Air pressure with Bernoulli's equation
The discussion focuses on applying Bernoulli's equation to calculate air pressure and net force on a flat roof due to wind. The correct approach involves setting P2 to 1 atm for accurate results, particularly in the context of question 2 regarding hurricane pressure. The calculations utilize the formula F = (P2 - P1) * A, where A is the area of the roof. The density of air is specified as 1.29 kg/m³, and the wind speeds are given as 30 m/s and 300 km/h (converted to 83 m/s).
  • Understanding of Bernoulli's equation and its application in fluid mechanics
  • Knowledge of pressure types: absolute pressure vs. gauge pressure
  • Familiarity with basic physics concepts such as force and area
  • Ability to convert units, specifically from km/h to m/s
  • Study the derivation and applications of Bernoulli's equation in fluid dynamics
  • Learn about the differences between absolute pressure and gauge pressure
  • Explore the concept of differential pressure in fluid systems
  • Review examples of calculating forces on surfaces subjected to fluid flow
Students and professionals in physics, engineering, and meteorology who are interested in fluid dynamics, particularly those studying the effects of wind pressure on structures.
pompey
Nevermind, I think I figured out why I needed to set P2 = 0 in the first problem. Actually, what I needed to do was set P2 = 1 atm, and when I calculated force, I needed to use F = (P2 - P1) * A to get the right answer.
So just ignore this...but here's the post anyway:
For anyone who has the book, giancoli 5th ed, pg 306 number 39 and 41.
Question 1: If wind blows at 30 m/s over your house, what is the net force on the flat roof if its area is 240 m^2.
Question 2: Estimate the air pressure at the center of a hurricane with wind speed of 300 km/h at the center.
For question 1 and 2, using bernoulli's equation, and setting y1=y2=0, we have:
P1 + 1/2*d*v1^2 = P2 + 1/2*d*v2^2 where d = density of air = 1.29 kg/m^3
For question 1, if we set P2 = 0 and v2 = 0, and v1 = 30 m/s, I get the right answer. I solve for P1 and then for the force, I just say F = P1 * A where A = 240m^2.
But for question 2, if I do the same thing, with P2 = 0 and v2 = 0 and v1 = 300 km/h = 83 m/s, I do not the right answer. But, if I set P2 = 1 atm, I get the right answer.
Can someone explain how to solve these two questions?
It's important to have both/all the pressures be in absolute pressure. Sometime pressure is given as gage (or gauge) pressure, which is relative to 1 atm. For absolute pressure, the reference is 0, or pure vacuum.
Also, once can consider differential pressure, e.g., Pi - Po, across a pipe (or tube) wall, or Po - Pi, depending on the type of problem. One might calculate the tension in a pipe/tube wall, or collapse potential. Sign convention is important with respect to calculated stresses.
It's a bit like a ground reference in electrical circuit potentials.
  • · Replies 16 ·
