A set of two 2nd order linear ode
omyojj
I'm doing an undergrad research job..
I have encountered the following coupled 2nd order linear ODE with constant coefficients a, b, c, d...
\begin{align} \frac{d^2 y_1}{d x^2} + a^2y_1 &amp; = -c y_2 \\<br /> \frac{d^2 y_2}{d x^2} - b^2y_2 &amp; = -d y_1 \end{align}
In addition, I would like to impose constraints
\frac{d y_1}{d x}|_{x=0} = \frac{d y_2}{d x}_{x=0} = 0
(y_1, y_2 are even in x)
if c were zero..the solution would be simple..
\begin{align} y_1 &amp; = A \cos(ax) \\<br /> y_2 &amp; = B \cosh(bx) + C \cos(ax) \end{align}
but i cannot proceed further when c is not zero..
did I fall into the silly trap??
please help me find the solutions..
Re-write this vector form:
<br /> \vec{y}&#039;&#039;=A\vec{y}<br />
with y=[y1 y2]
and A=[-a^2 -c; -d b^2 ]
Like in an ordinary constant coefficient ODE, we suggest solutions of the form
<br /> \vec{y}=\vec{v}e^{sx}<br />
Substituting into the equation gives:
<br /> s^{2} \vec{v}e^{sx}=A\vec{v}e^{sx}<br />
or
<br /> (A-s^{2}I)\vec{v}=0<br />
For this algebric equation to have a non-trivial solution, the determinant of the matrix must equal to zero. You might recognize this as searching for eigenvalues, only here the eigenvalues are \lambda=s^{2}.
In the most simple case, you'll get two real positive eigenvalues with one eigenvector which,
for which you will have four basic solutions:
\vec{y}=K_{11}\vec{v_{1}}e^{\sqrt{\lambda_{1}}x}+K_{12}\vec{v_{1}}e^{-\sqrt{\lambda_{1}}x}+K_{21}\vec{v_{2}}e^{\sqrt{\lambda_{2}}x}+K_{22}\vec{v_{2}}e^{-\sqrt{\lambda_{2}}x}
Off course other cases, will need more algebric manipulation, to pull out a real solution (f.e. if you get complex eigenvalues, your solutions will be periodic)
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
