Can an alternate Muonic Helium model be created with one electron and one muon?
  • Thread starter Thread starter jfy4
    Helium
jfy4
Hi,
I would like to model an alternate to Muonic helium, and I need some help. I got this idea from a professor of mine who mentioned it off hand in a lecture. The idea is the following:
Model a helium nucleus with one electron, and one muon.
This would have two fermions "orbiting" however, the particles are distinguishable and so none of the indistinguishably ideas around the electrons in the atom would apply.
One of my first question is this: The muon is considerably more massive than the electron, the ratio of mass between the nucleus and the muon is 1 m_\mu is 0.0283466 times smaller than 1 m_\alpha. So the muon is \approx 3\% the mass of a helium nucleus. Is this small enough to still approximate a stationary center?
If you are referring to gravity as moving the nucleus then you may assume so. Seeing as the relative distance from the nucleus to the the first orbit is incredibly large, gravity would not have an effect on the nucleus.
Well, your professor probably mentioned it due to the fact there was an http://www.sciencemag.org/content/331/6016/448" .
The ground-state is a singlet, so as far as that's concerned, the two particles are distinguishable anyway, since they've got opposite spin.
As for your question: Yes, the Born-Oppenheimer approximation was found to hold up well under the circumstances.
Zush: What on Earth are you on about? Electrons (or muons) don't have 'orbits', nor stay at any well-defined distance from the nucleus. And the gravitational attraction is over 50 orders of magnitude smaller than the electromagnetic force between the particles.
Wow, thanks for this article. Do you think anyone will mind If I try and do this without reading the article first, as an exercise. See if I can do physics without seeing it first.
I decided to assume that the nucleus was stationary. The Schrodinger equation is then
-\frac{\hbar^2}{2m_\mu}\nabla^{2}_{\mu}\Psi(\vec{r}_\mu, \vec{r}_e) -\frac{\hbar^2}{2m_e}\nabla^{2}_{e}\Psi(\vec{r}_\mu, \vec{r}_e)+ke^2\left(-\frac{Z}{r_e}-\frac{Z}{r_\mu}+\frac{1}{r_{e\mu}}\right)\Psi(\vec{r}_\mu, \vec{r}_e)=\hat{E}\Psi(\vec{r}_\mu, \vec{r}_e).
I'm going to take
H&#039;=\frac{ke^2}{r_e\mu}[/itex]<br /> <br /> as the perturbation and then divide the wave function into two parts<br /> <br /> \Psi(\vec{r}_\mu, \vec{r}_e)=\psi(\vec{r}_\mu)\phi(\vec{r}_e).[/itex]&lt;br /&gt; &lt;br /&gt; and write \hat{E}=\hat{E}_\mu+\hat{E}_e.&lt;br /&gt; &lt;br /&gt; I&amp;#039;m then going to treat this as two, two-body problems with the Helium nucleus and the Muon, and the Helium nucleus and the electron. Both of these problems have the normal hydrogenic wave function solution&lt;br /&gt; &lt;br /&gt; \Phi_{nlm}(r,\theta,\phi)=-\left[\frac{4(n-l-1)!}{(na_0)^3n\left[(n+l)!\right]^3}\right]^{1/2}\rho^l L_{n+l}^{2l+1}(\rho)e^{-\rho/2}Y_{l}^{m}(\theta,\phi)&lt;br /&gt; &lt;br /&gt; where \rho=2r/na_0 and a_0=\hbar^2/\bar{\mu} e^2. Here \bar{\mu} is the reduced mass of either one of the systems (I&amp;#039;m running out of symbols...). L_{n+l}^{2l+1}(\rho) and Y_{l}^{m}(\theta,\phi) are the Leguerre polynomials and the Spherical Harmonics respectively. For this Hydrogenic solution, n,l,m,r,\theta,\phi are all dependent on the system, and so are not the same in general for both systems. Then the total unperturbed wave function for the system is&lt;br /&gt; &lt;br /&gt; \Psi_{\{n \}}(\vec{r}_\mu , \vec{r}_e)=\psi_{\{n_\mu \} }(\vec{r}_\mu)\phi_{\{n_e \}}(\vec{r}_e).&lt;br /&gt; &lt;br /&gt; Here \{n\} is the set of quantum numbers. Then the ground state of this atom is&lt;br /&gt; &lt;br /&gt; \Psi_{100,100}(\vec{r}_\mu, \vec{r}_e)=\frac{1}{\pi}\left(a_{0_\mu}a_{0_e}\right)^{-1/2}e^{-(r_\mu/a_{0_\mu}+r_e/a_{0_e})}.&lt;br /&gt; &lt;br /&gt; Tomorrow, if everything is fine, I will calculate the first correction to energy and other interesting items. Stay tuned.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
