Algebra help with Lorentz Transformation
The discussion revolves around difficulties with algebra related to the Lorentz transformation, specifically transitioning from x' to x. The user seeks a step-by-step guide to resolve an issue where they consistently end up with an extra x' and v during their calculations. They mention rearranging the initial equation and substituting for t but are unsure of the next steps. Other participants emphasize the importance of showing their work to identify where mistakes may be occurring. The user is looking for clarification on the algebraic process to achieve the correct transformation.
Luckier
Hey all, my algebra isn't as great as it used to be and I am having trouble with some of the algebra dealing with Lorentz transformation. Basically, I just need someone to do a quick step by step of how to go from x' to x (see the following).
I started with the top equation in this image (x')
and moved some things around to solve for x
Then I tried plugging in for t to put into terms of t'
This is where I am stuck, somehow I keep ending up with an extra x' and v that I cannot get rid of... By the way, the result is supposed to end up being
So I was hoping for someone to do a quick little algebra step by step so I can figure out where I made my mistake(s). This is my first time posting, I hope all the images work. If needed, here is where I obtained the images... http://galileo.phys.virginia.edu/classes/252/lorentztrans.html
Thanks in advanced for any help!
What did you do after this? Did you use the second equation to substitute in for t in the first equation?
Hey, thanks for the reply. First I just rearranged the very first equation to get
And then I plugged in for t (into the equation above), using this equation for t:
And basically, I can't figure out the algebra. Supposedly, you should end up with
according to http://galileo.phys.virginia.edu/classes/252/lorentztrans.html
And that's it really, I just need someone to write out the steps algebraically for plugging in that t into x=vt+x'√(1-v2/c2) to get
It's against the forum rules to do the problem for you. You need to show us what you did, so we can see where you're going astray. So what did you do next?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
