Engineering Adding Harmonics to Form the Final Signal
The discussion focuses on understanding harmonics in relation to the fundamental frequency and the mathematical representation of signals. Participants clarify that the fundamental frequency (f0) is the base harmonic, while subsequent frequencies (f1, f2, etc.) represent higher harmonics. The formula involving (2PI/T)*t + phase is highlighted as essential for constructing cosine functions for signal representation. There is uncertainty about the term A0/2, but it is noted as a common reference in literature. The period (T) is defined as the time for one complete cycle, particularly in the context of a 50 Hz frequency.
MisterP
Hello. Could someone help me?
I have to:
1) from given harmonics syntesize signal
2) calculate effective value of signal
3) represent resultant signal
Specs:
I assume frequency is 50hz
Table given below
A0/2 + A1*cos ("what goes here?" + Fi1) + etc..
Formula I have shows is probably for resulting harmonic? Does syntesizing mean writing the main formula? I havo no clue about effective value of signal and representation is probably done in excel or other graphing app.
Inside the cosine should be a frequency *time + phase shift. What do you know about the harmonics in relation to the fundamental frequency? Are you sure about the A0/2 ? Usually f0 would be the fundamental freq. Then f1 is first harmonic etc.
Likes berkeman
Thanks for response. I am not sure about A0/2, but I have seen it in books. I found formula where it says (2PI/T)*t + phase comes in cosine function. What is "(2PI/T)*t"? PI refers to 3.14
Ok, I have come to some conclusion, i hope it is right.
So, first comes base harmonic and it is devided by 2. A0/2, then adding other harmonics + A1*cos(314-0.68) + etc
So, 314 is because I have 50hz frequency and -0.68 is my angle in radians.
Sorry for being slow to reply. In this context T is the Period (time of one complete cycle). In your example of 50 Hz frequency, the period is (1/50) seconds.
  • · Replies 22 ·
  • · Replies 58 ·
