Action and equations of motion
The discussion centers on the implications of adding a time derivative of a function of time and coordinates, denoted as f(q,t), to the Lagrangian in classical mechanics, specifically referencing Landau and Lifshitz's mechanics book. It is established that the equations of motion remain unchanged when this time derivative is included, as demonstrated through the Euler-Lagrange equations. The reasoning hinges on the properties of perfect differentials, where the variation of the added function vanishes at the endpoints of integration, confirming that the action remains invariant.
  • Understanding of Lagrangian mechanics
  • Familiarity with Euler-Lagrange equations
  • Knowledge of calculus, particularly differentiation and integration
  • Concept of action in classical mechanics
  • Study the derivation of the Euler-Lagrange equations in detail
  • Explore the concept of perfect differentials in calculus
  • Investigate the implications of coordinate transformations in Lagrangian mechanics
  • Learn about the principle of least action and its applications
This discussion is beneficial for students and professionals in physics, particularly those studying classical mechanics, as well as educators looking to clarify concepts related to Lagrangian dynamics and the invariance of action.
TeTeC
Hello !
I'm reading Landau/Lifchitz's mechanics book.
At equation (2.8), the author explains that when I add a time derivative of any function of time and coordinates f(q,t) to the lagrangian, the equations of motion are unchanged.
I understand the mathematical development leading to S' = S + f(q(2),t_2) + f(q(1),t_1), but I can't see why the equations of motion don't change.
I've tried to substitude the lagrangian of equation (2.8) in the Euler-Lagrange equations to convince myself it works, but that doesn't seem to be a good idea.
If you don't have this book and can't see what I'm talking about, I can provide you with more details.
Thank you !
More details would certainly be appreciated :)
Okay L'=L+\frac{d}{dt}f(q,t). Compute the E-L equations for S' defined in terms of L'. Can you do it ?
(click on it, obviously my attachment becomes very small...)
Like this ? If this is correct, I don't see why the two last terms should disappear...
Perfect so far. Now who's
\frac{d}{dt}f(q(t),t) equal to ? HINT: Chain rule, you've got both implicit and explicit time dependence.
That simply imply that you can sit in a different frame of reference /coordinate and see the system.
But you can prove that simply,
When the perfect time derivative dF is added to Lagrangian, to calculate the action you have to integrate a perfect differential dF. Then you get a function F which is the functions of position and momentum coordinates and their variation vanishes at the end points. So the variation of the function F also vanishes.
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 23 ·
