What Radius of a Bubble Causes Vapour Combustion After Adiabatic Compression?
The discussion focuses on determining the radius of a vapor bubble required for combustion after adiabatic compression. The initial bubble radius is 5 mm, and the vapor ignites at 1100 degrees Celsius. The ratio of specific heat capacities is given as CV/(n*R) = 3.0, leading to specific heat capacities of CV = 3R and CP = 4R. The final calculated radius for combustion is 1.09 mm, derived from the relationship between temperature, volume, and the specific heat capacities.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the ideal gas law and its applications
  • Knowledge of specific heat capacities (CP and CV)
  • Basic principles of statistical mechanics
  • Study the derivation of the adiabatic process equations in thermodynamics
  • Learn about the significance of specific heat ratios (gamma) in gas dynamics
  • Explore the relationship between temperature, volume, and pressure in ideal gases
  • Review examples of combustion processes in vapor systems
Students and professionals in thermodynamics, chemical engineering, and physics, particularly those interested in combustion processes and adiabatic transformations.
kpw1
An explosive liquid at temperature 300 K contains a spherical bubble of radius 5 mm, full of its vapour. When a mechanical shock to the liquid causes adiabatic compression of the bubble, what radius of the bubble is required for combustion of the vapour, given that the vapour ignites spontaneously at 1100 degrees C? That ratio of CV/(n*R) is 3.0 for the vapour.
I'm going to combine relevant equations and attempt at solution together because I'm not sure if the equations I'm using are the relevant ones to begin with.
So for reversible adiabatic changes in an ideal gas,
PV^{\gamma} = constant
And if we put P = nRT/V into that equation, we get
TV^{\gamma-1} = constant
The problem is, how am I supposed to know the n of the gas (how many particles)? I'm guessing I have to use the ratio CV/(n*R) somehow to also find \gamma:
CV/nR = 3 (from above)
So
CV = 3nR
and
CP = CV + R
So
CP = 3nR + R
= (3n + 1)R
\gamma = CP/CV
= \frac{(3n + 1)R}{3nR}
= \frac{3n+1}{3n}
And now I'm stuck again because I still don't know n
Any help/guidance would be appreciated. Thanks.
Also, this problem is from Introductory Statistical Mechanics 2nd ed. by Roger Bowley and Mariana Sanchez, Chapter 1, Problem 8
Use the initial information in the beginning of the problem to give you the T and V of the bubble. Then use that equation. Set the initial and final equal to each other.
As for the "n" part. I think you use the specific heat capacities instead.
How do I find \gamma, though?
\gamma = CP/CV
I don't know either values of CP or CV..
BTW, I recently found the answer in the back of the book. The new radius is supposed to be 1.09 mm, but I still don't get how they got to this..
The gamma is just the Cp/Cv but it is with specific heat capacities.
Your equation with Cp = Cv + R is only for specific heat capacities. I wish that I could put the little bar above the Cp and Cv but I can't. Remember that it is specific heat capacities that have to be used in this problem.
This means that the specific Cv would be 3R and the specific Cp would be 4R.
Sorry, I'm still confused..:confused:
How did you arrive to this?
I arrived to this because the problem gave you Cv/(n*R) = 3.0 . Since specific Cv is just Cv/n, the specific Cv would be 3R.
Since specific Cp is equal to specific Cv + R, then specific Cp would be 4R.
This will give you the information needed for gamma and the rest of the problem.
Thanks so much, bucher.
I forgot the difference between heat capacity and molar heat capacity.
Thanks again! :smile:
10K
  • · Replies 22 ·
