Accoustic waves notions (propagation in a tube)
The discussion revolves around acoustic waves and their propagation in a tube with a variable cross-section. The original poster seeks clarification on concepts related to elongation, dilation, and the application of the fundamental principle of dynamics in the context of fluid dynamics and acoustics.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the definitions and relationships between elongation (e) and dilation (D), questioning the dimensional analysis of these terms. There is also inquiry into the use of density in the fundamental principle of dynamics for fluids. Some participants analyze the implications of pressure gradients and their relation to force and volume.
The discussion is active, with participants providing insights and raising questions about the underlying principles. Some guidance has been offered regarding the dimensional relationships and the application of dynamics, but there is no explicit consensus on the definitions or relationships among the variables involved.
Participants note a lack of clarity on certain terms and relationships, such as the definition of the cross-sectional area (S) and the implications of using mass density in the equations. There are also personal inquiries about sound amplification and its feasibility using a truncated cone, which diverges from the main focus of the problem.
Cathr
Thread moved from the technical forums, so no Homework Template is shown
Please help me with this problem I am facing, I am lacking notions of acoustics and I would be very grateful if someone could clarify them:
A tube has a revolution symmetry arounf the ##x## axis and has a section dependent of the value of the abscissa (x), so the profile ##S(x)## is known. The tube is filled with a fluid with the density (mass/volume) at rest = m and the pressure P0. Whe call ##p(x,t)## the overpressure and ##e(x,t)## the elongation in the presence of an accoustic perturbation. The total pressure is ##P(x,t)=P0+p(x,t)##.
We admit the by applying the fundamental principle of dynamics for a slice of fluid of width dx at the x abscissa, we can show that the tube profile does not modify the relationship that is obtained for cylindrical tubes:
##\frac{dp}{dx}=-m \frac{d^2e}{dt^2}##
These were the given statemens, now the questions are:
1. Using the linear response approximation, write the relationship for the dilation D, the compressibility X and overpressure p.
2. Making sure to control the coherence of the approximation orders of the different terms, show that:
##D=\frac{1}{S} \frac{d(Se)}{dx} ##
There are notions here that I don't quite understand. What is the difference between the elongation e and the dilation D? What do they correspond to?
Why, when writing the fundamental principle of dynamics (F=Ma) we don't use the mass, but the mass over volume for the fluid?
I would really like to know the relationships between these variables, as I searched everywhere I could and didn't find. Thanks a lot in advance!
Analysing the equations given dimensionally, I see that m is a density, e is a distance, but D is dimensionless. So maybe D is the fractional expansion of a region... but then, it would have a simple relationship to pressure, no?
Not sure how S is defined. From the description, I would have guessed radius, but from the equations it looks like cross sectional area.
On the left it is dp/dx, a pressure gradient. If you consider a small volume, the net force acting is pressure gradient multiplied by the volume. So you can go from F=ma to dp/dx=ρa by dividing by the volume of the element.
Thank you!
I found a solution, and, if you don't mind, I have a question that is rather out of personal interest. How can I calculate the amplitude of a sound wave that gets out of the tube, comparing to the one that enters?
Direct application: Suppose I don't like the sound intensity of my phone, and I want to amplify it. Is it possible to do this using a truncated cone out of paper? If so, how can I calculate the maximum intensity that I can obtain? This is, of course, in function of the radiuses of the truncated cones, or their ratio.
Cathr said:
Thank you!
By consrvation of energy, the only way you could increase the amplitude is to narrow the wavefront. But at a given distance from the speaker, the wave will still spread over the same area, so that won't help. You would need to channel the sound or get the outlet closer to your ear.
  • · Replies 18 ·
  • · Replies 67 ·
  • · Replies 33 ·
  • · Replies 45 ·
