Why Does Adiabatic Compression Yield a Negative Work Calculation?
In the discussion about adiabatic compression, participants clarify that while the work done on the gas is considered positive, the work done by the gas is negative. The confusion arises from the application of the first law of thermodynamics, where the internal energy change is expressed as ΔU = Q - W. The calculations initially yield a negative work value due to a misunderstanding of the sign convention. The correct interpretation is that during adiabatic compression, the work done by the gas is negative, aligning with standard thermodynamic conventions. This highlights the importance of understanding the context and sign conventions in thermodynamic calculations.
ewang
Find the work done by the gas (or on the gas) for an adiabatic process starting at V = 0.024 m^3 and 101325 Pa and ending at 0.0082 m^3 and 607950 Pa. The working gas is helium
Work for adiabatic = area under pV diagram
p1V1^gamma = p2V2^gamma
This is a relatively simple problem, but I'm not getting the right answer. For adiabatic compression, work on gas is positive, since work on gas = ΔEth and the adiabatic process moves from a lower isotherm to a higher one. Integrating for work gives:
pV * (Vf(1 - gamma) - Vi(1 - gamma))/(1-gamma)
I believe this is correct, but when I plug in the numbers, I'm getting a negative number:
101325 Pa * 0.024 m3 * ((0.0082 m3)1 - 1.67 - (0.024 m3)1 - 1.67)/(1 - 1.67)
= -3823.6 J
ewang said:
Homework Statement:: Find the work done by the gas (or on the gas) for an adiabatic process starting at V = 0.024 m^3 and 101325 Pa and ending at 0.0082 m^3 and 607950 Pa. The working gas is helium
Relevant Equations:: Work for adiabatic = area under pV diagram
= -3823.6 J
Nevermind, work is negative integral oops. I was staring at this for the longest time.
The standard thermodynamics convention of signs is the Clausius convention
ΔU = Q - W
the variation of internal energy = Heat added to the system - Work done
Thus when the gas expands we have positive work
Likes Lnewqban
Right. work done BY gas is negative. The 1st law is usually written ## dU = \delta Q - p dV ## in physics.
10K
9K
