Adding velocity vectors to get average velocity
Displacement vectors can be summed to determine total displacement when driving, but adding velocity vectors to find average velocity is more complex. Average velocity is defined as total change in position divided by total time, not simply the sum of velocity vectors. If each segment's velocity vector corresponds to equal time intervals, averaging them by dividing the sum by the number of segments is possible. However, if time intervals vary, this method would not yield an accurate average velocity. Understanding the relationship between displacement, velocity, and time is crucial for accurate calculations.
Jtwa
If you're driving in a car and map out all the displacement vectors, you can add the segments to get the total displacement. Correct?
Why can't we add the various velocity vectors for the different segments to get the average velocity. ?
Could you add up all the velocity vectors and divide by the # of segments?
If all the vectors represented the same amount of time, you could.
Average velocity is also the total change in position divided by the total time.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
