Against "interpretation" - Comments
343 replies · 38K views
@Demystifier , where do you see distinctions like Hamiltonian and variational methds, versus forces and Diff.. Eq. ?
Auto-Didact said:
How about
T1 Frequentist statistics
T2 Bayesian statistics
They are not physical theories. They are mathematical tools that share some similarities but make fundamentally different statements.
Yes, those could also be thought of as different theories with identical measurable predictions.
martinbn said:
I expected a non quantum example. So, you have in mind only QM interpretations, and you think they should be called theories. My opinion is that they are correctly called interpretations. The all start with QM or at least the core of QM, then add a bit more, yet don't get new predictions. To me that is not a different theory. To be a different theory it should build on something else, it should be possible to get to that theory even if you have never seen QM. And that is not the case of the interpretations.
For a non-quantum example see my post above. In your terminology, they would not be different theories too.
The problem with your terminology is that it is ambiguous. For instance, Schrödinger developed his wave quantum theory without referring to the Heisenberg matrix quantum theory. It was only later realized (by Dirac) that they were equivalent. Would you say that Schrödinger QM and Heisenberg QM are different theories?
fresh_42 said:
a theory - or model - is a mathematical framework to describe the experimental results, including possible predictions. On the other hand, an interpretation is merely an informal description of named theory / model to describe the mathematical framework in common language and by the frequent use of aphorisms and metaphors.
I think @fresh_42's comment #3 puts it in a nutshell. Regarding quantum mechanics and the interplay between theory and interpretation, the following is said by Hans Primas in his book “Chemistry, Quantum Mechanics and Reductionism, Perspectives in Theoretical Chemistry”:
“It is tempting, but mistaken, to believe that we can use the formalism of quantum mechanics without entering into a discussion of its interpretation. Only interpreted mathematical formulas express laws of nature, the interpretation gives a physical meaning to the mathematical symbols used. Interpretations never are inherent in the formalism but must be assigned to it. Mathematical construction is such a marvelously effective creative principle that the formal structure of a new theory may be arrived at prior to the establishment of a consistent interpretation. That is, we may be confronted with the amazing situation that we know and can use the mathematical equations of a new theory without exactly knowing what they mean. Pioneer quantum mechanics is an example: it is the most controversial theory we have and even today no general agreement exists on its interpretation [compare for example the review given by Jammer, 1974).”
Demystifier said:
Some versions of BM do, but the standard "minimal" version doesn't.
But isn't one difference that the minimal version allows a measurement to be reversed in principle but not FAPP, whereas Copenhagen does not allow a measurement to be reversed in principle and FAPP since its principle is FAPP.
Also, is the equivalence of minimal BM and Copenhagen exact, or does minimal BM have small but FAPP unmeasurable differences from Copenhagen?
Thinking about the Wilson case, many expositions say that Wilsonian renormalization does produce terms different from old fashioned renormalization, but the differences are too small to be measured. So if one uses theory to mean exact equivalence, then Wilsonian renormalization is a different theory. However, since interpretation is also supposed to have the meaning of "solving a common sense problem with the theory (measurement for Copenhagen QM or nonsensical subtraction of infinities for old-fashioned renormalization", I would like to say Wilsonian renormalization is both an interpretation (solves the conceptual problem) and a different theory.
BM is observationally equivalent to Copenhagen only in the FAPP sense.
Can you give a reference for an exposition saying that Wilsonian renormalization produces terms different from old fashioned renormalization?
For that reason, I think even if one is not against "interpretation", minimal BM can be considered a different theory. In contrast, the Newtonian, Lagrangian, and Hamiltonian formulations would be identical even in principle so they are the same theory. Similarly, the Schroedinger and Heisenberg pictures are the same theory.
http://www.solvayinstitutes.be/pdf/doctoral/Adel_Bilal2014.pdf (p69)
Theories like QED are presently thought to be only effective theories ... Such an effective theory then has an effective Lagrangian obtained by “integrating out” the very heavy additional fields that are present in such theories. This necessarily results in the generation of (infinitely) many non-renormalizable interactions ... From the previous argument it is then clear that at energies well below this scale these additional non-renormalizable interactions are completely irrelevant, and this is why we only “see” the renormalizable interactions. Our “low-energy” world is described by renormalizable theories like QED not because such theories are somehow better behaved, but because these are the only relevant ones at low energies: Renormalizable interactions are those that are relevant at low energies, while non-renormalizable interactions are irrelevant at low energies.
Brilliant insight atyy! :approve:
What in principle predictions does BM make that are not equivalent to predictions of Copenhagen?
In principle, Bohmian particles may be far from the quantum equilibrium, in which case the probabilities of measurement outcomes can be totally different.
This reads as an attempt to legitimize alternative 'interpretations' to Copenhagen such as dBB, referred to as nonsense by some of the founders of QM, e.g.
The term 'Copenhagen interpretation' suggests something more than just a spirit, such as some definite set of rules for interpreting the mathematical formalism of quantum mechanics, presumably dating back to the 1920s. However, no such text exists, apart from some informal popular lectures by Bohr and Heisenberg, which contradict each other on several important issues[citation needed]. It appears that the particular term, with its more definite sense, was coined by Heisenberg in the 1950s,[4] while criticizing alternate "interpretations" (e.g., David Bohm's[5]) that had been developed.[6] Lectures with the titles 'The Copenhagen Interpretation of Quantum Theory' and 'Criticisms and Counterproposals to the Copenhagen Interpretation', that Heisenberg delivered in 1955, are reprinted in the collection Physics and Philosophy.[7] Before the book was released for sale, Heisenberg privately expressed regret for having used the term, due to its suggestion of the existence of other interpretations, that he considered to be "nonsense".
https://en.wikipedia.org/wiki/Copenhagen_interpretation#Origin_of_the_term
Calling alternatives such as dBB which steal equations from QM (valid only in the non-relativistic limit of all things, a galling thing to do) and then postulate those stolen equations as axioms only to then (gallingly) use them to contradict the most fundamental claims about QM (paths not existing), I mean it is correct to say this not an 'interpretation' but rather it's own separate theory analogous to the theory of angels causing quantum weirdness who give us Schrödinger equations that only work non-relativistically... The fact that one is led to do things like deny things like relativity as fundamental https://www.physicsforums.com/insights/stopped-worrying-learned-love-orthodox-quantum-mechanics/ and rationalize away such basic, basic, concepts of physics should prove to most people why words like "nonsense" for these alternatives are appropriate.
If you want to take that road: Einstein, Schrödinger, Born and Dirac all spoke out against QM as being incomplete, tentative or in need of revision; moreover, Dirac also rightfully criticized QFT.
In fact, Madelung published his equations (Nov 1926) a month before Schrödinger (Dec 1926). But arguing about priority is childish nonsense.
Yeah, just like how Newton being 'obviously correct' for two centuries invalidated Einstein's attempt to rewrite the canon of physics... oh wait.
Actually, being unable to make theoretical leaps in order to progress may only be the sign of a cautious and preservative mind; however prohibiting others from doing so and even going so far as to ridicule those who boldly do is what distinguishes the real ignoramuses from the mere cowardly.
Indeed. QED is even thought to be trivial, but I do not think anyone has proven it rigorously. If so that is strong evidence it could only be an effective theory - and of course we now know it is since its part of the electro-weak theory at high enough energies.
Is the elctro-weak theory trivial - that is something I have not seen anything written about - but my guess is probably.
Thanks
Bill
Auto-Didact said:
(Snip) Schrödinger (Dec 1926) (snip).
Do you mean the paper published in January 1926? “Quantisierung als Eigenwertproblem. Erste Mitteilung” (Quantization as a problem of proper values, part one), which he sent to the Annalen der Physik on 26 January 1926. In this paper, he first formulated his famous wave equation...” https://www.uzh.ch/en/about/portrait/nobelprize/schroedinger.html
He indeed derived it back in 1925 and published it quite early on. But as I said, arguing about priorities is childish especially seeing the extensive influencing the early founders had on each other (including Planck, Einstein, de Broglie et al.).
Claiming that the import of a mathematical equation from one theory into another - upon which the equation is then naturally expanded upon by using a more general form of the same type of mathematics (differential equations) - is theft is pure ludicrous, especially seeing BM was first formulated by de Broglie.
To get back on topic: orthodox QM has several problems; however, from both a pure mathematical point of view as well as the mathematical physics point of view, the most important problem is the ad hoc nature of the Born rule as an axiom; no other canonical physical theory formulated as a set of differential equations has such problems. Even worse; in fact all ad hoc procedures (e.g. stationary principles) in classical canonical physics can be shown to be a necessary consequence i.e. derived purely mathematically from first principles from a more complete formulation of the differential equations.
Somehow most physicists - not being sufficiently trained to recognize proper canonical forms of differential equations based on their symplectic geometric formulation - don't take this mathematical issue seriously, instead ranting on about the fundamental importance of symmetries. For mathematicians and mathematical physicists however - especially those well versed in algebraic geometry, algebraic topology, differential geometry and complex manifolds - this is as clear as daylight.
The inability to derive the Born rule from the theory, i.e. directly from the differential equations, actually makes orthodox QM a disjointed mathematical framework. This remains a fact regardless of any reformulations using or invocations of matrices, operator algebras and/or Hilbert space; none of these help in this matter, they only make matters worse by enabling physicists to confuse the map for the territory. Moreover, going to many-body QM or QFT does absolutely nothing to solve this mathematical problem.
If a differential equation cannot be understood and solved immediately, this implies that it has somehow been stated in an implicit form which hides essential properties of the equations through unwanted algebraic simplification; this means that the equation is actually incomplete, which is no shame in itself. There are in fact many incomplete differential equations which took several decades if not centuries to be properly understood and many more which have remained so to this day.
In contrast to what physicists often claim, a differential equation not being complete is not merely a mathematical problem, but also distinctly a fundamental physics one. The way these differential equations are completed is by algebraically rewriting the incomplete implicit form into a more complete explicit form; this for example is also how Dirac derived his equation from first principles. It is not an exaggeration to say that rewriting differential equations into more explicit forms is almost the entire history of theoretical physics in a nutshell.
What is important to note is that each rewriting of an implicit differential equation can have different subsequent completions and extensions which need not be immediately consistent with each other; differential equations are like different species, they often need to be analyzed and dissected before their relation to one another becomes more clear. This is why understanding differential equations is so hard, i.e. why theoretical physics is so difficult: there is no clear foolproof route forward, only careful reasoning, mathematical experimentation and intuition.
If physicists on the other hand however choose not only to forego completing the equation, but instead go on to claim that the equation actually requires additional axioms in order to be able to interpret it, it is a signal that something has gone terribly wrong. Even worse, if they then proceed to claim that invoking new axioms in order to be able to interpret equations is proper practice, it means that they either lack mathematical insight, theoretical standards or both.
Those who today still continue to say and think that the Schrödinger equation, stated in the implicit standard form, actually precludes the existence of the Bohm quantum potential, which was always already there in the more explicit Madelung form, are as misguided as those who say that the electromagnetic potential in electrodynamics is just a mathematical trick with no actual physical existence. This is why BM is actually practically a different theory from orthodox QM: it is the most natural direct mathematical completion of orthodox QM - similar to adding the cosmological constant to the Einstein field equations - instead of an extension such as Dirac theory.
In contrast to orthodox QM, BM derives Born's equation from first principles i.e. from within the theory as part of the differential equations without any special pleadings or unwarranted axioms. The derivation is very similar to reformulating the Maxwell equations into a more brief and more symmetric form by restating everything in terms of the electromagnetic potential; this automatically makes BM a fundamentally more coherent mathematical framework than the disjointed mess that is orthodox QM.
The fact that you think "BM derives Born's equation from first principles i.e. from within the theory as part of the differential equations without any special pleadings or unwarranted axioms" completely explains why you think the Schrödinger equation in BM is not simply stolen from QM.
Please go and read Bohm's original papers (http://cqi.inf.usi.ch/qic/bohm1.pdf) and show me where he derived the Schrödinger equation - you won't find it because he didn't, he assumed it out of thin air, which is what many BM sources do. The ones that try harder try and derive it from something along the lines of these here https://en.wikipedia.org/wiki/De_Broglie–Bohm_theory#Derivations which are either complete nonsense (to be explained in a moment) or are using concepts that assume standard Copenhagen QM (I mean really, ##p^{\mu} = \hbar k^{\mu}## as your starting point, where do these strange concepts of energy or momentum even come from? and we are talking about a theory that is not a 'disjointed mess') and so defeat the whole purpose of BM, i.e. to save classical physics and deny what science actually tells us...
The fact that you think we need to formulate theories in terms of differential equations is to unavoidably assume that classical paths must exist, and so to literally deny/misunderstand the most basic claim of QM that paths don't exist - if paths don't exist, all of classical physics is wrong and we have absolutely nothing...
All we can say before the Born rule is that paths don't exist because that's what experiments tell us, and therefore that classical theories (non-relativistic and relativistic) are wrong, and so we literally have nothing... The very fact you think we should be able to derive the Born rule illustrates an extremely fundamental misunderstanding of what QM says - if the very first thing it says is that path's don't exist, and so without paths we have nothing, the idea we need to derive the premise on which the whole theory is built is simply shocking, if properly understood it's like saying we need to derive F = ma or the principle of least action from nothing... In order to state something to build a theory we need to admit that we have the existence of classical mechanics in 'some sense', i.e. the to-be-defined quasi-classical limit, and so try to merge the fact that paths don't exist in experiments with paths existing in some approximate sense which leads to needing what we call the Born rule, which is why QM is so nuts - we unavoidably need classical mechanics to formulate it.
Without standard QM you are literally banned from using concepts like wave functions as if they were fundamental, it is simply madness to even think of something like a wave function if the notion of a path exists in any sense, nothing but a decision to ignore inherently obtainable information for no reason, and the ironic reason for this is differential equations, which tell us that if particles follow any kind of path at all in any sense, we should be able to predict the path no matter what the equations which control it's motion are because it's just basic mathematics - just because Newton and Einstein got the force laws (i.e. part of the ode's) allowing us to predict the motion wrong, if the paths exist in any sense, you'd have to deny differential equations if you want to pretend we can never know what the path was for some given special example, which is why said 'derivations' of the Schrödinger equation are complete nonsense, the idea that these random concepts like wave functions should mean anything if paths exist is simply human bias, of course it's a bias motivated by BM'ers trying to copy orthodox QM because they have to for unexplained reasons despite the fact that they should be able to do way more fundamental things like actually predict paths if what they claimed made any sense... In other words, there are good reasons why the founders made such bold claims about complementarity e.g. paths not existing and why this is all they could come up with without committing basic logical errors...
Landau's QM spends a good few pages stressing the technical points here, I don't know how anybody could try and imply that orthodox QM is flawed because the Born rule can't be found via differential equations if they understood the very first claim of QM is that paths simply don't exist so that no differential equation could ever dictate it's most fundamental claim...
Even more laughable is the idea that a quantum theory which fails so spectacularly at dealing with relativity is "a fundamentally more coherent mathematical framework than the disjointed mess that is orthodox QM", as I've already pointed out one of the ways people claim to be able to do this is to literally deny that special/general relativity is more fundamental non-relativistic classical mechanics, this should be beyond shocking, yet in here we are implying this is "more coherent"?
Finally, the reason physicists are "ranting on about the fundamental importance of symmetries" is because without symmetries we can do almost nothing, e.g. without Galilean symmetry we can't go far beyond the statement of the principle of Least action in non-relativistic mechanics, and ironically in QM you can't derive the non-relativistic Schrödinger equation BM'ers seem to think is all of reality, and it's merely the failure of Galilean symmetry that leads to special relativity, with both Galilean and Einsteinian relativity based on the primitive notion of a path existing, unlike QM... (Again, all in Landau).
So yes, BM is "actually practically a different theory from orthodox QM" because it begins by contradicting the most basic claim QM makes and then tries to still get the results of the theory it denies by assuming it's equations out of thin air, it's no wonder people like Heisenberg used words like "nonsense" for alternatives this logically flawed, with the relativity denial issues taking this over the top. These are the kinds of serious flaws that an essay like this is trying to legitimize...
Have you seen chapter 3 of Ballentine where its derived from probabilities are frame independent? If so can you elaborate on how it fits in with the above?
Thanks
Bill
Gleason's Theorem? It of course depends on non-contextuality. But that is hardly ad-hoc - its very natural.
IMHO QM is very very elegant, not a disjointed mess. What it means is another matter, but the theory itself is very elegant. If you accept Gleason (ie non-contextuality) it all follows from just one axiom as shown in Ballentine.
Thanks
Bill
Thanks
Bill
My post said "without Galilean symmetry... you can't derive the non-relativistic Schrödinger equation BM'ers seem to think is all of reality", chapter 3 of Ballentine is mostly about applying Galilean symmetry in the edition I have seen anyway.
Yes - without something to be symmetrical in you can't apply symmetry. That's is the paradox about physics relation to symmetry despite its fundamental importance.
Thanks
Bill
bhobba said:
Yes - without something to be symmetrical in you can't apply symmetry. That's is the paradox about physics relation to symmetry despite is fundamental importance.
Thanks
Bill
I would love to see that chapter re-written as though it were directly a non-relativistic version of Weinberg's QFT chapter 2 :DD
But what about comments like:
http://www.staff.science.uu.nl/~hooft101/lectures/basisqft.pdf
"Often, authors forget to mention the first, very important, step in this logical procedure: replace the classical field theory one wishes to quantize by a strictly finite theory. Assuming that physical structures smaller than a certain size will not be important for our considerations, we replace the continuum of three-dimensional space by a discrete but dense lattice of points ... If this lattice is sufficiently dense, the solutions we are interested in will hardly depend on the details of this lattice, and so, the classical system will resume Lorentz invariance and the speed of light will be the practical limit for the velocity of perturbances."
https://arxiv.org/abs/1106.4501
"Since, emergent rotational and translational symmetry and locality of couplings is both common and familiar, let us start by assuming we have a continuum quantum field theory with these properties, but without insisting on Lorentz invariance ... This problem is quite general in weakly coupled field theories for multiple particle species, but at strong coupling the flow to Lorentz invariance can be robust."
Can one also get small deviations under the assumption of quantum equilibrium? In QM, when one shifts the cut to include the measurement apparatus, for example in decoherence or in the Hay and Peres paper https://arxiv.org/abs/quant-ph/9712044, one seems to find small deviations from QM with a smaller quantum system (ie. when the quantum side excludes the measurement apparatus). So in a sense, it seems that QM with different cuts is also in principle different theories. Since BM uses decoherence, could one argue that BM like QM with a bigger quantum system also has small deviations, even if quantum equilibrium is not violated? Thus if QM is not the same theory as QM, then BM is not the same theory as QM.
@Auto-Didact I know you that you've already written a long post, but can you be a bit more specific. You are using a lot of phrases that I personally find hard to guess what they mean. For example what is a canonical form based on symplectic geometric formulation, say what is that for the heat or the Laplace equations? What is the problem with having axioms such as the Born rule? What is an implicit form of a differential equation and why is the Schrödinger equation implicit? Generally what makes the Schrödinger equation so different from any other to say that the theory has a problem? What does it mean for a differential equation to be incomplete/complete? And what does it mean to complete it? Say why is the Schrödinger equation incomplete and why are the equations from classical physics complete?
Thanks
Bill
It's a genuinely uncertain issue. There are known cases where adding an ##SU(2)## gauge field to otherwise trivial theories renders them non-trivial and there are numerical simulations and simplified or limiting theories suggesting this might be what occurs in the Electroweak theory. So we currently don't actually know if the standard model is trivial.
A good intro to this stuff is still:
D.J.E. Callaway, Triviality pursuit: can elementary scalar particles exist? Phys. Rep. 167(5), 241–320 (1988)
One thing needs to be made crystal clear: the argument I'm making is as I said from a pure mathematics or mathematical physics viewpoint. All physical theories can and have been judged from this viewpoint, and its criteria are different from those of regular and theoretical physics because their respective direct goals and intentions are truly different.
This is why I made the distinction 'as a mathematical framework' instead of saying 'as a physical theory'; this distinction is not vacuous, instead it is where the very notion of a theory being fundamental or not comes from in the practice of physics. Notice that many theoreticians today have turned this notion on its head and instead just subjectively reserve the right to claim fundamentality for their particular viewpoint; such anarchy is exactly what happens once physicists decide to forego the prime role of bestowing upon mathematical physics the task of identifying what is fundamental.
It is not my viewpoint, it is a standard one in mathematical physics, because historiclly almost all more fundamental mathematical reformulations were discovered from within this very viewpoint of practicing mathematical physics.
bolbteppa said:
Please go and read Bohm's original papers (http://cqi.inf.usi.ch/qic/bohm1.pdf) and show me where he derived the Schrödinger equation - you won't find it because he didn't, he assumed it out of thin air, which is what many BM sources do. The ones that try harder try and derive it from something along the lines of these here https://en.wikipedia.org/wiki/De_Broglie–Bohm_theory#Derivations which are either complete nonsense (to be explained in a moment) or are using concepts that assume standard Copenhagen QM (I mean really, pμ=ℏkμpμ=ℏkμp^{\mu} = \hbar k^{\mu} as your starting point, where do these strange concepts of energy or momentum even come from? and we are talking about a theory that is not a 'disjointed mess') and so defeat the whole purpose of BM, i.e. to save classical physics and deny what science actually tells us...
##p=hk## is just another way of stating the de Broglie wavelength, which was invented in 1924 before Schrödinger came up with his equation. Again, it is irrelevant what happened first: the mathematical veracity of equations do not depend on when someone first writes them down or for whatever reasons they were written down.
Experiments say nothing of the sort, it is an interpretation of the theory and experiment together which talks about the non-existence of paths.
Again it's not my own viewpoint, it is a legitimate standard viewpoint in the practice of mathematical physics.
The SE is just a (complex) differential equation, like all other differential equations; this means that it can be studied purely mathematically from within the theory of differential equations just like any other differential equation. The fact that the Born rule is mathematically derivable in this manner makes your point moot.
It is not shocking because all canonical physical theories, except for QM, were eventually able to be derived in such a manner, once reformulated into the specific mathematical framework in which the physical theory best fits (i.e. into vector calculus, or exterior calculus, or differential forms, or differential geometry, or bispinor calculus, or complex manifolds, etc) by the mathematicians and mathematical physicists.
The principle of least action is directly derivable from Stokes theorem; calculus of variations is not an independent framework but a direct consequence of not taking exterior calculus and differential forms to heart.
On the other hand ##F=ma## can actually be derived from experiment directly, just like ##E=h\nu## as Planck and Einstein did.
This is just one way of seeing it, i.e. an interpretation. It is however not merely an interpretation of an equation but an interpretation of methodology as well; i.e. it is a purely pragmatic FAPP philosophy. In terms of mathematical physics, such FAPP philosophies are unnecessary assumptions since the question to be answered in mathematical physics isn't a question to be answered FAPP, but instead a question to be answered in principle.
This is just pure hogwash. Wave functions are just mathematical objects, taken literally functions describing waves. They arise naturally not only in physics, but in all different kinds of manners in empirical and phenomenological science studied by applied mathematicians and/or non-physicist scientists.
The theory of differential equations absolutely says no such thing; what can and cannot be done depends on the class of the differential equation. It is a severe misapprehension of mathematics to think otherwise. It is not a non-trivial issue because the theory of differential equations is still a work in progress, meaning many physicists, focussed solely on applications, remain unaware of such issues.
Again what I stated applies to all of canonical physics, up to and including statistical mechanics, critical phenomenon, geometrodynamics, etc.
Opinion, not fact. Whether this opinion is popular among physicists says absolutely nothing about the veracity of the claim.
The reasons Bohr et al. made such strong claims were due to reasons of practicality and ignorance of more advanced mathematics; they were at the cutting edge in their time. Realizing that much more was left to be understood experimentally, physicists generally just ignored the problem in the foundations of QM for almost a century, merely pretending that these were resolved, which is why the foundational problems still haunts the theory until this very day.
However, someone today seriously making the exact same argument as Bohr et al. did a century ago just means that this person is just hopelessly out of touch with the progression of science and mathematics since then: it was justified then because there was more to discover and there was the hope the issue would resolve itself; more was indeed discovered but the issues have not resolved themselves. Playing make belief in the name of FAPP philosophy is fine until one hits a wall where experiment gets stuck; suffice to say, physics seems to have hit that wall since.
Easy, two different ways:
- by challenging the viewpoint made by Landau and Lifshitz; the books are good, stellar even, but not holy.
- by approaching the question from the point of view of mathematical physics instead of based on FAPP philosophy; this issue would necessarily arise sooner or later due to the mathematical problem of merging GR and QT.
That depends on the intent of the formulation. The intent in mathematical physics is to give QM a solid mathematical foundation instead of parroting FAPP philosophy; no one seems to question the non-FAPP intent of mathematical physics when Wightman et al. attempted to give a rigorous foundation of QFT. I'm guessing you would say that Newton-Cartan theory has absolutely no scientific merit either and studying it was a complete waste of time for physicists.
Making any theory consistent with relativity is another step in the process of building foundations; for BM this step is still a work in progress. You are pretending for some strange reason that all steps have to be taken at once, else thrown out immediately. This is a strange and overambitious methodology which can not possibly be rigorous enough to be seen as legitimate practice in fundamental physics.
That is a way, not the only way. And yes, it is still mathematically more coherent independent of whether it is the correct theory of nature. That is another question entirely! Fact: BM as well as Newton-Cartan theory are more coherent mathematical frameworks than orthodox QM. This just implies that mathematical coherence alone is not sufficient nor the best guide for judging the utility or veracity of a theory for physics; this is obvious, that role belongs to experiment.
Fact: all experiments done so far cannot distinguish between the outcomes of orthodox QM and BM.
Without symplectic geometry there is no principle of stationary anything. Working on BM as a project in terms of mathematical physics does not in any way imply that those who work on it believe it to be all of reality; that is just pure projection, which in fact sounds very much like a soundbite that a politician would make to smear his opponents.
I see no issue whatsoever with constructing intermediate mathematical frameworks in order to arrive at a new physical theory or in trying to formulate rigorous foundations where they are sorely lacking in an existing physical theory. The progression in the foundations of physics is not helped at all by physicists who believe that appealing to FAPP philosophy actually solves foundational problems, thereby giving them a license to bark at those actually attempting to solve such foundational problems.
I certainly agree with that. :biggrin:
Yes, the first communication article instead seems to be the article in question. Responding to a request in another thread here I’d linked a paper recently that discusses the first two of a number of his articles published in 1926, including the first communication article, hence some interest in the facts. The paper I recently linked also describes aspects of notions involved in the wave equation as misleading, hence less interest in primacies here : https://royalsocietypublishing.org/doi/pdf/10.1098/rsta.2017.0312.
