Graduate Rumors of Gravitational Wave Inspiral at Advanced LIGO | Sept 2015 Launch
The Advanced LIGO experiment, which began operations in September 2015, is rumored to have detected gravitational waves from a binary merger of two black holes, each approximately ten solar masses. Sources indicate that there may be multiple detections, with a significant press conference scheduled for February 11, 2016, to announce findings. The detection methodology involves matched-filtering of incoming signals against a database of templates, which is crucial for distinguishing genuine signals from noise. The implications of these findings could significantly constrain modifications to General Relativity in strong gravitational fields.
  • Understanding of gravitational wave physics
  • Familiarity with LIGO's detection methodologies
  • Knowledge of General Relativity and its implications
  • Basic concepts of black hole mergers and astrophysical phenomena
  • Research LIGO's matched-filtering technique for gravitational wave detection
  • Study the implications of gravitational wave detections on General Relativity
  • Explore the astrophysical significance of black hole mergers
  • Investigate the upcoming press conference details and findings from February 11, 2016
Astronomers, physicists, and researchers interested in gravitational wave astronomy, as well as anyone following advancements in astrophysics and the implications for General Relativity.
  • #121
More:
It seems like atom interferometers are the best possible tool to perform Gravitational Wave observations.
(Researchers are working on applying the same idea to molecules, which are even heavier than atoms, and thus have an even shorter DeBroglie wavelength which could be used for even more precise interferometry)
  • #122
The true sensation of the discovery is the engineering masterpiece!
  • #123
bcrowell said:
This isn't going to work. The rate of radiation of gravitational waves is proportional to the frequency raised to the 6th power. The period of rotation of a galaxy is on the order of 10^8 years, so the frequency is extremely small.
Additionally, because the frequency is so small, one needs to listen for hundreds of millions of years to see a wave. So this is impossible on two grounds: there's not enough energy to see it. and there's not enough time to see it.
And (to sanman):
PAllen said:
You seem to have the syndrome "if you have a hammer everything looks like a nail".
+1
It's interesting how, right after a discovery, there are a bunch of messages of the form, "I know how to do this better!"
Likes fresh_42
  • #124
Tphysics said:
I have a question about how they were able to detect the gravitational wave. They say they have two different sites approx. 4000 km away from one another. If the size of the wave is one tenth of a electron-mass how did both sites detect the wave came through?
The wave hit the whole galaxy (and much larger structures) in a uniform way. The amplitude (the relative change in distance) is tiny, but it is the same amplitude everywhere.
Comparing the amplitude of gravitational waves to masses does not make sense.
sanman said:
Would it at least be possible to artificially generate Gravitational Waves - very tiny ones, obviously - and detect them using a detector like LIGO or like an Atom Interferometer? Even though Man-made Gravitational Waves would be far, far smaller than those from astrophysical phenomena like Black Holes, at least any attempts to measure them would be done at distances far, far smaller than the distant Black Holes that LIGO has been getting signals from. Wouldn't the far lower distance offset the fact of the smaller amplitudes, to make detection feasible? I was just imagining that if Gravitational Waves could be harnessed for communication purposes, then there'd be no need for satellite relays and such. We could have direct communication between Earth and Mars even when both are on opposite sides of the Sun.
The strain from artificial gravitational waves at the boundary of what can possibly be produced on Earth is something like 15 orders of magnitude smaller than what LIGO can measure. I don't say it is impossibe, but it is way beyond the capabilities of even the keenest proposals today.
  • #125
sanman said:
Since the atom is more massive than the photon, it has a much lower DeBroglie wavelength, thus allowing much greater precision in interferometry. Photons were turned into coherent light long ago with the invention of the laser. The more recent invention of the BEC has led to the "atom laser" and atom interferometry.
The atom interferometer can be a much more compact device than the huge LIGO, and could be launched into space (perhaps to a LaGrange Point). It can have far greater precision/sensitivity, and would also be much less expensive to build.
Thanks, very interesting. However, it changes nothing else I said.
  • #126
That's what I thought, too. Hence the comment in my post #21:
DiracPool said:
My guess is that they measure these tolerances so closely because they are using an interferometer running an extremely high frequency/small wavelength and that they have a technique to measure extremely small phase discrepancies.
But then after reading the article it looks as though they optimize the readings at extremely low frequencies/long wavelengths, as in roughly 100 Hz.
https://dcc.ligo.org/public/0122/P150914/014/LIGO-P150914_Detection_of_GW150914.pdf
"In their most sensitive band, 100–300 Hz, the current LIGO detectors are 3 to 5 times more sensitive to strain than initial LIGO [67]; at lower frequencies, the improvement is even greater, with more than ten times better sensitivity below 60 Hz."
Maybe I'm reading this wrong, but I'm guessing the frequency doesn't matter so much as it is their ability to detect minute differences in the phase. If you took at the timeplot of the inspiral event, it too looks to be on the order of 100 Hz or less.
  • #127
bcrowell said:
A maximum-entropy big bang, which is the most overwhelmingly likely possibility, would have had its gravitational degrees of freedom equilibrated with all the other degrees of freedom
I have been wondering: to what extent is this consensus science, and to what extent Roger Penrose's pet ideas?
  • #128
You could compare, for example, with this article:
Callender, Craig, "Thermodynamic Asymmetry in Time", The Stanford Encyclopedia of Philosophy (Fall 2011 Edition), Edward N. Zalta (ed.), http://plato.stanford.edu/archives/fall2011/entries/time-thermo
This is a topic on which many people on the internet spout a huge amount of nonsense, and that may have contributed to your doubts. Among people who actually understand the topic, AFAIK there is no controversy on the description I gave in #96. If you want to have a serious discussion on this, we should really start a separate thread.
  • #129
In the Arxiv's today.
arXiv:1602.03842
The Rate of Binary Black Hole Mergers Inferred from Advanced LIGO Observations Surrounding GW150914
B. P. Abbott, R. Abbott, T. D. Abbott, M. R. Abernathy, F. Acernese, K. Ackley, C. Adams, T. Adams, P. Addesso, R. X. Adhikari, V. B. Adya, C. Affeldt, M. Agathos, K. Agatsuma,N. Aggarwal, O. D. Aguiar, L. Aiello, A. Ain, P. Ajith, B. Allen, A. Allocca, P. A. Altin, S. B. Anderson, W. G. Anderson, K. Arai, M. C. Araya, C. C. Arceneaux, J. S. Areeda, N. Arnaud, K. G. Arun, S. Ascenzi, G. Ashton, M. Ast, S. M. Aston, P. Astone, P. Aufmuth, C. Aulbert, S. Babak, P. Bacon, M. K. M. Bader, P. T. Baker, F. Baldaccini, G. Ballardin,S. W. Ballmer, J. C. Barayoga, S. E. Barclay, B. C. Barish, D. Barker, F. Barone, B. Barr, L. Barsotti, M. Barsuglia, D. Barta, J. Bartlett, I. Bartos, R. Bassiri, A. Basti, J. C. Batch,C. Baune, V. Bavigadda, M. Bazzan, B. Behnke, M. Bejger, C. Belczynski, A. S. Bell, et al. (901 additional authors not shown)
Comments: 16 pages, 6 figures, submitted to ApJL
Subjects: High Energy Astrophysical Phenomena (astro-ph.HE); General Relativity and Quantum Cosmology (gr-qc)
A transient gravitational-wave signal was identified in the twin Advanced LIGO detectors on September 14, 2015 at 09:50:45 UTC (GW150914). To assess the implications of this discovery, the detectors remained in operation with unchanged configurations over a period of 39 d around the time of the signal. A search of 16 days of simultaneous two-detector observational data found GW150914 to have a false alarm probability (FAP) of $2 \times 10^{-7}$. Parameter estimation followup on this trigger identifies its source as a binary black hole (BBH) merger with component masses $(m_1, m_2) = 36^{+5}_{-4}, 29^{+4}_{-4} \, M_\odot$ at redshift $z = 0.09^{+0.03}_{-0.04}$. Here we report on the constraints these observations place on the rate of BBH coalescences. Considering only GW150914, assuming that all BBHs in the universe have the same masses and spins as this event, imposing a false alarm threshold of 1 per 100 years, and assuming that the BBH merger rate is constant in the comoving frame, we infer a 90% credible range of $2-53 \, \mathrm{Gpc}^{-3} \, \mathrm{yr}^{-1}$ (comoving frame). Incorporating all triggers that pass the search threshold while accounting for the uncertainty in the astrophysical origin of each trigger, we estimate a higher rate, ranging from $6-400 \, \mathrm{Gpc}^{-3} \, \mathrm{yr}^{-1}$ depending on assumptions about the BBH mass distribution. All together, our various rate estimates fall in the conservative range $2-400 \, \mathrm{Gpc}^{-3} \, \mathrm{yr}^{-1}$.
  • #130
If you replace the $ by ##, TeX gets rendered properly.
  • #131
One question looms in my mind, now that GR has gained this validation, what does that mean for other existing theoretical frame works? Will science focus more on expanding on GR or continue looking for other theories to complete the standard model?
Just curious about others opinions/ thoughts.
  • #132
PAllen said:
There is a class of quantum gravity approaches (based on a variant way of handling spin 2 quantization, put forward by a few Russian physicists), that had a specific prediction (yeah!) that collapse would stop signficantly before horizon formation (as I recall, close to the photon sphere of classical GR). Presumably this result (along with increasing reliability of horizon / mass observations) completely kills this approach (the downside of a specific prediction). It probably kills most any approache that suggests the QG effects diverge from classical GR outside the horizon.
Or the effects outside the non existent horizon may just be be small, eg. Mathur's fuzzball.
"7.8 Do fuzzballs look the same as the traditional black hole outside the horizon?
Thus outside the fuzzball the non-sphericality effects fall off very fast, and we see an effectively spherical geometry."
http://www.physics.ohio-state.edu/~mathur/faq2.pdf
  • #133
GR has long been validated at low energies, but remains problematic at high energies. It is at high energies that theories are still needed to complete GR and the standard model.
The direct detection of gravitational waves is first of all a beautiful experiment, because the prediction is beautiful and the measurement at the limits of precision. Secondly, it will allow us to see many more low energy events that were previously hard to see, such as black hole mergers.
Likes nsaspook and gjonesy
  • #134
I agree. There is no impact on a theory like this, and I quite like the fuzzball idea.
  • #135
Does the data underlying LIGO's detection of gravitational waves allow us to say anything new about gravitons?
IH
  • #136
IH
It allows to set an upper limit on the mass, but indirect constraints from the effect of gravity on large scales are still better than those upper limits.
  • #137
All under the assumption that gravitons exist ...
  • #138
Hi All,
Very excited with this result, but with some basic doubts.
1) do gravitational waves travel with the velocity of light?
2) was the velocity of the gravitational wave determined in this experiment?
3) was it that the staff at LIGO have brought the supposition of merging BH after analysing the oscillations observed in the interferometers? Was it then a plausible cause for the oscillations?
4) If one is stuck in the Newton's formula and accepts the relativity postulate of velocities no larger than c, this person would agree that fastly oscillating the position of a highly massive object would imply the propagation of a "gravitational" wave, measurable at great distances. Is this correct?
Best wishes,
DaTario
  • #139
Well, sure, but it seems likely.
All measurements are pointing towards this, but there is no direct speed measurement yet.
No.
They computed signals for hundreds of thousands of different scenarios in advance, and then compared the observed signal to those calculations. Two merging black holes fit, all other things do not fit. They also checked this based on the signal afterwards.
Newton's formula and a finite speed of light are incompatible. They just do not work together.
  • #140
I agree that Newton's formula doesn´t have included this principle. But is it plausible to speculate that our calculations with gravity must deal, from now on, with retarded potentials or similar resources ?
  • #141
mfb said:
We'll know more in a week.
A loss of three solar masses in the merger would correspond to a power above 1046 W (probably much higher), the most powerful event we ever saw.
The combined luminosity of all stars in the observable universe is about 1049 W.
Is this equivalent to the annihilation of three solar masses worth of matter in an instant? Was such energy release predicted by present models of BH merger/collision or is this a new phenomenon?
IH
  • #142
Yes.
It was predicted. Without these enormous energies, the signal wouldn't be strong enough for LIGO to see, and we would never have built it.
  • #143
Where does the spin 2 prediction come from?
  • #144
I'm going to disagree a little with mfb on point (2). He's correct that this experiment doesn't measure the speed of gravity. However, there is still information. The speed of gravity has to be less than the distance between Richland and Livingston, which is about 1850 miles, divided by the difference in time, which is less than 10 ms. So that gives as a ballpark estimate of within a factor of a few of 185,000 miles per second.
So, while a single measurement is not very constraining, it shows that the speed of gravitational radiation is of the same order as the speed of light.
Likes mfb
  • #145
This nature article mentions that other interferometers such as Geo600 in Germany and Virgo in Italy were not operating at the time . Is it known whether Geo600 would have detected the gravitational waves?
What happens with gravitational waves? Do they exist forever or can they be absorbed or transformed?
  • #146
I've been lurking on the thread about this fascinating announcement but this question got me to wondering. Can gravity waves be theoretically affected by gravitational lensing? My guess would be that they are but I don't know the details enough to know.
Edit: It seems that I'm wrong.
PAllen said:
Matter (dark or not) between us and a GW source is invisible to the GW.
  • #147
This depends on what you mean by "annihilation".
Three solar masses worth of energy were converted to the energy of gravitational waves, which are "invisible" (they interact very weakly).
The "annihilation" as in matter-antimatter reaction would generate electromagnetic radiation (gamma rays), not gravitational radiation.
  • #148
True; what I was trying to gauge was the value of energy release. From Phyzguy's reply I take it that the energy is the same as that released if we were indeed taéking about matter-antimatter annihilation.
IH
  • #149
His statement is not about the gravitational lensing. It is about how the GW would interact with matter and dark matter.
Likes Borg
  • #150
Right. I have no knowledge of an analysis of lensing for GW; it is a great question. A purely heuristic argument to expect it is that if GW travel at c, and can be treated similar to the EM geometric optics approximation of treating a piece of the wave front as having a world line, then that world line ought to be a null geodesic. Then, the lensing would be basically the same as light. But this is just a general argument - I would not be very confident in it without more analysis or information.
Likes Borg
  • · Replies 66 ·
  • · Replies 27 ·
