Algebra - make the assumption?
  • Thread starter Thread starter MathJakob
    Algebra
MathJakob
##\frac{6-2x}{x^2-9}\times\frac{15+5x}{4x}##
##\frac{2(3-x)}{(x-3)(x+3)}\times\frac{5(3+x)}{4x}##
##\frac{3-x}{x-3}\times\frac{5}{2x}##
Now do I make the assumption that ##x\neq3## ?
If I make the assumption that ##x\neq3## then ##-1\times\frac{5}{2x} = -\frac{5}{2x}##
Mathematics news on Phys.org
You started of with
For this to be well-defined, you make the assumption there that ##x\neq -3, 0, 3##. So you make the assumption in the beginning instead of in the end.
micromass said:
You started of with
How can you tell before even starting the question that ##x\neq-3,0,3## ? It only became obvious to me once I got to the last section. Even still my main question was is it the right thing to do to make the assumption? Should I be doing this with all questions and just include where ##x\neq-3,0,3## along with my answer?
Would an examiner be looking for these types of checks?
You want to avoid dividing by ##0##. So the denominator shouldn't be ##0##. I see two denominators, namely ##x^2 - 9## and ##4x##. Neither should be ##0##. Now, solving things, we get that ##x^2 - 9 = 0## if and only if ##x=-3,3## and ##4x = 0## if and only if ##x=0##. So you don't want ##x=-3,0,3##.
Yes, you should make the assumption. But you should make the assumption in the beginning.
Yes.
They should be looking out for these things.
Likes 1 person
Ok thank you
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
