Calculating Air Temp Increase from Atmospheric to 3 Bar Pressure
The discussion centers on calculating the increase in temperature of air when it is pressurized from atmospheric pressure to 3 bar using a piston-type air pump. The scope includes theoretical considerations related to thermodynamic processes.
  • Technical explanation, Debate/contested
  • One participant inquires about the calculation method for temperature increase during pressurization.
  • Another participant suggests consulting Wikipedia on "Adiabatic process," mentioning relevant expressions involving pressures, temperatures, and the specific heat ratio (gamma) for air.
  • It is noted that the outcome depends on the nature of the process, whether it is isentropic or polytropic, with a formula provided for isentropic processes.
  • A correction is made regarding the formula, emphasizing the correct representation of gamma in the context of temperature calculations.
Participants express differing views on the nature of the process (isentropic vs. polytropic) and its implications for the temperature calculation, indicating that the discussion remains unresolved.
There are limitations regarding the assumptions made about the process type and the dependence on the definitions of the variables involved, which are not fully clarified.
Sakthi1267
How to calculate the raise in temperature of air when it's pressurized by a piston type air pump from atmospheric pressure to 3 bar(gauge pressure) ?
one can read wikipedia on "Adiabatic process", there are expressions involving both pressures, temperatures and gamma = 1.4 for air
it depends upon the process.whether its isentropic or polytropic.If its isentropic then the formula wouls be
T2\T1=(p2/p1)^(gamma-1\gamaa0.gamma=1.4
sorry its gamma -1\gamma.t1 may be normal temp
  • · Replies 45 ·
  • · Replies 33 ·
  • · Replies 20 ·
