Adiabatic filling of a tank - Minimum work required
The discussion focuses on calculating the minimum and real work required for the adiabatic filling of a tank with ethane, starting at 350 K and 8 MPa and ending at 365 K and 6 MPa. The tank is insulated, meaning no heat exchange occurs during the process. Participants suggest using the first law of thermodynamics to relate changes in internal energy and enthalpy to work done. The ideal gas law is deemed inapplicable due to the need for specific heat data in polynomial form, complicating calculations. The conversation emphasizes the importance of accurately determining the change in internal energy and enthalpy to find the required work.
alystar
Hi guys, need an help about that problem
That's an adiabatic filling of a reservoir (tank) from a line.
Line is at 350 K and 8 MPa. The tank is, in the final state, at 365 K and 6 MPa.
Tank is insulated (no heat exchanged during the process), and only one stream enter in the tank.
How can i find the minimum work to be done to make the filling? And how can i find the "real work" to be done to make the filling?
Thanks a lot...
Thanks a lot...
Welcome to PF alystar!
How about telling us what you are filling the tank with?
AM
Thanks for your welcome!
Sorry, thought the procedure (energy balance or kind of) was almost independent from the kind of substance involved. :) Substance is Ethane.
I've to do the same, also, with Acetylene, but on different pressures and temperatures conditions. (the one I've wrote above are about Ethane).
Thanks!
We just need to know if you can apply the ideal gas law. Ethane can be modeled as an ideal gas in this temperature range. We also have to know its heat capacity (constant volume) CV
Start by using the first law of thermodynamics: ##Q = \Delta U + W##. Since Q = 0 (adiabatic) what is the relationship between W and U? Using the ideal gas law and the CV for Ethane, can you determine the ##\Delta U##? Can you then relate that to W?
AM
Nope, ideal gas law cannot be applied. Data for Cp are available as polynomial as function of temperature, so i cannot give you an exact value right now.
The energy balance for the system is:
d(U)/d(t)= (Mass flow in*)Enthalpy In - (Mass flow out)*Enthalpy out + Heat exchanged + Work
where U is the internal energy and "t" is time.
The three last terms are = 0, because there's no mass flow out, no heat exchanged, and no work of deformation done (because the volume of the tank is constant, there's no work done through areas which are not crossed by streams). I'm sure about that energy balance because it had been already applied to another similar tank filling.
Therefore, that's why I'm really in trouble. No idea about a formula in order to get the minimum work.
Right now i calculated the Enthalpy difference H(f)-H(e), where H(f) is the final enthalpy of the tank at the end of the filling, and H(e) is the enthalpy of the line (costant during the filling). I calculated H(f)-H(e) because it was needed in order to get the final status of the tank at the end of the filling.
I'm pretty sure that difference it's necessary in order to calculate the minimum work. Still thinking about a simple relationship between the already found enthalpy and something else, like entrophy. (of course suitable for that case, an adiabatic and not-closed system)
OK But the units are not quite right. Should it not be:
##d(U)/d(t)= (\Delta H_{in})dm_{in}/dt- (\Delta H_{out})dm_{out}/dt + dQ_{exch}/dt + dW/dt ## ?
This is simply a restatement of the first law:
##\Delta U = Q + W ## where W is the work done on the system
As far as the minimum work, under what conditions would the work be minimum (think of the process - what kind of process would require minimum work?)
Can you find ##\Delta U## per unit mass? and the ##\Delta Q## per unit mass (i.e. ##\Delta H_{in}##) for the process?
The net change in internal energy has to equal the change in enthalpy + work done on the gas. So if you can find ##\Delta U##? and ##\Delta Q## you can find W.
AM
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
