dvscrobe
- 51
- 11
How do you determine the phase shift of an aliased signal?
The discussion focuses on determining the phase shift of an aliased signal, particularly in the context of sampling theory. It emphasizes that phase relationships can only be accurately discussed when signals share the same frequency. The conversation highlights the importance of the Nyquist theorem, stating that a sampling frequency of at least 3000 Hz is required to accurately reconstruct a signal with a maximum frequency of 1500 Hz. Additionally, it explains that the alias frequency can be calculated using the formula Falias = Fs – f, where Fs is the sampling frequency.
PREREQUISITESStudents preparing for the FE Exam, signal processing engineers, and anyone involved in digital communications or audio engineering will benefit from this discussion.
My apologies, I think was referring to the perceived signal. Would there be a phase shift between that and the signal being sample?Baluncore said:You want to measure the phase relative to what ?
An alias appears at the wrong frequency because the frequency has been reflected or folded one or more times from the ends of the 2π wide spectrum.
dvscrobe said:My apologies, I think was referring to the perceived signal. Would there be a phase shift between that and the signal being sample?
I guess I am a little confused here. I am studying for my FE Exam. I am stuck on problem 8.1c and d. I get that the highest frequency being sample is 1500 and the sampling frequency of 2000 is not high enough. It needs to be at least 3000. That I am good with. It's the recovered signal that I am stuck. I think they are asking for the reconstructed signal. It wouldn't have a frequency of 1500 but something much lower at 500. I am lost on the phase shift here.sophiecentaur said:You can only really talk about phase between signals if they are the same frequency. If they are different frequencies then the phase will be changing by (2π times the frequency difference), every second.
Tell us the context of your question and we may find out what and how the actual misconception is arising.
If you alter the phase of the sampled signal then the phase of the reconstructed signal will be affected but relative to what?dvscrobe said:I am lost on the phase shift here.
Starting with phase is certainly the hard way round, imo but, as frequency is the time derivative of phase, it should be possible to go at it either way. The 'trig identities' allow you to find the passage of a phase change θ on the way through. I guess the examiners had their own priorities about this.Baluncore said:The answer to 9.1D does not require consideration of phase, it only requires computation of the alias frequency.
Either way, except that there is a constant of integration to be found.sophiecentaur said:Starting with phase is certainly the hard way round, imo but, as frequency is the time derivative of phase, it should be possible to go at it either way.
Phase conjugate? Negative phase? Wow, okay, that does seem to make sense. The problem wasn’t asking me for a specific angle but whether it was positive or negative as compared to the frequency being sampled. Thanks!Baluncore said:The answer to 9.1D does not require consideration of phase, it only requires computation of the alias frequency. But frequency and the phase can be solved most easily by considering that when you sample a signal you are performing a frequency mixing operation, and you can treat the sampling frequency, Fs, as a harmonic-rich local oscillator.
Frequencies f, in the range 0 to Fs/2 are analysed normally as being at 0 to Fs/2. Frequencies in the range Fs/2 to Fs map to an alias in the reversed range Fs/2 to 0. The alias frequency will be Falias = Fs – f, but the sampled signal will be the phase conjugate, which is effectively backwards in time, so can be seen as having negative phase.
The general equation of a harmonic mixer is; Falias = f – n·Fs;
https://en.wikipedia.org/wiki/Harmonic_mixer
https://en.wikipedia.org/wiki/Undersampling
Or just ignored on many occasions.Baluncore said:Either way, except that there is a constant of integration to be found.
