Accelerator Operator: Job Description & Responsibilities
An accelerator operator is responsible for the operation and maintenance of particle accelerators, ensuring they function smoothly within larger user facilities like synchrotron centers. Key duties include monitoring beam parameters, conducting system checks, managing beam filling and topping, and performing start-up and shut-down procedures as needed. The role focuses on maintaining optimal performance and safety of the accelerator systems.
imastud
What sort of things does someone who works at a lab as an "accelerator operator" do. Obviously the name speaks for itself but I was looking more a more specific description.
Accelerator operator (not the be confused with accelerator physicist), does exactly what the name implies, operate an accelerator. Many accelerators are part of a larger user facility, such as a synchrotron center. As an accelerator operator, you make sure the beam parameters are nominal, run system checks, do beam filling/topping/etc., do start-up and shut down whenever necessary, etc... etc. In other words, things that require the accelerator to run smoothly.
Zz.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
