Absolute Value Equations: Setting Restrictions
The discussion focuses on setting restrictions for solving absolute value equations, specifically |2|x + 3| - 5| = 7 and |x - |2x + 1|| = 3. The first equation is clarified as not being an absolute value equation due to the absence of the variable x within the absolute values, reducing it to a simpler linear equation. The second equation involves breaking it into cases based on the critical points where the expressions inside the absolute values change signs, specifically at x = -1/2 and x = -1/3. Participants emphasize the importance of checking solutions against the defined intervals to ensure they satisfy the original equations. Overall, the discussion highlights the methodical approach needed to handle absolute value equations effectively.
vertciel
Hello everyone,
For the following absolute value equations, I have no trouble solving them and finding the valid x solutions by plugging all the x solutions into the original equation.
However, I am just wondering if could someone please show me how to set restrictions for the following equations? I want to know how to solve these equations in two ways instead of just one.
Thank you very much.
1. | 2|x + 3| - 5 | = 7
2. | x - | 2x + 1 || = 3
Mathematics news on Phys.org
The first one isn't an "absolute value" equation at all since the variable, x, does not appear in the absolute vaues: |2|= 2 and |-5|= -5 so that equation is just 2x+ 15= 7.
For the second one, |2x+ 1| "changes" when 2x+ 1= 0 or x= -1/2. Now separate it into cases:
If x< -1/2, then 2x+ 1< 0 so |2x+1|= -(2x+1)= -2x-1. Your equation is now |x+ 2x+ 1|= |3x+1|= 3. |3x+1| "changes" when 3x+ 1= 0 or x= -1/3. Since -1/3< -1/2, x< -1/2 immediately gives x< -1/3 so we have -(3x-1)= -3x-1= 3. Solve that equation. If the solution is less than -1/2, that is a solution to the original problem. If not, this gives no solution.
If x>= -1/2, then 2x+ 1>= 0 so |2x+1|= 2x+ 1. Your equation is now |x- 2x- 1|= |-3x-1|= 3. |-3x-1| "changes" when -3x- 1= 0 or x= -1/3. Now we have two possibilities: -1/2<= x< -1/3 or -1/3<= x.
If -1/2<= x< -1/3, then |-3x-1|= -(-3x-1)= 3x+ 1 and the equation becomes 3x+ 1= 3. Solve that for x and check if the answer is between -1/2 and -1/3. If it is, that is a solution to the original equation, if not, this gives no solution.
Finally, if x>= -1/3 then |-3x-1|= -3x-1 and the equation become -3x-1= 3. Solve that for x and check if the answer is >= -1/3.
halls i think you misinterpreted the first equation, it's a little ambiguous. he probably meant |2(|x+3|)-5|.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
