Is There a Shorter Proof for 0.999... = 1?
  • Thread starter Thread starter waterchan
    Proof
The discussion centers on the mathematical equivalence of 0.999... and 1, with various proofs and perspectives shared. One participant highlights a simple proof using the relationship between 1/3 and 0.333..., leading to the conclusion that 1 = 0.999... This prompts debate about whether such manipulations constitute a valid proof or merely a demonstration. Some contributors express frustration over misconceptions surrounding infinite decimals and the nature of real numbers, emphasizing that 0.999... is indeed equal to 1 based on mathematical definitions. Overall, the conversation reveals a mix of agreement and confusion regarding the concept of repeating decimals and their implications in mathematics.
  • #51
eNathan said:
Well that's just me theory, its not based on anything I have read.
No, it isn't, is it?
Mathematics news on Phys.org
  • #52
houserichichi said:
Zero times infinity means nothing.
Meaning what??
  • #53
gee this thread looks fun. my suggestion ius athat a proof requires a definition.
definition: .9999... is the smallest real number not smaller than any of the finite truncations of it.
Archimedean axiom: the numbers 1/(10)^n appraoch zero, as n goes to infinity.
corollary: .9999... = 1.
proof: 1 - .999...9, with n 9's, = 1/(10)^n. qed.
  • #54
dash00 said:
how about this , for simple- 1-0.9r does not = 0.
if 0.9r does equal 1, like you say, must the difference between them not be 0?
As often happens- simple, and wrong.1- 0.999... by any definition of base 10 notation that I know is equal to 0.
  • #55
Cute, but that isn't the "definition" of 0.999...
By definition of "base 10 notation" , 0.999... is the limit of the infinite series
0.9+ 0.09+ 0.009+ ... Since that is a geometric series it is obvious that
0.9999... = 0.9/(1- 0.1)= 1.
  • #56
Please don't jump down my throat too bad on this because I am just a kid who likes to entertain silly ideas, and to be honest I am a crappy math student, but does 0.9~ = 1 really make sense to say? I do believe that 0.9~ = 1, but I am unsure of whether 0.9~ falls under the definition of a real number or if it can be proven without using 0.9~ = 1. If it isn't, does the group it belongs to have the same order of infinity as R (to which 1 belongs to)? How then would an equivalence relation be constructed? Be nice please :smile:
Edit: Thanks to Hurkyl below for his last line. That was probably my biggest question on the topic.
  • #57
Actually, it is one of the ways people go about defining the decimal numbers. (The different definitions are, of course, equivalent)
My favorite definition of the decimals happens to state outright that 0.999... = 1.000... (and all similar equalities)
In this approach, the decimals are merely defined to be a sequence of digits, and the semialgebraic operations are defined on sequences of digits. You never ever talk about a single real number until you decide to prove the decimals are isomorphic to the reals.
  • #58
doesn't everyone get to give his own definitions? what simpler definition of .999... is there?
here are my notes from day one of a recent honors calculus class:
Math 2300H. Chapter One. What are real numbers?
Real numbers are the numbers used to measure lengths. (They were essentially invented for this purpose, hence this is the best way to understand them, although later it turns they can also be used to measure other quantities such as areas.) Imagine an ideal line, infinitely long in both directions, straight, and continuous without breaks or gaps. Fix a point to begin at, called 0 (zero), and fix another point to be called 1 (one), which defiens a choice of "unit length". Then there should be exactly one real number for every point on this line, such that the number measures how far that point is from the point 0, assuming the point 1 is one unit away. Positive numbers correspond to points on the same side of 0 as 1, and negative numbers correspond to those points on the opposite side of 0 from the point 1. Then how do we represent real numbers by symbols? And how do we add and multiply these numbers using those symbols? Possibly the best way is using decimals.
A finite decimal is a finite sequence of form a1a2a3...an.b1b2...bm, where each ai and each bj is one of the ten digits {0,1,2,3,...9}. A finite decimal corresponds to a point on the real line as follows. For example, 14.63 corresponds to the point constructed like this: first lay off 14 copies of the unit length, the first one being at 1, the second one (called 2) being one unit on the opposite side of 1 from 0, and the third one (called 3) on the opposite side of 2 from 1, and so on, until we come to the 14 th point (called 14). Then lay off another unit ending at 15. Then subdivide the interval between 14 and 15 into ten equal parts, with the end points of the 6th subinterval being called 14.6 and 14.7. Then subdivide that 6th subinterval again into ten equal parts and go out to the 3rd subinterval. The initial point of that subinterval is the point corresponding to 14.63. In this way one can assign to any finite decimal a point on the real line.
Not every point of the real line occurs as one of the points corresponding in this way to finite decimals however. For instance the point (called 1/3) lying one third of the way between 0 and 1 does not correspond to a finite decimal. It lies to the right of the all points corresponding to finite decimals of form { .3, .33, .333, .3333, .33333, ...}, but to the left of any point of form { .4, .34, .334, .3334, .33334, ...}. However since the points of form { .3, .33, .333, .3333, .33333, ...} get arbitrarily close to the point 1/3, any point to the left of 1/3 will lie to the left of one ofthe points { .3, .33, .333, .3333, .33333, ...}. For example if we take a point which is 1/1000 to the left of 1/3, then it will be to the left of the point .3333, which is within 1/10,000 of 1/3.
Thus 1/3 is “the leftmost point which is not to the left of any finite decimal of form { .3, .33, .333, .3333, .33333, ...}”, i.e. 1/3 is the “smallest number not smaller than any of the numbers { .3, .33, .333, .3333, .33333, ...}”, technically we say 1/3 is the “least upper bound (l.u.b.) of the numbers { .3, .33, .333, .3333, .33333, ...}”. Although 1/3 does not equal anyone of these finite decimals, this is a description of the point 1/3 in terms of the whole infinite sequence { .3, .33, .333, .3333, .33333, ...} of finite decimals. It is usual to replace the infinite sequence { .3, .33, .333, .3333, .33333, ...} of finite decimals simply by the one infinite decimal .3333333... (3’s continuing forever), sometimes denoted by .3333ä3... where the bar over the last 3 indicates infinite repetition of that symbol.
In this way every point of the real line can be described by either a finite decimal or an infinite decimal. I.e. given a point x on the line, to the right of 0 for example, to get the integer part of the decimal measure off copies of unit interval starting at 0, until the next unit interval will go past the point x. If x lies strictly between the 5th and the 6th point, for instance, then the integer part of the decimal for x is 5. Then subdivide that interval again into ten equal parts and see whether x lies exactly on one of the subdivision points. If it does lie on say the 2nd subdivision point, then x corresponds to the finite decimal 5.2. if x does not lie on one of the subdivision points but lies between say the 2nd and the third subdivisions points, then the second decimal approximation to x is 5.2. Continue in this way to subdivide and approximate x by decimals.
If eventually x lies exactly on some subdivision point then x corresponds to a finite decimal. if x never lies on any subdivision point, as was the case with 1/3, then x corresponds to an infinite decimal. Thus each point of the line can be represented by a finite or infinite decimal. We often call the finite ones infinite decimals also, where we assume they are made to look infinite by writing an infinite number of zeroes after they stop. This makes the language easier and we can just say “every point of the real line corresponds to an infinite decimal”. (Not all infinite decimals can be obtained in this way from points on the line. Try to convince yourself that this procedure will never lead to an infinite decimal ending in all 9's repeating forever.)
The other direction is harder, i.e. if we start with an infinite decimal, does it always correspond to a point of the real line? We could try to find the point, starting from the decimal as follows. If we have a finite decimal like 3.7 there is no problem, it is easy to find the corresponding point. Just go out to the fourth unit interval after 0, between the points 3 and 4, subdivide into ten equal parts and take the 7th subdivision point to be 3.7. But if the decimal is infinite, it is not so obvious. Say we have the decimal D = .12122122212222... Does this correspond to a point x?
Well first we subdivide the interval between 0 and 1 into ten equal parts and we consider the first subdivision point called .1. Then we know x lies to the right of .1. then we subdivide again and take the 2nd subdivision point in the subinterval, the point 1.2, and we know x lies to the right of that point. Continuing in this way we find an infinite number of points (if we live long enough, otherwise we must imagine it) and we know the point corresponding to x should lie to the right of all of them. But it should also be the closest point which is to the right of all of them.,
So we describe the point x corresponding to an infinite decimal D as “the leftmost point which is to the right of all points corresponding to finite decimal approximations of D”, i.e. x is the lub of all finite decimal approximations to D”. But how do we know there is such a point? We do not. But it seems plausible at least if the real line is truly supposed not to have any holes in it, so we take this as an axiom, or unproved fact about the real line. This is called the “least upper bound axiom”: For every infinite decimal, the sequence of finite decimal approximations has a least upper bound on the real line.
Stated as fact about real numbers, it is usual to assume it in the following more general form:
Least upper bound axiom: “If a set of real numbers is non empty and has an upper bound, then it has a least upper bound”.
This concept can be used to describe many familiar numbers and solutions to many problems:
Examples: (i) (assuming we know how to find the length of line segments and hence the perimeter of a polygon), the number <pi> can be described as the lub of the lengths of all polygons inscribed in the unit semi circle. I.e. if you inscribe any polygon in the unit semi circle, the perimeter of that polygon will not be greater than <pi>, but if you take a polygon with small enough sides, its perimeter will be as close as you like to the number <pi>, i.e. <pi> is the smallest number not smaller than any of those perimeters. But how can we calculate this number, i.e. how can we find some of its finite decimal approximations?
(ii) If we know how to find the area of a triangle and hence of a polygon, we can define the area of a circle as the lub of the areas of all inscribed polygons. But how can we show that this area is actually equal to <pi>r^2, where <pi> is defined above and r is the radius of the circle?
(iii) If we want to know what is meant by the value of an infinite sum like 1 + 1/2 + 1/4 + 1/8 + 1/16 + ..., we can say it is the lub of all the finite “partial” sums { 1, 1 + 1/2, 1 + 1/2 + 1/4, 1 + 1/2 + 1/4 + 1/8,...}. But how can we actually calculate this sum, i.e. can we find this least upper bound?
(iv) If we want to find the slope of the parabola y = x^2 at the point (1,1), we can say it is the lub of the slopes of all the secant lines drawn through points of the form (x,x2) and (1,1) where x < 1. But can we actually calculate this slope?
(v) If we want to describe the “square root of 2” we can say it is the lub of all finite decimals whose square is less than 2. (Since the square of a finite decimal is never 2, as you can easily check, the square root of 2 is going to be an infinite decimal, and it is not so easy to even tell how to square an infinite decimal. In fact the only way we have to do that, is to say that the square of an infinite decimal is the lub of the squares of all its finite decimal approximations!) Can we compute, or at least approximate this infinite decimal?
(vi) The cosine function, in radians, is defined as follows: given a positive real number t, measure off an arc of length t along the unit circle, starting at (1,0) going counterclockwise. Then the x coordinate of the point reached is cos(t), and the y coordinate is sin(t). But can we actually calculate say cos(1)?
All these problems have answers provided by calculus. For example, cos(t) is given by the infinite formula cos(t) = 1 - x^2/2! + x^4/4! - x^6/6! ±..., where n! = “n factorial” = (1)(2)(3)...(n) is the product of the numbers between 1 and n. Cos(t) can be computed to any desired degree of accuracy by taking enough terms of this formula. For example, cos(1) is the least upper bound of the sequence of approximations
{1-1/2, 1 -1/2 + 1/24 - 1/720, ...} formed as above by taking finite partial sums ending in a negative term.
Actually computing answers to problems
It is one thing to describe the answer to a problem as a lub of some set of numbers, but it is usually more desirable to actually find the answer in a nice simple form, or at least approximate it as well as we want. This is often not so easy, and may depend on the problem at hand. Thus there are two parts to solving most problems:
1) Describe the solution in precise terms, even if abstract ones.
2) Actually calculate that answer, say as a decimal, or at least show how to find as good a finite decimal approximation as we want. Sometimes we calculate the answer in terms of some other “known” number, such as when we say the area of a circle is <pi>r^2, even if we may not know exactly how to calculate <pi>.
Even step 1) above has two parts: 1a) decide whether the problem has a solution, and if so, 1b) describe it. For example, if the solution of a problem is defined as the lub of some set of real numbers, to show it exists all we have to do by the lub axiom is prove the set is non empty and has some upper bound.
For example, to prove the infinite sum
1 + 1/2 + 1/4 + 1/8 +... has a finite value, described as the lub of all the finite sums }1, 1 + 1/2, 1 + 1/2 + 1/4, ...} we must show there is an upper bound to these finite sums. But it is not hard to see these finite sums are never greater than 2, so 2 is an upper bound. Then the axiom tells us there is a least upper bound, which in fact turns out also to be 2.
The finite partial sums of the sequence 1 - 1/3 +1/5 - 1/7 + 1/9 - 1/11 ±... are bounded above by 1, hence have a least upper bound, WAIT! OOOOPS! The sum of this sequence is not the lub of all those finite partial sums since the minus signs cause the finite sums to go back and forth on both sides of the actual infinite sum. (Now is when we need the more general notion of “limit” instead of lub.) Anyway we can finesse this and say (correctly) the value of the infinite sum
1 - 1/3 +1/5 - 1/7 + 1/9 - 1/11 ±... is the lub of the finite partial sums
{1 - 1/3, 1 - 1/3 +1/5 - 1/7, 1 - 1/3 +1/5 - 1/7 + 1/9 - 1/11, ...}.
I.e. if we are careful to always take partial sums which end in a negative term then they are actually smaller than the infinite sum we are trying to define. Thus we can say that 1 is an upper bound for THESE finite sums so there is a lub. But what is the lub ? It turns out to be <pi>/4, rather amazing. In the case of the infinite sum 1 + 1/4 + 1/9 + 1/16 + 1/25 + ..., where the nth denominator is the square of the integer n, it is not even so easy to find any upper bound at all (until you know about how to compute area formulas by integral calculus). The least upper bound of these finite sums turns out to be <pi>^2/6, incredibly.
Not only that, Leonhard Euler knew this before the invention of calculus! Euler also knew how to evaluate the sum
1 + 1/16 + 1/81 + 1/ 243 + ..., where the nth denominator is the 4th power of the integer n, namely <pi>^4/90, and he knew many more such even power sums and included them as essential material in his famous “PRECALCULUS” book! However I do not believe even today that anyone knows the value of 1 + 1/8 + 1/27 + 1/64 +... where the nth denominator is the cube (or any other odd power) of n. I.e. these finite sums have an upper bound, but no one knows the least upper bound.
Differential calculus is about how to: 1) describe the answer to the slope problem for the graph of a function in terms of "limits", and 2) how to actually calculate these limits to calculate the slope of y = f(x) at least as well as we know how to calculate f(x) itself.
Thus for a nice easy function like a polynomial f(x) = 3x^2-6x+9, we should be able to calculate the slope also as a polynomial. but for a trigonometric function like f(x) = cos(x) we will only be able to calculate the slope function as another trigonometric function. (In a later math course, when we know the infinite formula given above for cosine, we will also get an infinite formula for the slope of the graph of cosine.) For a more difficult function like 2^x, or log2(x) (the logarithm “base 2” of x), the derivative will be also a challenge. You have probably heard of "natural logarithms", or logarithms to the base "e". We will define this magic number "e" as the unique base such that the slope of the graph of y = e^x at the point (0,1) equals 1. But then what is the number e? calculus can be used to give a very simple formula for the function e^x = 1 + x + x^2/2! + x^3/3! + x^4/4! +..., and this can be used to approximate e very well, by plugging in x = 1 and adding up a few terms. It turns out e is between 2.71828 and 2.71829.
Rather than continuing to restrict ourselves to the concept of least upper bounds, it is more useful to use the concept of “limits”. These are harder to define precisely, and harder to prove the existence of, but easier to deal with intuitively. Thus in practice we will find it convenient to use this concept, since there are some good methods for actually computing these “limits”, using the notion of a “continuous function”. This is our next topic of study. For example, if we approximate the tangent line to y = x^2 at (1,1), by the secant line through the points (1,1) and (x,x^2), where x < 1, we can describe the slope of the tangent line as the lub of the slopes of all these secant lines, i.e. the lub of all numbers of form (x^2-1)/(x-1) where x < 1. Simplifying the fraction gives x+1, and if x is any number < 1, the smallest number not smaller than any of the numbers x+1, is 2.
We might wonder though whether we get the same slope if we approximate from the right, looking at numbers of form (x^2-1)/(x-1) where x > 1. These simply again to x+1, for x > 1, but this time the slope of our curve should be less than all these numbers. Thus we can describe our slope as the smallest number not smaller than any of the numbers x+1 for x > 1, i.e. as the greatest lower bound (glb) of these numbers. this is again 2.
However it is simpler to say that the slope of the tangent line is the number being approximated by the numbers (x^2-1)/(x-1), when x is approximately 1, without worrying about whether the approximation is too small or too large. Thus again we are asking what number is approximated by x+1 when x is approximately 1. It seems clear that when x is approximately 1, then x+1 is approximately 2. Of course since we have not precisely defined what we mean by “approximately”, you may not feel this is so obvious. I will try to give you a feel for how to compute these limits, and will also give the rigorous precise definition of limit.
  • #59
No offense, mathwonk, but I didn't read that long page of notes that was just posted above this. I have my own pile of notes to review for finals...
However, it seems that a lot of confusion has arisen over this problem when it really shouldn't be necessary.
0.9999 "recurring" (or better written, 0.\overline{9}) is notation that signifies, as HallsofIvy already mentioned, the limit of a sum. Specifically:
0.\overline{9} = \lim_{n\to\infty}\sum_{k=1}^{n} \frac{9}{10^k} = 1
I wrote it out like this because it's the first way of writing it out that came to mind, and it's also the way that HallsofIvy was writing it down, basically. You can rearrange things to create a geometric series and then relatively easily evaluate the quantity.
The limit of that sum equals 1. If you write down a bunch of nines after the decimal, you've written a number that is very close, but not equal to 1. If you write down a bunch of nines and indicate that they repeat forever, then you've written down is notation for that infinite sum, which is a limit that is equal to 1.
I think people are confused because some don't understand that 0.9999 "recurring" is just notation for a limit.
EDIT: And for the record...I didn't follow the original poster's reasoning at all. How does 1.3 * 3 = 0.333... * 3 ? I'm assuming that they messed up and meant to put a / in instead of a . (period). In any case, that certainly isn't a proof.
  • #60
How would you use limits to define recurring numbers such as 0.1234512345r?
  • #61
gee, what do you think the definition of the limit of a series is anyway?
the limit of a series of positive terms is most naturally and simply defined to be the lub of the sequence of partial sums. that is exactly the definition i have given only in simpler terms.
i.e. look: the limit of a series is by definition the limi tof the sequence of partial sums.
now if the series has only positive terms, as in this case, then the seuence of partial sums is increasing.
so we only need the definition of a limit of an increasing sequence.
there is a trivial theorem that the limit of an increasing sequence is the lub of that sequence,
so a simpler definition of the limit of an increasing sequence, and hence of a series of positive terms, is simply as the lub of the sequence, or of the sequence of partial sums in the first place.
anyone who understands anything about convergence would immediately realize this.
the general definition of limit of a sequence, or series is more difficult for young students, and is not needed in this trivial case.
thats why i explain limits in easy stages in my class. at least i am not surprized that someone doesn't want to take time to read my notes. it takes effort to learn something.
by the way, how do you KNOW the sum of the geometric series 1+r + r^2 +... is 1/(1-r)? [when |r| < 1).
duhh, you prove it by showing that 1/(1-r) is the lub of the sequence of partial sums!
or you could just memorize it if you do not want to understand anything.
  • #62
0.\overline{12345} = \lim_{n\to\infty}\sum_{k=1}^{n} \frac{12345}{10^{5k}} = \frac{12345}{99999}
  • #63
Touche INCREASING THE LENGTH OF THE MESSAGE TO MEET OBLIGATORY LENGTH
  • #64
or
\sum^{+ \infty}_{n=1} \frac{12345}{100000} (\frac{1}{100000})^{n-1} = \frac{12345}{100000} + \frac{12345}{100000}\frac{1}{100000} + \frac{12345}{100000}(\frac{1}{100000})^2+ ... + \frac{12345}{100000}(\frac{1}{100000})^{n-1} + ... = \frac{\frac{12345}{100000}}{ 1 - \frac{1}{100000}} = \frac{4115}{33333}
  • #65
come on. these are trivial facts.
  • #66
I'll assume that was directed at me.
Why so hostile? I apologize for not reading your intimidatingly long block of text, but frankly, I figured it would be a better use of my time to simply indicate that I hadn't and then include my own short reply. If you find this offensive, then ignore my post. You have to understand, it's finals week here, and I really have no desire to read another person's class notes when I have my own that I'm reading (right now, in fact).
Additionally, what gives you the idea that I simply memorized the formula for geometric series without understanding anything? Is it because I didn't include it in my previous post? I'm sure you're aware of the fact that if you include every proof for every single thing that needs to be proved in every statement, you'll have an unnecessarily long explanation. You don't need to re-invent the wheel. The topic wasn't "How do you evaluate a geometric series?"; it was "Why does 0.9999 recurring equal 1?". I was not interested in teaching people what a geometric series is or how to evaluate one, and judging by your previous posts, neither were you. You still haven't posted a proof of why a geometric series equals 1/(1-r). If you want to, go ahead, but I won't read it. That's what my class notes are for.
Just because I chose not to read your post is no reason to get so hostile. You never once said that your notes directly addressed the issue we were discussing, and come on, that's a lot to read for something that requires a relatively simple explanation. If you think my explanation is flawed in some way, then please, by all means, correct it.
Now if you'll excuse me, I have things to study for.
  • #67
I believe that can be written as:
12345 \Sigma_ {n=1} ^{\infty} 10^{-5n}
  • #68
never mind, night owl, everyone takes whatever instruction they are ready to absorb.
  • #69
we cannot prove, or rather justify that 3*0.33333... = 0.999999... isn't it?? in arithmetic multiplication, we start multiplying from the rightmost and here...we can't reach the righmost. we are dealing with infinity here(infinite number of digits) and arithmetic fails with infinity. Maybe my thinking is a bit too "simple" for u all...but i don't know how u can say 3*.3333... = .9999... arithmetic cannot be used as a proof for a theorem or a result ... best to use the word "justification" ;) cheers!
  • #70
This means
3(\frac{1}{3})=1
It is often better to think of decimal expansions as ways to write numbers, not as strange and mysterious objects.
.999999999... is just one possible way to write 1 here are a few others
\frac{151}{151}
\frac{d}{d(x^2)}x^2
\lim_{n\rightarrow\infty}\frac{n^2+1}{n^2-1}
\int_0^11dx
  • #71
waterchan said:
1/3 = 0.333...
1 = 0.999... also works.
Doesn't this merely shift the punchline of the proof, so to speak? Doesn't one have to prove 1/3 = 0.333... ? How's that easier than proving 1 = 0.999... directly?
Either I am the smartest one in this bunch or I missed the point of a lot of the postings here. :redface:
  • #72
I am not going to justify the post made there, but many people find it easier to comprehend the fact that 1/3 = 0.3333... than 1 = 0.9999...
Why??
Divide 1 by 3 using long division and it seems apparent (to them) however there is no such process to get 0.99999... from 1, so obviously they think its an error. However naive this argument may sound, i believe it appeals to their thought process and hence 1=0.99999... becomes a much talked abt issue in many forums.
No wonder, matt wants it to be immortalised as an FAQ :biggrin:
-- AI
  • #73
TenaliRaman said:
... however there is no such process to get 0.99999... from 1, so obviously they think its an error. ... -- AI
The closest expression I can come up with is: 1 = 0.999... * 1.000...
Or 1/1.000... = 0.999...
It's sort of like saying "1 is the geometric average of 0.999... and 1.000..."
Example:
Suppose a population grew -0.000... in the first year and +0.000... in the second year; what is the cumulative growth rate (CGR) in two years?
1 + CGR = (1-0.000...)(1+0.000...)
1 + CGR = 0.999... * 1.000...
Intuitively there was zero growth, so CGR = 0.
1 = 0.999... * 1.000... There.
If one is prepared to accept the CGR = 0 intuition then it becomes possible to show 1 = 0.999... directly:
1 + CGR = (1-0.000...)(1+0.000...) = 12 - (0.000...)2
Intuitively CGR = 0 so,
1 = 1 - (0.000...)(0.000...) = 1 - 0.000... = 0.999... So there!
  • #74
Hello enumaelish, if cgr=0 intuitivley, you will not be able to get
  • #75
Can you elaborate, even it's along the lines of "obviously you haven't had your 3rd cup of coffee this AM, because ..."?
  • #76
Why is this a five page thread? What's wrong with the three-line epsilon proof:
\begin{align*}<br /> &amp;\mbox{For } \epsilon &gt; 0, \exists n &gt; \log ( \epsilon^{-1} ) &gt; 0 \mbox{ such that} \\<br /> &amp; |1 - \sum_{k=1}^{n}9*10^{-k} | = 10^{-n} &lt; \epsilon \\<br /> &amp; \mbox{Therefore: } 0.99\overline{9}\equiv \lim_{n \rightarrow \infty} \sum_{k=1}^{n}9*10^{-k} = 1 \end{align}
Is anyone not happy?
  • #77
Not creative enough! :smile:
  • #78
Anyone who's math-literate enough to read that wouldn't need it in the first place.
  • #79
lurflurf said:
This means
3(\frac{1}{3})=1
this is exactly what we have 2 prove isn't it!? i liked the epsilon proof...it involed no arithmetic that's why lol ;) but see...if u can convince urself that 3*0.3333333... = 0.99999999... then u mite as well convince urself that 1-0.9999999... = 0.00000000.. this wud become a shorter *proof*
  • #80
Oh! But there will be a 1 at the end :-p
-- AI
  • #81
-- AI
Yes at the end of an infinite number of 0s :devil:
  • #82
how about just this simple one with arguably less demands on the idea of "infinity":
<br /> \begin{align*}<br /> x &amp;=&amp; 0.999\overline{9} \\<br /> 10x &amp;=&amp; 9.999\overline{9} \\<br /> 10x-x &amp;=&amp; 9 \\<br /> 9x &amp;=&amp; 9 \\<br /> x &amp;=&amp; 1 \\<br /> \end{align}<br />
  • #83
and you've proven that arithmetic is well defined on strings of recurring (or any infinitely long) decimals have you?
  • #84
i've opened a pandora's box haven't i...
  • #85
More like a Russian doll, IMO.
  • #86
gingkonut, that was the arguemnt i was shown in 8th grade and i always remembered it and liked it. that's the right level for it, kids who don't need rigor, but enjoy being amazed.
  • #87
There is no harm in using white lies when explaining maths, often it is the best way of getting across information. And the multiplying by ten thing is a good example: we know what *ought* to happen when we do it, and as mathwonk says that is often good enough. the problem comes from the die hards who refuse to accept this *motivational* reason and then dismiss the full on proof with all the details and carefully laid out definitions (I would suggest because they do not understand the formality of mathematics). hence in this case (and this is only my opinion now because of the attitudes displayed repeatedly in this forum where the audience is of all levels) i tend to immediately go for the overkill approach since there is a good chance the reader is not a kid to be amazed.
  • #88
Does anyone have any links to the original discussion from battle.net? Thanks in advance.
  • #89
x = 0.9999
9x = 9
11x = 10.9999
2x = 1.9999?
  • #90
bao_ho said:
x = 0.9999
9x = 9
11x = 10.9999
2x = 1.9999?
Starting from x= 0.9999, how do you get 9x= 9? According to my calculator 9x= 9(0.9999)= 8.9991! (And 11(0.9999)= 10.9989, not 10.9999.)
Anyway, why are you talking about 0.9999? Everyone else is talking about 0.99999... (which is easily shown to be equal to 1.)
  • #91
J33Z these threads are always poping up, well I think this thread was pulled up from a while ago but...
This is my conclusion
1 - .999~ = 000 \infty
To say that 1 != .999\infty is to say that x * 000\infty!= 0
Sorry I forgot the latex code for <> or !=, what is it again :rolleyes:
  • #92
\infty is undefined, so i would have to say that is completely wrong
  • #93
Well, he is completely wrong, but \infty is well-defined (you're wrong about that), but arithmetic on \infty is not, so \infty \cdot 0 is what's undefined.
  • #94
Your looking for \neq
Would you like to make any mathematical sense of that? Or should I not bother asking?
  • #95
here we go again
if you were to perform the following operation
1 - .9 you would get .1
if you were to do
1 - .9999999999 you would get .0000000001
Now if you were to manually try to subtract .999 \infty from 1, you would get 000000000 for infintiy! hence,
1 - .999 \infty = 000 \infty Make sense? So to say that 1 - .999 \infty \neq 0 would also mean that that the infinite row of 0's (that you get from 1 - .999~) actaully doesn't equal 0! Which is false.
Now why did I present it as 0x != 0? Because there are an infinite number of zero's, which I called variable 'x'. Correct me if it's not proper to present infiity as a x. What I wrote was
x * 000\infty \neq 0
When what I should have wrote was
000\infty \neq 0
By the way, is 0 \cdot \infty really undefined? :rolleyes: news to me, I always assumed it was 0.
  • #96
In calculus when evaluating limits you can get to a point like infinity times 0 and at those times it is considered indeterminate. Thus you invoke L.H...
But without knowing how you arrived at infinity times 0 I don't think anyone can really call it undefined. As far as ordinary arithmetic goes I don't see how this would be a legal operation.
Regards,
I am not an expert so please go easy if I made an error... :smile:
  • #97
eNathan said:
here we go again
if you were to do
I see, the problem is we were misreading your (incorrect) notation. It's 0.999... or 0.\overline{9}, not .999 \infty (which looks like an attempted multiplication).
Yes, arithmetic on infinity is not defined. If you attempt to define it, you get contradictory results like
\lim_{x \rightarrow 0} \frac{1}{x} \cdot x = 1
\lim_{x \rightarrow 0} \frac{1}{x} \cdot 0 = 0
This probably already occurred a dozen times in this thread, I'm too lazy to look for precedents.
Will this thread ever die?
  • #98
then define \infty
  • #99
then define \infty
The greatest number of all real numbers. Obviously, you won't be able to find what number actually infinity is.
@eNathan:
How come 1 - 0.99... = a row of 0s? Where is the little number 1.
I agree 0.99... = 1, but your proof does not make much sense to me.
Viet Dao,
  • #100
1 / 9 = 0.1111recuring
0.9999recuring / 9 = 0.1111recuring
then 1 = 0.9999recuring
