Why Doesn't Car Speed Increase with Constant Accelerator Pressure?
The discussion centers on the misconception that maintaining constant pressure on a car's accelerator results in constant acceleration. It is established that while force is applied, external factors such as drag force, rolling resistance, and mechanical friction counteract this force, leading to a state of equilibrium where acceleration ceases. The drag force can be quantified using the equation Fdrag = 1/2 ρCAv2, where ρ is air density, C is the drag coefficient, A is the cross-sectional area, and v is velocity. This results in the car maintaining a constant speed despite constant accelerator pressure.
  • Understanding of Newton's laws of motion
  • Basic knowledge of vehicle dynamics
  • Familiarity with drag force and its components
  • Concept of torque and its relationship with engine RPM
  • Study the effects of drag force on vehicle performance using fluid dynamics principles
  • Learn about torque curves and their impact on vehicle acceleration
  • Explore the mechanics of rolling resistance and its effects on speed
  • Investigate the relationship between throttle position and engine output in automotive engineering
Automotive engineers, physics students, and anyone interested in understanding vehicle dynamics and the factors affecting acceleration and speed in cars.
jrm2002
We know,
a=F/m
a=acceleration
F=Force
m=mass
Greater the force applied greater would be the acceleration.If force is constant then for a particular mass the acceleration(rate of change of velocity) would remain constant.Right?
Now, let us say I press down the accelerator of my car.I keep the accelerator at a constant level , i.e. after presing the accelerator wioth my foot to a certain distance down, I neither raise my foot above or below.Then, in such a case,
Am I not maintaining a constant force?
Should not the acceleration remain constant?
i.e. should not the velocity vary uniformly(linearly)?
But the needle of the spedometer of the car shows no change in speed in such a case?
But the force is constant as I keep the accelerator at a constant level , i.e. after presing the accelerator wioth my foot to a certain distance down, I neither raise my foot above or below.
Plz. help!
Think of this situation: you release the gas pedal completely. You're clearly not applying any force, yet the car experiences acceleration in the opposite direction of motion (deceleration).
Why does the car slow down?
To:dav2008
dav2008:
You asked ,
Ya-- but I am sorry as I am not familiar with mechanical engineering part of the vehicles.Shall be extremely grateful and obliged if you can explain the answer to my question and also tell me why the car experiences deceleration when the peddle is released fully?
i think u miss the contribution of the fuel of the car too.
this is not simply u press the accelerator and the the car would accelerate. there are many other things would be involved.
hope it helps^^
kit
The is due to the force of drag or fluid friction. The drag force experienced by a car can be represented as;
F_{drag} = \frac{1}{2}\rho CAv^2
Where \rho is the density of air, C is the drag co effiecient, A is the cross sectional area of the car and v is the velocity.
This represents an unbalanced force acting on the car, which will cause a negative acceleration. Rolling resistance (of the tyres) and friction of other mechanical parts would produce a retarting force upon the car.
~H
the mechanics of the car just contributes to unnecessary complication of the problem, so let's boil it down...
lets assume that the force you apply to the pedal is directly linearly proportional to the "thrust" of the car (neglecting torque curves, gear changes, fuel and such). now since you are applying a constant force to the pedal, and hence telling the car to apply a constant "thrust" to the ground, why does the car not continue to accelerate? Well, neglecting air resistance, road friction, drag torque in the drive train, etc., the car would continue to accelerate, much like a rocket in space where there is no resistance to motion. but since we live on earth, and these resistances do occur, the constant thrust of the car is exactly balanced by the external forces mentioned before when the car reaches a constant speed (i.e., a=0). Hope that helps without being redundant in addition to the other helpful answers in this thread
Acceleration and Velocity(Continued)
That means:
If we pull anybody say with a constant force (neglecting effects due to friction,etc.) it would accelerate with a constant acceleration i.e. its velocity keeps changing at every instant(linear variation).Right?
jrm2002 said:
That means:
yes, it is
  • · Replies 33 ·
9K
