About Van Der Waals interactions
Van der Waals interactions are characterized by temporary dipoles caused by the momentary uneven distribution of electrons, leading to weak attractions between molecules. There is confusion regarding the classification of hydrogen bonds within this category. While some discussions suggest that hydrogen bonds are a type of van der Waals interaction, others argue against this, stating that hydrogen bonds are distinct and should not be classified as van der Waals bonds. This distinction is significant enough that it could necessitate a revision of theories like TLC (Thin Layer Chromatography) if hydrogen bonds were included in the van der Waals category.
samy4408
TL;DR Summary
the consept of van der waals bonds
Hello, when reviewing the types of chemical bonds i was a little bit confused about van der waals interactions, in the definition we talk about momentarily disproportion of electrons that provoke a dipole , and then i read that also include hydrogen bonds .
I am a bit confused about van der waals bonds can anyone enlighten me ,thanks.
Chemistry news on Phys.org
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
