from 0→2∏ to find ##\vec{E}##
$$\vec{E}=\frac{KQx}{2\pi a^3} \int_{0}^{2\pi} d\theta = \frac{KQx}{a^3} = \frac{KQx}{(x^2+r^2)^{3/2}}$$
From here, I'm not sure how to use this to "prove" that ##\vec{E}_x## has a maximum value at ##x=\pm \frac{r}{\sqrt{2}}##
How do you go about finding the maximum or minimum of a function of x?
squelch said:
First derivative test?
You've sort of got the right idea. Set the first derivative w.r.t. x to zero and solve for x. Then test the second derivative at x to see if you've found a maximum or a minimum. It's a Calculus 1 topic.
Right, but I don't feel like I have my ##\vec{E}## right. I keep seeing that ##\sqrt{x^2+r^2}## and thinking that I missed that I was supposed to do trig substitution somewhere along the way.
You formula for E is correct. You need to find x where the function ##\frac{x}{(x^2+r^2)^{3/2}}## has its extrema.
ehild
