Acceleration in a Pulley System
The acceleration of mass m1 (10 kg) in a frictionless pulley system, where mass m2 (5 kg) is connected, can be calculated using the formula a = (m2 * g) / (m1 - m2). The tension force acting on m2 must be considered, and it is crucial to understand that the accelerations a1 and a2 are not equal due to the movement of the pulley. Visualizing the system with a string can aid in comprehending the relationship between the distances moved by m1 and m2, which directly influences their respective accelerations.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of pulley systems and tension forces
  • Familiarity with acceleration and gravitational force concepts
  • Ability to visualize mechanical systems and their movements
  • Study the derivation of acceleration in pulley systems using Newton's laws
  • Learn about the effects of friction in pulley systems
  • Explore the concept of tension in different pulley configurations
  • Investigate real-world applications of pulley systems in engineering
Physics students, mechanical engineers, and anyone interested in understanding dynamics in pulley systems will benefit from this discussion.
grouchy
For the system in the figure mass m1 is 10 kg and mass m2 is 5 kg. What is acceleration of m1 if the horizontal surface is frictionless? Hint: How does a1 compare to a2?
http://geocities.com/grouchy187/untitled.bmp
My attemp:
T = m1a T - m2g = m2a
m1a = m2g + m2a
a= m2g / m1-m2
What tension force acts on m2? (Consider the pulley as part of m2.)
What about that hint?
for m2, would the weight W, be equal to 2T?
also I think a1 = a2
No. But those are the forces acting on m2. (They would only be equal if m2 were not accelerating.)
No. Try to think this through. (Using a piece of string to work it out may help--I'm not kidding.) If m1 moves 1 m to the right, how far down does m2 move?
i dunno, I'm thinking about it and I just don't get this one
If m2 moves down by 1 meter, how much extra rope will hang down off the table? That extra amount of rope is the distance that m2 moves (since m2 is tied directly to the rope). Once you have that, the ratio of distances in this case is the same as the ratio of accelerations.
If you're having trouble visualizing the amount of extra rope, just start with your orginal diagram. Now draw in the new position of m2 and the lower pulley 1 meter below where they were. Note that you have to extend the lines for the ropes on each side of the pulley. How much extra rope do these new lines represent?
