Undergrad Solving Adiabatic Process for Two Compartments
The discussion revolves around solving an adiabatic process involving two compartments of a cylinder containing ideal gases at different initial temperatures. The initial calculations suggest final temperatures of 510K and 290K, but there is uncertainty about their correctness. A revised approach emphasizes that adiabatic compression occurs on one side while expansion happens on the other, necessitating adjustments to the equations used. The need for an external force to move the partition slowly implies unequal work done by the gases, affecting the internal energy of the system. This problem parallels another recent discussion on similar adiabatic processes.
chuakoktong
TL;DR
Adiabatic process
I tried this question and this the answer given in the book.
A cylinder is close at both ends and has insulating walls. It is divided into two compartments by a perfectly insulating partition that is perpendicular to the axis of the cylinder. Each compartment contains 1.00 mol of oxygen, which behaves as an ideal gas with γ=7/5. Initially the two compartments have equals volumes, and their temperatures are 550k and 250k. The partition is then allowed to move slowly until the pressure on its two sides is equal. Find the final temperatures in the two compartments.
Let P1 be the initial pressure in 1st compartment
P2 be the final pressure in 1st compartment
P3 be the initial pressure n 2nd compartment
P4 be the final pressure in 2nd compartment
V1 be the initial volume in 1st compartment
V3 be the initial volume in 2nd compartment
V2 be the final volume in 1st compartment
V4 be the final volume in 2nd compartment
T1 be the initial temperature in 1st compartment
T2 be the final temperature in 1st compartment
T3 be the initial temperature in 2nd compartment
T4 be the final temperature in 2nd compartment
X be the length of the cylinder
m be the percentage of the cylinder length that move in the process
A be the area of partition
Solving the equation 1 and 2
##P_1V_1^{\gamma}=P_2V_2^{\gamma} -1##
##P_3V_3^{\gamma}=P_4V_4^{\gamma}-2##
(By using PV=nRT)
Will get the ration ##V_2=1.756V_4## or ##T_2=1.756T_4##
Since the work done by the adiabatically expanding gas is equal and opposite to the work done by the adiabatically compress gas.
##(T_1-T_3)=- (T_4-T_2)##
##T_2+T_4=T_1+T_3=800K##
And substitute ##T_2=1.756T_4## into the equation will get ##T_2=510K## and ##T_4=290K##
However, i think this answer is not correct?
The equation should be as below since it not possible to undergo adiabatic expansion on one side and adiabatic process on the other side?
The correct one should be adiabatic compression on the right partition?
##2.5p_1v_1-(2.5p_4v_4-2.5p_3v_3)=2.5p_2v_2##
##p_1v_1-(p_4v_4-p_3v_3)=p_2v_2##
##nR(550)-[nR(250)(\frac{0.5}{0.5-m})^{\gamma-1}-nR(250)]=p_2(0.5+m)XA##
and
##p_3v_3^{\gamma}=p_4v_4^{\gamma}##
##nR(250)(0.5XA)^{\gamma-1}=p_4(0.5XA-mXA)^{\gamma}##
##p_4=p_2##
##[550-250(\frac{0.5}{0.5-m})^{\gamma-1}+250](\frac{0.5}{0.5+m})(\frac{0.5}{0.5-m})^{-\gamma}=250##
solve the value of m to get the pressure on both side and hence temperature on both side?
If the partition is "allowed to move slowly", what they meant to say is that it is "forced or constrained to move slowly." To accomplish this, you need to exert external force on the partition during its motion. This means that the amounts of work done by the two gases will not be equal and the change in internal energy of the overall system will not be zero.
This is similar to a question addressed in another recent thread: https://www.physicsforums.com/threa...diabatic-container.981529/page-2#post-6274658
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 61 ·
  • · Replies 22 ·
