A screen with three slits and 1 gets blocked --> diffraction?
  • Thread starter Thread starter ElectricEel1
    Diffraction Screen
The discussion centers on calculating the diffraction pattern produced by a screen with three slits when either the middle or one of the side slits is blocked. The relevant equations include a*sin(theta) = m*lambda and Y = (m*lambda*L)/a. When blocking the middle slit, the separation is 2a, while blocking a side slit retains the separation as a. Sample calculations using a = 300 microns, b = 10 microns, L = 10 m, and lambda = 500 nm yield distances of 0.0082 m and 0.017 m for the two scenarios, respectively.
  • Understanding of wave optics and diffraction patterns
  • Familiarity with the equations of diffraction, specifically a*sin(theta) = m*lambda
  • Basic algebra skills for manipulating equations and performing calculations
  • Knowledge of the significance of slit width and separation in diffraction experiments
  • Study the principles of diffraction and interference in wave optics
  • Learn about the impact of slit width and separation on diffraction patterns
  • Explore the use of simulation tools for visualizing diffraction patterns
  • Investigate the application of diffraction in real-world scenarios, such as spectroscopy
Students studying wave optics, physics educators, and anyone interested in understanding the principles of diffraction and its mathematical modeling.
ElectricEel1
A screen with three equally spaced slits of the width b and separation a is illuminated at normal incidence with monochromatic light with wavelength lambda. A diffraction pattern is obtained at a distance L on another screen positioned behind the screen with the slits. Calculate and compare the distance between the diffraction maxima with numbers m and m+1 for the cases when either the middle or one of the side slits is blocked. Assume a>>m*lambda
a*sin(theta)=m*lambda
Y=(m*lambda*L)/a
Im not entirely sure what it is asking me to do but I started by finding the equations I wanted to use then figured the separation for blocking the middle would be 2a+b and the separation for blocking one of the side slits would just be a.
Then I wrote the two cases up and took the difference between the Y at m=2 and m=1 for both. With no values given I'm not sure where to go next just with algebra, I subbed in some values of
a=300 micron b = 10micron L = 10m lambda = 500nm
and got 0.0082m distance in the first case and 0.017m in the second case but I am not sure this is what I'm being asked to do.
Thanks
That's not logical if you use a for the side slit blocked case. Usually separation a means from center to center.
Otherwise Ithink you are doing fine. Check with Hyperphysics if in doubt
its just 2a, right? not 2a+b for when the middle slit closes. that way everything should scale and the y position of the middle slit blocking will be half
piece of cake. looks good to me
10K
