A spaceship traveling close to the speed of light sending some data....
The discussion revolves around the implications of a spaceship traveling close to the speed of light and the effects of relativistic physics on time perception and data transmission between the spaceship and stationary observers. It explores theoretical scenarios involving time dilation, the Doppler effect, and the challenges of acceleration in extreme conditions.
  • Some participants assert that a spaceship with mass cannot travel at the speed of light, and the time dilation effect means that for every second on the spaceship, ten seconds pass for stationary observers.
  • Others propose that the reception of data pulses depends on the relative motion of the spaceship towards or away from the observers, suggesting the use of the relativistic Doppler formula to calculate the frequency of received signals.
  • A participant points out that if the spaceship is moving in a circular orbit around the observer, the Doppler effect may not apply in the same way, but the time dilation would still result in the observer receiving pulses at a different rate.
  • Concerns are raised about the physical feasibility of maintaining such orbits and the potential effects of acceleration on the human body, with some arguing that if all parts of the body could be accelerated uniformly, it might mitigate harmful effects.
  • Another participant introduces a thought experiment involving dropping an astronaut into a hole drilled to the center of a planet, discussing how different parts of the astronaut's body would experience varying accelerations and the implications for relativity.
Participants express a range of views on the implications of relativistic effects, with no consensus on the feasibility of the proposed scenarios or the specifics of acceleration and its effects on the human body. The discussion remains unresolved regarding the practical applications of these theoretical ideas.
Limitations include the assumptions made about the spaceship's mass and speed, the complexities of acceleration in relativity, and the speculative nature of the thought experiments presented. The discussion also highlights the challenges of applying relativistic principles to hypothetical situations without concrete calculations.
  • #91
Grimble said:
Let me ask you all a question that is at the very heart of my understanding of relativity. If A and B are two events in Spacetime and light emitted at those events meets at point M midway between A and B, were A and B simultaneous? Note, this is without defining any frames of reference and without defining any observer, let us say it is an objective view that could be measured from anywhere.
Sadly, your question takes as a premise that simultaneity of two events is absolute. If you assume this, then you are bound to run into a contradiction at some point, given that SR shows that simultaneity is relative.
  • #92
Bartolomeo said:
I think I misinterpreted Grimble. I am not sure I understand what he wanted to say. Does he unwittingly assigns simultaneity of events to the train and admits that rays of light will meet in the centre of the train, if they were simultaneous in embankment frame?
I'm not sure. From his last post, I suspect he's figured out the block universe model but has not quite worked through the idea that there is no preferred direction in which to view it. I could be wrong...
  • #93
Grimble said:
A frame of reference is no more than a map of Spacetime based upon a particular event - a point in space at a point in time and therefore every frame of reference is at rest relative to that initial event.
An event has no definable state of motion. You cannot be "at rest" relative to something for which no state of motion is defined.
  • #94
Grimble said:
Ah! now I do see what you are all saying and why we seem to be using the same words yet speaking different languages!
You say I am giving motion to events when I say their locations are at rest in the rest-frame of an observer - because that 'rest frame' is only 'at rest' measured from itself! From any other frame it is moving - and because 'at rest' has to be relative to something and that something has a state of motion relative to everything else.
Because I have tried to explain how I understand relativity using your framework it doesn't work (for explaining my understanding); because I immediately place myself within the constraints of your views using anthropomorphised frames of reference (well not exactly given human form but at least given physical form - embankments and trains); because that immediately gives rise to 'preferred frames' - usually the embankment - e.g. when we say that the lightning flashes were simultaneous in that frame.
I believe there is a fundamental error in that very phrase for events A and B are not simultaneous in the Embankment frame but are measured to be simultaneous in that frame.
I do not believe that Spacetime has any rest state. That everything moves relative to everything else. That every observer measures Spacetime from their own rest frame. That is not stating that any frame is truly at rest for the very concept does not exist for there is no way to assign a state of rest in Spacetime.
I am sorry if I do not use the correct phrases for I am not a professional scientist, but I am trying to explain what my understanding is.
To answer your last question, it again shows a very basic misunderstanding. Midpoint between A and B in spacetime is an event with space like separation between A and B, therefore no signals from A and B could possibly reach it. So, to define a reachable event you have to posit a world line through M, and there are an infinity of such choices, thus your question has no meaning without a frame of reference - which picks which world line through M is considered to be stationary. Given a choice such that signals from A and B arrive at the same event on this world line, you can say that in the frame where this particular world line is stationary, events A and B are simultaneous. In every other frame, which pick different world lines through M as the stationary one, they are not simultaneous.
  • #95
Then your question makes no sense, because "simultaneous" has no meaning unless you define a frame of reference. This has been said many times in many ways in response to your posts. Enough is enough. Thread closed.
  • · Replies 65 ·
15K
  • · Replies 67 ·
  • · Replies 42 ·
  • · Replies 26 ·
  • · Replies 47 ·
  • · Replies 34 ·
  • · Replies 25 ·
