Abstract Algebra Problem involving the order of groups
The problem involves a group G with elements a and b, where a has an order of 5 and a specific relation between a and b is given by aba^-1 = b^2. The task is to determine the order of the element b, under the conditions that both a and b are not equal to the identity element e.
  • Participants explore the implications of the relation aba^-1 = b^2 and consider the orders of the elements involved. They discuss manipulating the given equations and raising them to powers to analyze the structure of the group.
Several participants have provided insights and alternative approaches, including examining the orders of the elements and the implications of conjugation. There is an ongoing exploration of whether certain powers yield the identity element and the conditions under which this occurs. Some participants express uncertainty about specific steps and seek clarification on the implications of their findings.
Participants note that the order of the element b must be a divisor of 31, and there is a discussion about the implications of the orders of conjugate elements. The conversation highlights the importance of understanding the definitions and properties of group elements in relation to their orders.
xcr
Let G be a group with identity e. Let a and b be elements of G with a≠e, b≠e, (a^5)=e, and (aba^-1)=b^2. If b≠e, find the order of b.
Maybe the statement if |a|=n and (a^m)=e, then n|m.
Other ways of writing (aba^-1)=b^2:
ab=(b^2)a
b=(a^-1)(b^2)a
a=(b^2)a(b^-1)
Also, if the order of a=5, then |a|=|(b^2)a(b^-1)|=5
My work is kinda in the relevant equations. I have manipulated the given formula and looked at the statement listed above but can't see if these will get me anywhere or started in the right direction.
one idea to try:
see if you can prove that abn = b2na.
since a is a conjugate of ba, a = b(ba)b-1, |a| = |ba|.
now write e = (ba)5 by getting all the b's first.
I understand how you got to this point: abn = b2na. The steps to get there go like this:
aba-1=b2 so raising both sides to the nth power would look like (aba-1)n=(b2)n. On the left side we would have n terms of aba-1, but regrouping them would cause then the aa-1 terms to cancel. yielding abna-1=b2n. Multiplying by a on the right gives abn=b2na.
We haven't covered conjugates in my course so I don't understand the second hint and I think your third hint follows from that.
Perhaps you can try and prove that the order of "a" is equal to the order of "ba"?
Start with checking that (ba)5=e.
Then prove that (ba)m≠e for m<5.
For background, conjugate elements are rather important in group theory.
Basically it means that 2 elements "behave the same".
In this case Deveno uses the fact that 2 conjugate elements have the same order.
From wiki:
wiki said:
Suppose G is a group. Two elements a and b of G are called conjugate if there exists an element g in G with
gag−1 = b.​
For the last step that Deveno suggested, can you rewrite (ba)5?
ab=b2a
b-1ab=ba
(b-1ab)5=(ba)5
(b-1a5b)=(ba)5
b-1eb=(ba)5
b-1b=(ba)5
e=(ba)5
Therefore |a|=|ba|
As for proving that (ba)m≠e for m<5, do I just show that when m=1,2,3,4, you get b-1amb=(ba)m, which ≠e?
Then do I just show that (aba-1)n=(b2)n, which can be rearranged as b-nabn=bna.
Not sure what to do from here. If I raise both sides to the 5th power, I would get e=(bna)5
Yes, that looks good!
Consider that (ba)5=b(ab)4a...
xcr said:
ab=b2a
b-1ab=ba
(b-1ab)5=(ba)5
(b-1a5b)=(ba)5
b-1eb=(ba)5
b-1b=(ba)5
e=(ba)5
Therefore |a|=|ba|
the idea is, if we can get e = (ba)5 = bras, with hopefully (if things go well) s = 5, well then we'll have an equation that tells us something about the order of b, which is what we were after in the first place. I like Serena has given you a VERY good place to start...
ok so I took e=(ba)5=b(ab)4a=b(ab)(ab)(ab)(ab)a. I then took ab=b2a and substituted it in. After doing this REPEATEDLY I moved all the b's to the left and all the a's to the right. I ended up with e=b31a5, but a5=e, so e=b31e, or e=b31. Therefore the order of b is 31. Felt like I was doing the right steps but not very confident in that answer.
Right! :)
Btw, taken literally you have not found the order of b yet.
What you found is a power of b that brings b to the identity.
So the actual order of b is at most 31.
To finish things neatly, you should proof that it has to be exactly 31.
Can you?
(Same thing for the order of "ba", where you actually concluded an order of 5 prematurely, but I didn't want to nitpick at the time.)
I would just need to show that (ab)m, where m=1,2,3,4 does not equal e. So just show that (ab)1≠e, (ab)2=a(ba)b≠e, (ab)3=a(ba)2b≠e, (ab)4=a(ba)3b≠e.
Yes, but for (ba)m instead of (ab)m.
To make it easier, consider that the order of (ba) has to divide 5, so it can't be 2,3, or 4.
That leaves the question whether it's possible that ba=e...?
Well if (ba)=e, then (ba)2=(ba)(ba)=ee=e, which is not true. Therefore ba≠e
I'm afraid it's still possible that (ba)2=e at this stage.
I thought that since 2,3, and 4 did not divide 5 that the could not be the order?
Indeed, but you should realize why.
The order is the lowest power to yield identity.
If that were for instance 2, then the power 5 could not be identity.
But the order could still be 1, in which case all powers 2,3,4,5 are identity.
Ok, so ba≠e because then a must equal e and b must equal e, which cannot be true because of our assumptions
Close... but how did you get that a must be equal to e?
if ba = e, what happens when you multiply both sides of this equation by a4?
if b is any power of a, say b = am, show that b5 = e.
why is this a contradiction?
If you multiply both sides by a4 on the right, you get b=a4, so I see now that there is a possibility that ba=e where a and b do not equal e. But if you do b=am, then b5=(am)5=a5m=(a5)m=em=e. Not sure if this is correct but I'd say that this is a contradiction because 5 does not divide 31 and we proved earlier that b31=e.
I'm afraid you are doing things out of order.
The proof that (ba) has order 5 is earlier in the proof, and indeed is used to prove that b31=e.
So you can't use it the other way around.
You also haven't proven yet that b5≠e.
what you HAVE established, is that:
ba = b-1ab.
so what happens if b-1ab = e?
(conjugates really do have the same order, it is never just the case that the order of gxg-1 merely divides the order of x or vice versa).
so if (ba)5 = e and ba ≠ e, then the order of ba is some positive integer that divides 5 which is not 1, so...
Ok, so far I have that aba-1=b2, rewritten as b-1ab=ba. Raising both sides to the 5th power gives us e=(ba)5, therefore the order of ba is 5 or m where m|5. so m=1,2,3,4. m can't be 2,3,4 because they don't divide m. 1|5 but then we have ba=e, where ba=b-1ab. So b-1ab=e, giving us ab=b, which shows that a=e. This is a contradiction to the assumption that a≠e, so the order of ba does not equal 1 and therefore must equal 5. Since the order of ba is 5, then e=(ba)5. Rewrite this as e=b(ab)4a=b(ab)(ab)(ab)(ab)a. Using ab=b2a, we can substitute until we get to the point where e=b31a5. Since the order of a is 5, e=b31. Thus, the order of b is 31 or m, where m|31. Since 31 is prime, only 1 and 31 divide 31. If the order of b is 1, then b=e, which is a contradiction to one of our assumptions. Therefore the order of b is 31.
I think that is it but if there is something wrong I am still accepting help :) just trying to make sure I understand this topic before the exam comes up.
The one part that I am a little worried about is do I need to include the part starting at "Thus, the order of b is 31 or..." I don't know if by proving that the order of ab does not equal 1 means that I do not need to prove this last part.
i think this is a typo...it should be that 2,3,4 do not divide 5.
yes you DO need to include that part. the primality of 31 is essential, if we had come up with something like b30 = e, we would have to consider every divisor of 30.
Yea that was a typo, it should have been 5. So does that prove that the order of b is 31 or is there more that needs to be done?
you should be more explicit here. again, showing that abk = b2ka first, is helpful here, because it allows you to streamline the derivation. so you should have something like:
e = (ba)5 = b(ab)4a
= b(ab)(ab)(ab)(ab)a = b(b2a)(b2a)(b2a)(b2a)a
= b3(ab2)(ab2)(ab2)a2
in other words, you need to justify your "repeated reduction".
Gotcha. And I could show that abk=b2ka by doing aba-1=b2 and then raising each side to the k gives abka-1=b2k. Move the a over and get abk=b2ka. Thank you so much Deveno and I like Serena. Hope ya'll both have a great holiday season.
  • · Replies 26 ·
10K
