Does Reversing Time Affect Acceleration and Velocity in Classical Physics?
  • Thread starter Thread starter universal2013
    Acceleration Time
The discussion clarifies that in classical physics, acceleration, represented as \( a = \frac{d^2}{dt^2}x \), remains unchanged under time reversal, while velocity, defined as \( v = \frac{d}{dt}x \), does reverse. This indicates that while the laws of physics, particularly those governing force, are invariant under time reversal, the initial conditions, such as velocity, do change. The conversation emphasizes that reversing time does not equate to assigning negative values to time itself, but rather involves the dynamics of motion and the corresponding changes in velocity and acceleration.
  • Understanding of classical mechanics concepts, particularly acceleration and velocity.
  • Familiarity with calculus, specifically derivatives and their physical interpretations.
  • Knowledge of the laws of physics related to motion and forces.
  • Basic grasp of time as a parameter in physical equations.
  • Study the implications of time reversal in classical mechanics.
  • Explore the relationship between velocity and acceleration in different inertial frames.
  • Investigate the role of initial conditions in physical systems under time reversal.
  • Learn about the exceptions in thermodynamics regarding time symmetry.
Students of physics, educators teaching classical mechanics, and anyone interested in the foundational concepts of motion and time in physics.
universal2013
Hello there, i have a question that confuses me a lot. Is there a difference between the way that we think about time in many classical physics concepts as if it goes to a negative number. For example, we have dv/dt and we can be sure if velocity increases with respect to time and respect to our inertial frame that the acceleration is non zero (positive or negative). If i plug -dt and i don't know if there is a such thing, velocity becomes negative and i can image the motion like a trajectory starts to reverse its motion. But in the dx^2/d^2t the acc doesn't change its sign. What does it mean? Could we think that if time goes to positive or negative, shouldn't it be the same ? Thank you
This is the correct one. Acceleration is second order in time: ##a=\frac{d^2}{dt^2}x##. So acceleration is unchanged under time reversal. And therefore force is also unchanged.
In contrast velocity is first order in time: ##v=\frac{d}{dt}x##. So velocity is reversed under time reversal.
That means that the laws of physics* (which describe the forces) are the same under time reversal, and what changes are some of the initial conditions.
*Excluding thermodynamics
Likes universal2013
Imagine a particle moving towards the right and slowing down. Suppose you have a strobe light flashing at regular intervals of time. Each time the strobe light flashes it reveals the location of the particle. The dots in the following drawing show those locations:
Let's say the velocity is positive, which would make the acceleration negative. If you reverse time you see that the particle would move to the left, speeding up. Now the velocity is negative but the acceleration is also negative! Note that in both cases the acceleration is directed to the left, and so is the net force.
As @Dale says, the acceleration and the force are unchanged under time reversal.
Also, note that when you make ##dt## negative you are not necessarily making ##t## negative. That is, having time go backwards is not the same thing as time being negative.
Likes Dale and universal2013
Thanks for the answers!
  • · Replies 47 ·
  • · Replies 27 ·
  • · Replies 29 ·
