Acceleration of point of contact
The discussion revolves around the acceleration of the point of contact of a sphere undergoing pure rolling on a smooth surface, with the center of mass moving at a constant velocity. Participants explore various aspects of the motion, including the relationship between linear and angular quantities, and the nature of acceleration in this context.
  • Some participants assert that the velocity of the point of contact during rolling motion is zero.
  • Others question whether the acceleration of the point of contact should consider centripetal acceleration, suggesting it is relevant to the overall analysis.
  • There is a proposal that the relationship between the center of mass velocity and angular speed can be expressed mathematically, with some participants suggesting that the acceleration of the center of mass is zero in uniform rolling.
  • Some participants argue that the acceleration of the point of contact is directed towards the center of mass, regardless of whether the rolling is uniform or accelerated.
  • There is a discussion about the implications of different interpretations of the term "point of contact," leading to varied conclusions about its acceleration.
  • One participant notes that the original question lacks clarity, leading to different interpretations and answers regarding the acceleration of the point of contact.
Participants do not reach a consensus on the nature of the acceleration of the point of contact. There are multiple competing views regarding whether to consider linear acceleration, centripetal acceleration, or both, and the implications of the question's phrasing contribute to the disagreement.
The discussion highlights limitations in the clarity of the original question, which affects the interpretations and responses provided by participants. There is also a dependence on definitions of terms like "point of contact," which leads to varied conclusions.
quawa99
For a sphere undergoing pure rolling on a smooth surface with center of mass having constant velocity,what is the acceleration of point of contact
Perhaps start by asking what is the velocity of the point of contact? Is that constant or changing?
Is'n it stationary?
The velocity of the point of contact during rolling motion is zero.
My question is about its acceleration
Hi quawa99...
If the velocity of the CM is vcm,radius R and the angular speed of the sphere is ω ,then what is the relationship between them considering the sphere is undergoing pure rolling ?
Tanya Sharma said:
Hi quawa99...
If the velocity of the CM is vcm,radius R and the angular speed of the sphere is ω ,then what is the relationship between considering the sphere is undergoing pure rolling ?
The velocity of of CM with respect to the point of contact is given by Vcm=RXw where w is angular velocity of the sphere.
vcm is with respect to the ground frame .
Anyways, now what is the relation between the acceleration of CM and the angular acceleration ?
a=RXangular acceleration
Now ,what is the value of acm in the given problem ?
Its not a problem given in a book
Angular acceleration and linear acceleration of cm in horizontal direction is 0
I was referring to that question.
Anyway, the point of contact (in fact, all the points on the surface) have acceleration toward the centre of mass of the object. Be it, uniform pure rolling or accelerated pure rolling, the acceleration will be towards the centre of mass.
Also even if there is friction, since there is no slipping between the surfaces, the work done by it will be zero.
Why do all the points on surface have an acceleration towards centre ?I have read that pure rolling is the same thing as pure rotation about point of contact so doesn't that mean acceleration of cm with respect to point of contact is v^2/R ?
Yes. Pure rolling is same as rotation about point of contact.
About the point of contact and the acceleration, mathematically you can derive for any point on the surface. And if you substitute the condition for the pioint of contact, you'll find out that the acceleration of point of contact is towards the centre.
Since vcm = constant ,acm = 0 .
apoint of contact = apoint of contact w.r.t CM + acm
So,apoint of contact = ?
You have to derive that. Also, acceleration of centre of mass is zero only in a uniform pure rolling.
What is the acceleration of point of contact with respect to cm?
My question is about a uniformly rolling sphere
apoint of contact w.r.t CM = αR ,where α is the angular acceleration :smile:
α is zero in my question
if you consider the horizontal to be the x-axis, then, the point of contact makes an angle 3π/2. Now
a(point of contact)= a(cm)i + a(P,cm)
= a(cm)i + a(P, tangential) -i + a(P, radial)
= a(cm)i - Rα(cm) + R(w^2)
α+ angular acceleration of centre mass.
So now what is the problem ? You have everything to answer the question .
according to your equation the point of contact has 0 zero acceleration but then shouldn't that mean if you observe the cm in the frame of point of contact(which is stationary in present situation) it would have a centripetal acceleration of v^2/R as it is undergoing pure rotation about point of contact with angular velocity v/R
a(point of contact) = a(point of contact w.r.t CM) + a(cm)
= a(p, tangential) + a(P, radial) + a(cm) i
Since the rolling is uniform, a(cm) is zero as well as α(cm) i.e; angular acceleration of centre of mass and since a(P, tangential) = Rα(cm), it becomes zero.
Therefore, a(point of contact) = a(P, radial) = R(w^2) j
i is positive x-axis and j is positive y-axis.
The equation does NOT show that acceleration is zero. It is Rw^2. Since V=Rw, it is equal to v^2/R
I said that for Tanya's equation not yours.I think I understood what you said. thanks :)
quawa99..You are mixing up things ...The linear acceleration of the point of contact is zero , but it does have a centripetal acceleration about the CM owing to its rotation about the CM .
Isn't centrepetal acceleration also a type of acceleration?.so when you calculate the acceleration of point of contract shouldn't you think about the centripetal acceleration as well?.I never asked for linear acceleration of the point of contact specifically
Yes...centripetal acceleration is part of the total acceleration of the point of contact with respect to the CM .
But your original question is :
It doesn't ask about the total acceleration of the point of contact with respect to the CM . Generally ,if the question asks about the acceleration of the point of contact ,the implicit meaning is to calculate the linear acceleration (horizontal in this case) of the point of contact of the rolling body with respect to the ground frame.
Certainly the original question isn't clear. When I drove my car to the shops today the point of contact certainly went with it and didn't remain in the garage. It had the same velocity and acceleration as the car.
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 51 ·
