A ZERO Curl and a ZERO divergence
4 replies · 9K views · last reply
Robt Massagli
A ZERO Divergence Vector Field
There is theorem that is widely used in physics--e.g., electricity and magnetism for which I have no proof, yet we use this theorem at the drop of a hat. The theorem is this:
Given sufficient continuity and differentiability, every vector function A such that div(V) = 0 yields a vector function U such V = curl(U).
Is there a simple proof of this?
I think a proof of this might go along the lines of constructing (a formula for) the vector potential, where the construction holds only for divergence-less vector fields.
Also, there are likely issues of the region over which you are integrating. Your statement above may only be guaranteed locally, a subtle point that is often glossed over in physics courses.
I'll try to describe this issue in the case of a curlless vector field being the gradient of some scalar potential.
The vector field (-y/r,x/r), I think that has zero curl, so locally it has a scalar potential, but globally it is not possible. The theorems don't apply because there is a singularity in the vector field at the origin.
You can visualize the potential function as a winding staircase, so the gradient points up the stairs, locally you can describe the height of the stairs, but if you make more than a full loop around the pole, your height will not be well defined over the plane.
This is not true. We need certain conditions on the domain in order to get this result. A nice condition that we can demand is that the domain of the vector field is open and star-shaped. For example, an open ball would satisfy this, or entire [itex]\mathbb{R}^3[/itex] would satisfy this as well.
In the case of an open and star-shaped domain, the result is true and is given by the so-called Poincaré lemma. Even more general, the Poincaré lemma holds for contractible domains.
A proof of this can be found in "Calculus on manifolds" by Spivak. The result is theorem 4-11 p94. However, it is stated in the language of differential forms. Exercise 4-19 in the same chapter relate differential forms to the more common notions of div, grad and curl.
I made a typo above, I think my example should have been
(-y/r^2,x/r^2)
I think you are referrring to a particular case of a general result called Poincaré Lemma, which states under which condition a function called "potential" can exist, in a wide range of situations. It is indeed an extremely powerful result.
