I Air flow from atmosphere into a tank
To determine the flow rate of air into a depressurized tank at 0.2 bar, the equations for viscous flow should be applied, as the mean free path is smaller than the vessel dimensions. The flow rate is influenced by the conductance of the pipe, which remains relevant whether the vacuum pump is on or off, as it relates to the pressure difference. When the pump is off and the valve is opened, the pressure inside the tank will change over time according to the flow rate, necessitating integration over time to solve the flow rate equation. This results in a simple exponential relationship between flow rate and pressure. Understanding these principles is essential for accurately modeling airflow into the tank.
JCB123
Hi,
I have a tank of air which has been depressurized to 0.2bar (absolute) via a vacuum pump, where air can be let in from atmosphere through pipework controlled by a valve. What would be the equation I can use to determine the flow rate into the tank with time? As the flow rate is determined by the pressure inside the tank, and the pressure inside the tank is determined by the flow rate.
Thanks
At any moment you will have a flow rate determined by the conductance of the pipe. You can read about that here:
https://www.pfeiffer-vacuum.com/en/...o-vacuum-technology/fundamentals/conductance/
At your pressures the mean free path is always smaller than the dimensions of the vessels, so you will use the equations for viscous flow and you will probably also want to assume the flow is laminar.
So that will give you flow rate as a function of pressure. However the flow rate can be related to the time derivative of pressure by the ideal gas law, so this will give you a first order differential equation in pressure which you can easily solve (you'll get a simple exponential)
Likes JCB123
JCB123 said:
Hi,
Thanks
Another good reference is "Building Scientific Apparatus" by John Moore which in addition to pumping also discusses just about everything of practical interest to the experimental physicist. I highly recommend it.
Thanks!
Does conductance only apply when the vacuum pump is switched on? If I switch off the pump and just open the valve to let the flow in, is it the equations for viscous flow I need to use?
JCB123 said:
Thanks!
The conductance applies for a difference in pressure regardless of how that is achieved. The difference between pump on and pump off is that without pumping the low pressure side will change pressure over time according to the flow rate dictated by the conductance. You therefore have to integrate over time. This integrates easily to a simple exponential.
Molecular flow vs viscous flow does not depend on pump on or pump off. It only depends on the pressure. At your pressures you will only ever use viscous flow.
Likes JCB123
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
