Air HES, Air Hydroelectric Station
  • Thread starter Thread starter aruseni
    Air
Air HES, or air hydroelectric station, is a new type of power plant currently in the research stage, aiming to provide green electricity and clean drinking water globally. If successful, it could revolutionize energy production, especially in arid regions. However, there are concerns about the feasibility of the proposed technology, particularly regarding fluid dynamics and flow rates in small tubes. Critics suggest conducting preliminary experiments to validate the design before further investment. Overall, the project holds potential but requires thorough testing and refinement.
aruseni
Air HES is air hydroelectric station. It is a new type of power plants which is now in research stage. If the experiments will succeed, people all around the World will get a source of completely green electricity and also clean drinking water (even in deserts and so on).
If you want to learn more about our science project, please check out our website: airhes.com
What do you think about this?
One non-technical comment: The writer of the website text has not learned to construct English sentences correctly.
There is no "above-mentioned Swiss HPS". (You should have an editor find and fix all your errors.)
And 450 mph sounds like a really extraordinary speed for water to be passing through a 3 mm tube over a distance of 2 to 3 kilometers.
I think your flow loses are going to be higher than you've estimated.
I would do an experiment with a 30 foot long, 3 mm tube, and check flow rates before I invested more. Or better yet, find the relevant fluid dynamics equations. They will give you ball park numbers. And best yet, they're free!
Balloon 500 m3 raises 500 kg
If you look at this site you balloon would need to be larger.
http://www.chem.hawaii.edu/uham/lift.html
A balloon containing hydrogen of 500 m3 would lift only about 200 kg from the site.
Have you been looking at the graph for hydrogen? The lift is 1.03 kg/m^3
according to that site.
Since the pressure of air is lower at an altitude, the air won't weigh as much.
You won't need more helium, because that expands as well, but the balloon
itself needs to be bigger
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
