Undergrad A spaceship traveling close to the speed of light sending some data....
A spaceship traveling close to the speed of light sends data to stationary observers, with time dilation causing discrepancies in received data timing. For every second on the spaceship, ten seconds pass for stationary observers, but the actual reception time depends on the spaceship's direction relative to the observers due to the relativistic Doppler effect. If the spaceship moves towards the observers, data pulses arrive more frequently; if moving away, they arrive less frequently. The discussion also touches on the complexities of acceleration and the physical limitations of achieving such speeds, particularly regarding the effects on the human body. Overall, the conversation highlights the intricate relationship between speed, time, and perception in the context of relativity.
radres
A spaceship traveling at speed of light close to speed of light (wrt inertial reference frame) sending some data every second on their clock to people who are stationary (wrt inertial reference frame). At what time these people would receive this data on their own clock?
Let's say for a second passed in the spaceship, 10 seconds passes for the stationary people.
Sorry if this makes no sense, I don't have a good understanding of relativity, I only know that at high speeds, the time is slower than the people at low speeds.
radres said:
A spaceship traveling at speed of light (wrt inertial reference frame)
Assuming your spaceship has mass, it cannot do this.
If you exchange "at the speed of light" for "close to the speed of light", it will depend on whether the spaceship is moving towards or away from the people. The relation will be given by the relativistic Doppler formula.
Likes radres
It's impossible to describe something with mass moving at the speed of light in relativity. However, you specified a tick rate ratio of 10:1, which implies a specific speed. If I see you traveling at speed ##v## then I will determine your clocks to be ticking once every ##1/\sqrt {1-v^2/c^2}## seconds.
As Orodruin says, when the people who are stationary in the inertial reference frame receive the pulses depends on where they are. The emitting ship is moving - so if it is coming towards you the second pulse does not have as far to travel as the first, so pulses come in squashed together. If it is moving away then the pulses come in spread apart. The relevant formula is that if the pulses are emitted with frequency ##f## (once per second, for example) then they are received with frequency ##f'=f\sqrt {(c+v)/(c-v)}##. Note that ##v## can be positive ot negative and that I'm assuming that the ship is coming straight towards or straight away from the observer.
If the receiver corrects for the travel time of light then they will calculate that the pulses were emitted once every ten seconds.
Note that the situation is symmetric. The "moving" ship may regard itself as stationary and the "stationary" ship as moving, and will be able to carry out the same measurements and calculations.
Likes radres
what if the ship is moving in circles around the receiver and keeping the radius with the receiver always constant, can we forget about doppler effect? would the constant velocity change of the ship affect the calculations?
In that case, yes, the receiver would receive pulses every ten seconds. Note the ##v^2## in the time dilation formula - it's only the magnitude of the velocity that matters.
Note that this situation is no longer symmetric. The ship moving in circles would receive ten pulses per (its) second from the stationary ship was emitting once per second by its clock.
Note that the thrust or time requirements to do this experiment are likely to be absurd.
Likes radres
Note that you have to follow an orbit e.g. around the solar system with a huge radius:
Orbiting the solar system (never mind the earth) at a sensible radius would also be impossible without crushing every bone of the space travellers: ##v^2/r=10## g at ##10^{12}## km ! That's 6000 astronomical units, less than an hour per round trip (pluto has 40 AU and 248 year) -- all calculated nonrelativistically, of course :smile:.
yes I see that but we are just doing some mental experiments and we happen to have all the tools and technology to achieve that :) also keep in mind that if you accelerate every atom of your body at the same rate no acceleration can crush your bones, it is the difference of acceleration throughout the body that crushes bones.
True as far as it goes. But we have no way to do that and you will be crushed. Also, accelerating all parts of your body at the same rate is a problematic statement in relativity. The different parts of your body don't agree on what "the same rate" means due to time dilation and the relativity of simultaneity. The end result is painful.
Care to hint at a way to accelerate every atom of an object in a practical manner ?
I surely would care if I had any idea how. Again, we are not talking in terms of today's technology it's just mental experiments.
As noted above, you can't do so at the same rate, since "at the same rate" is an incomplete sentence.
It's fine to think about what happens in extreme circumstances and leave the details to the engineers, so to speak. It's important, though, to be aware that there can be complications that you can't handwave away.
Likes BvU
What about if we drilled a hole to the center of a planet, having the right size and mass, and then dropped an astronaut in there.
His legs would be subject to less acceleration than his head, seen from the perspective of an observer at rest to the planet. He would be shrinking as predicted by SR (length contraction).
If the size and mass of the planet was chosen properly, one might be able to calculate that the astronaut won't be able to register any acceleration at all, as in his body registering a change of structure due to pressure/forces he would be subject to - or "feeling" acceleration as some loosely describe it.
(Clocks that were formerly synced, located at the astronaut's legs and head, before he gets dropped into the hole, would go out of sync once he would be in free fall, but devices trying to measure acceleration by measuring a change in the (space) structure, like a mass connected to a spring, should fail, or so i believe)
Contrary to letting the astronaut drop from orbit onto the planet surface, where his legs would be subject to more acceleration than his head seen from the perspective of an observer on the planet surface, hence the astronaut's body would have counter a force trying to elongate him.
Just a few thoughts. I did not really think this out or tried to figure out how one would calculate this from the perspective of the astronaut and what kind of mass/size the planet would have to be.
Well, this isn't special relativity any more.
Given that you are relying on careully chosen tidal forces to do your work, I wouldn't bet on being able to use SR concepts like length contraction - certainly not without careful calculation beforehand.
I think what you are trying here is a variant on Bell's spaceship paradox. In the "vanilla" version of that, two ships initially at rest and joined by a string undergo equal constant proper accelerations. According to the original rest frame of the ships, the string ought to length contract and break. But in the frame of the ships, why would the string break? It isn't length contracting. The solution is to realize that there is no "frame of the ships" - due to the relativity of simultaneity the two ships aren't at relative rest from either of their perspectives. That was the kind of thing I (and Bell, I think) was warning that you can't handwave away.
But you could certainly set up a variant where the two ships' accelerations are carefully chosen so that the separation between them (as measured in their initial rest frame) decreases at the same rate as the string length contracts. But that isn't equal acceleration in the initial rest frame and I have my doubts that it amounts to equal acceleration in anything other than a very carefully picked non-inertial frame.
I'd also suggest that this is far enough off topic to be another thread if you want to continue the discussion.
With an orbit radius of 6000 au the required centripetal force is pretty much the same for all your atoms.
Born rigid acceleration achieves this. Indeed the proper acceleration varies continuously along the rockets and string such that all neighboring distances in MCIF frames remain constant. Obviously, in the initial inertial frame, the rockets get closer together.
Herglotz-Noether theorem puts severe constraints on Born rigid acceleration, but it is quite generally possible if you exclude rotation.
Agreed. But OP was originally talking about the same acceleration being applied to the whole body. The proper acceleration clearly isn't the same along the length, and all I was noting was that I suspect that the only coordinate system where the coordinate acceleration is equal along the length is one constructed to achieve that.
I believe you're asking about what physicists would call the transverse doppler effect. The short answer is yes, see the wiki_article for more details.
Wiki said:
The transverse Doppler effect is the nominal redshift or blueshift predicted by special relativity that occurs when the emitter and receiver are at the point of closest approach. Light emitted at closest approach in the source frame will be blueshifted at the receiver. Light received at closest approach in the receiver frame will be redshifted relative to its source frequency.
If the space ship, considered to be small and pointlike (so we don't have to talk about what happens if it's not) is accelerating in a circular orbit and broadcasting a signal (via radio or laser, i.e. some known physical means that sends signals at the speed of light), said signal will be red-shifted when it's received by a stationary observer at the center of the space-ships circular orbit. This means that the received frequency will be lower, and if the space-ship was sending a video signal, the video will play out in slow motion.
If the receiver isn't at the center of the circular orbit, the velocity won't be transverse anymore, and you'll need a different more complicated calculation which basically involves a full doppler effect calculation. The distance from the receiver to the space-ship will only be constant if the receiver is at the center of the circular orbit.
Some experimental tests of this have been done (but with atoms, not spaceships), the results are in agreement with special relativity.
This situation appears analogous to the one in Schwarzschild spacetime, where the far away observer (who is in free-fall) sees the shell observer close to the black hole (who accelerates in his direction) redshifted. If true and assuming constant distance during the measurement of the redshift then an observer who hasn't any additional information couldn't distinguish between the two scenarios: If the source accelerates in a circular orbit with him at the center in flat spacetime or if it has constant r-coordinate in Schwarzschild spacetime,right?
Given Ashby's analysis of the orbiting clocks in the GPS system, I'd say no. See for instance
Relativity[/PLAIN] in the Global Positioning System.
I'd say more, but I'm pressed for time.
Although this "spaceship thought experiment" is included in most popular books on Special Relativity (SR) it does not demonstrate time dilation due to relative speed. If the spaceship were approaching Earth the data would arrive faster then once per second due to the decreasing distance the signal has to travel. SR never predicts "time contraction".
Time dilation is due to light's universal measured speed. (See "Einstein's light clock" for explanation.) If any thought experiment lacks the universal measured speed of light as a necessary condition -- as yours doesn't -- time dilation cannot be assumed. Many books written by "authorities" on SR contain similar thought experiments which are really unrelated to SR.
To test whether an example of time dilation is legitimate, reverse the situation. If time intervals get shorter it's not a demonstration of light's universal measured speed, but only of light's finite speed. The two are often conflated.
This is the Doppler effect, not time dilation. They are related but not the same. Time dilation is what you get when you take this direct observation and correct for the travel time of the light signals in order to calculate the rate at which they were emitted by the source. That rate will still be slower for an approaching source; the "slower" is time dilation.
No, but it does predict exactly what you describe for the Doppler effect from an approaching source.
You will need to give specific references for this very strong claim.
An article celebrating the centennial of SR in a 2005 issue of “Discover” Magazine cited an example of time dilation using a moving railroad car and a flashlight. In the example, the conductor flashed a beam of light from the rear of the moving car toward the front. As the beam traveled forward with respect to the train’s direction, the front of the car receded from the oncoming light. Therefore, from the point of view of a trackside observer, the light took longer to traverse the moving car than it would have had the train been standing still on the tracks. Considering the time it took the light to make the journey as one unit of time on the train, the trackside observer would interpret the train’s “clock” as running “too slow”.
But again, this example was carefully chosen to illustrate the desired point. Had the conductor flashed the light backward with respect to the train’s motion, the forward-moving rear of the car would have intercepted the oncoming light sooner than it would have were the train motionless on the tracks. In this case, the trackside observer would see the light taking a shorter time for the experiment, and would interpret the train’s “clock” as running “too fast
Likes PeroK
Yes, but Discover magazine is hardly a reliable source for these matters. You won't find this sort of error in any serious textbook.
Fyi, this would probably not be an acceptable source here on PF; we want to see textbooks or peer-reviewed papers. The moderators would have to look at it to make a determination.
That said, your criticism of the article's argument is incorrect; the argument, at least as you present it here, is wrong, but not for the reason you give. See below.
Yes; and what this demonstrates is relativity of simultaneity.
No, he would interpret it as relativity of simultaneity: light beams which would reach the ends of a motionless train simultaneously--or, equivalently, would reach the points on the track which would mark the ends of a motionless train simultaneously--do not reach the ends of a moving train simultaneously.
So a proper criticism of the argument, at least as you are presenting it here, is that the experiment is not about time dilation at all; it's about relativity of simultaneity. Neither the "forward" nor the "reverse" aspects of the scenario have anything to do with time dilation. To demonstrate time dilation, you would need a light pulse that goes out and comes back, as in a light clock, or some equivalent way of comparing clock rates.
To know whether the actual article is in fact making this mistake, I would have to see the article itself. It's quite possible that it is, since Discover magazine is not exactly a gold-plated source for relativity physics; but it's also possible that you are misinterpreting the argument given in the actual article.
I'll repeat the request for a reference. Not because I'm challenging you, but rather because I really do want to understand the issue.
Okay, but popularizations of SR are almost always written by physicists with an expertise in SR, whereas Discover Magazine articles are usually written by people who are writers, not experts in SR.
Also, a reference includes enough information for us to find the article you're referring to.
How about "The Universe and Dr. Einstein" by Lincoln Barnett with a forward by Dr. Einstein himself? Serious enough for you? In Chapter 6, using the train-and-lightening thought experiment, he claims that the observer riding at the midpoint of the train will see the forward strike before seeing the rear strike. Not so. Since the train is an inertial reference frame it can be considered "at rest" while the countryside rushes past. SR says that the measured speed of light is the same for all observers. This includes the observer on the train. It is the trackside observer who sees the front strike reaching the train observer first, not the train observer himself.
This isn't the example of the error I originally posed, but it is another false conclusion from a "serious" source.
No it isn't. It is you who are misinterpreting things. You need to be careful about specifying in what frame the lightning strikes are simultaneous. You cannot just say "simultaneous" without any qualifier that tells you what frame they are simultaneous in. If they are simultaneous in the ground's rest frame, the observer on the train will see the front strike first. This must be true in all reference frames and since the speed of light is the same in all directions, the strikes must therefore occur at different times in the train's rest frame.
If the strikes are simultaneous in the train's rest frame, then the ground observer will see the back strike first.
Likes PeroK
The sequence with which an observer sees (with his eyes) a set of flashes is an invariant physical fact. All observers agree on it. If two strikes are simultaneous in the trackside observer's frame then it will be a physical fact of the matter that the midpoint observer on the train will see the front flash first.
The two observers can and do account for that fact in different ways. The train observer will say that it is because the flashes were not simultaneous. The trackside observer will say that it is because the train observer moved toward one flash and away from the other.
Likes PeroK
But you've yet to establish your first claim that there was a false conclusion from a serious source.
It could very well be that the the writer of the Discover article made an error in his explanation of time dilation, as you originally claimed. But we don't know.
In your second claim about the relativity of simultaneity it is you who has made the error. It's possible for those two events be simultaneous in either frame, but not both. Because the two frames are equivalent.
This is my last response. Obviously, you are simply bent on being argumentative. If you read my description you will see than I never used the term "simultaneous'. I made quite clear the difference between what the train observer sees and what the trackside observer thinks the train observer sees. In fact, if you read the book you will see that the author made exactly the same mistake you falsely accuse me of making. "A thunderstorm breaks, and two bolts of lightning strike the track simultaneously at different points."
That's all I have to say. I think you just want to argue. I don't. Adios.
  • · Replies 65 ·
11K
  • · Replies 67 ·
  • · Replies 42 ·
  • · Replies 34 ·
  • · Replies 18 ·
  • · Replies 25 ·
