Advice for the design of an automatic door opener
  • Thread starter Thread starter cherrycoke
    Automatic Design
The discussion focuses on the design of an automated trap door opener that incorporates a motor and mechanical components such as gears, springs, or power screws. Participants explore various design considerations, including power requirements, mechanical configurations, and the specific constraints of the door's dimensions and operation.
  • One participant outlines the specifications of the trap door, including dimensions, weight, and required opening angle and time.
  • Another participant requests initial sketches and calculations to better understand the design approach.
  • Some participants suggest using a linear actuator but express concerns about its speed and range of motion.
  • There are references to external resources, including a link to a design on Thingiverse, although its applicability to a vertical trap door is questioned.
  • One participant proposes using a right angle gear motor, suggesting either a worm gear box or helical type for the design.
  • Questions arise regarding foot traffic on or around the trap door when closed, indicating potential safety considerations.
Participants express differing views on the suitability of linear actuators for the design, with some suggesting alternative motor types. There is no consensus on the best approach to achieve the desired functionality, and several ideas are presented without resolution.
Participants note potential assumptions in calculations and design approaches, such as the loading conditions for vertical versus horizontal operation. There is also a mention of a possible confusion regarding the units used in the design specifications.
cherrycoke
Hello all,
I need to design an automated trap door opener incorporating a motor and at least one of the following: gears, springs, or power screws. It is 36 inches wide and 48 inches long. It is hinged along its width. The door weighs 60 pounds. When closed it is flush with the floor. It must rotate to 110 degrees when opened in 20 seconds.
I've calculated how much power I would need to rotate the door at the angle and time constraint, but I do not know how to execute the design. I was thinking of using a linear actuator but I'm not sure how to incorporate that with the wide opening angle of the door. Linear actuators I have seen used to open doors so far have opened too slowly and at most 90 degrees.
Any help would be appreciated, thank you !
cherrycoke said:
Hello all,
Welcome to the PF.
Can you post your initial sketches and calculations? :smile:
Hello,
I hope the image attachment works. Here is my attempt at a kinematic approach first to find what HP motor I needed. Please let me know if I made wrong assumptions. Thank you!
bsheikho said:
But that opens horizonatally, so the loading on the motor and opener are pretty light. He is asking about opening a trap door vertically, no?
True, though I don't see how this concept can't be applied vertically with a stronger motor.
Its basically how all windows open, use rotary motion to swing open the windows.
That example is a bit more complicated with a rail and bushing,
Is there any foot traffic on or around the top area of the trap door when it is closed.
Right angle gear motor is enough either worm gear box or helical type
You mentioned the size of the door as 36 in x 48 in but in your image it is in 'ft'
  • · Replies 21 ·
9K
9K
18K
