Adjusting Accelerometer Readings for Tilt and Rotation: A Scientific Approach
In summary: What would you suggest I do?I don't think this sufficient info to get a unique 3D rotation. What would you suggest I do?You could try using a different kind of sensor that can measure angles, such as a magnetometer or an accelerometer with a higher resolution.
Sam Smith
37
I have been using an accelerometer and I have realized that it was sitting at a tilt of 18 degrees in the z direction and rotated at 5 degrees in the x y direction. How should I change my accelerometer readings to account for this?
You should be able to multiply each of your readings by the cosines of the known error angles.
This will not preserve the magnitude of the acceleration vector, which should be preserved in a mere rotation.
So for example my z reading will be multiplied by cos(18) and cos(5) as will the x and y readings?
My bad...they should be DIVIDED by the cosines...since being out of alignment will make the measured readings smaller.
Just wanted to check, so I will divide all readings by the cosine of both angles. For example I will divide z readings by cosing 18 AND cosine5 .. It makes sense as both rotations will effect all vectors but wanted to be sure
The magnitude of the vector will be the same so the absolute components cannot be all smaller.
Also wanted to check, Why do we use cosine as this would suggest that the actual reading and reading nw made form a right angle triangle with each other?
How would you approach this problem A.T?
Construct a 3x3 rotation matrix, that transforms the acceleration vector from the accelerometer coordiante system to the system you need:
http://en.wikipedia.org/wiki/Rotation_matrix
Hi there AT thank you so much for the advice. I actually came across my error I had already come up with a rotation matrix before but had considered the rotations in the wrong order. I also wanted to check how would work out the roll pitch and yaw from stationary data? my data is -0.9 0.5 and -0.4 (my x is pointing downwards into the 1g direction) How can I work out the angles I have done it but I think error in this part is leading to my problem
Don't mess around with angles, then you have no problem with their order.
Determine the unit vectors of the target system (TS) directly from measurement: Align the object so your TS-axis(e.g. X) points upwards (against gravity), and save the accelerometer reading as the TS-unit vector (e.g. ex). Do this for two axes (e.g. X,Y), then use the cross product to get the 3rd unit vector and orthogonize. For example, knowing ex, ey you would do this:
ez = ex x ey
ey = ez x ex
Then normalize all 3 vectors to unit length. These 3 unit vectors are the rows of your matrix R which can be used to transform from accelerometer system (AS) to TS:
aTS = R * aAS
That is a great idea however, I am doing this in retrospect. The device was placed on an animal and rotated during the course of the experiment. As a result the only thing I have to go on is the x y z readings when the animal was stationary in order to work out how much the gyroscope had rotated and then correct the rest of the readings. So what I found was that at rest my readings were x = -0.9 y = 0.14 z = 0.44 and so I am trying to adjust the rest of my readings based on this info
Related to Adjusting Accelerometer Readings for Tilt and Rotation: A Scientific Approach
1. How does an accelerometer work?
An accelerometer is a sensor that measures acceleration, which is the change in velocity of an object over time. It typically consists of a mass attached to a spring, and when the object experiences acceleration, the mass moves, causing the spring to compress or stretch. This movement is measured by electronic circuits and converted into a readable output.
2. What is the purpose of calibrating an accelerometer?
Calibrating an accelerometer is important because it ensures that the device is accurately measuring acceleration. Over time, environmental factors and wear and tear can affect the accuracy of the accelerometer, so calibration helps to correct any errors and maintain its precision.
3. How do you align an accelerometer?
The process of aligning an accelerometer involves orienting it in a specific direction to measure the desired acceleration. This can typically be done by using a known reference point or axis and adjusting the accelerometer accordingly. Some accelerometers also have built-in alignment features that can assist in this process.
4. What factors can cause misalignment in an accelerometer?
Misalignment in an accelerometer can be caused by various factors, such as improper installation, external vibrations or shocks, and temperature changes. It can also occur due to the design or manufacturing of the device, where the sensitivity axes do not align with the physical axes.
5. How can you correct for misalignment in an accelerometer?
To correct for misalignment, the accelerometer can be rotated or translated to align with the desired axis. This can be done manually or with the help of calibration software. Some accelerometers also have the option to digitally adjust the sensitivity axes, allowing for precise alignment without physically moving the device.
  • Mechanics
  • Mechanics
  • Nuclear Engineering
