How Many Moles of Copper Are Produced from 4.8 Moles of Aluminum?
  • Thread starter Thread starter Jimbo57
    Aluminum
In the chemical reaction 3CuCl2(aq) + 2Al(s) --> 2AlCl3(aq) + 3Cu(s), 4.8 moles of aluminum will produce a maximum of 3 moles of copper, as the copper yield is limited by the stoichiometry of the reaction. For producing 12.7 grams of copper, approximately 3.6 grams of aluminum are required. The calculations involve converting grams of copper to moles and then using the stoichiometric ratios to find the necessary aluminum. The discussion highlights the importance of understanding the coefficients in a balanced chemical equation, which dictate the ratios of reactants and products. Overall, the key takeaway is that the amount of copper produced is constrained by the reaction's stoichiometry, regardless of the excess aluminum.
Jimbo57
a) If 4.8 mol of Al react in the process, how many moles of Cu are produced?
b) How many grams of Al will be necessary in order to produce 12.7g of Copper?
a) This one is tricky in that I originally did 4.8/2Al X 3Cu = 7.2mol of Cu but then I realized that there is still only 3mol of Cu present as a reactant regardless of the concentration of Al. So I would assume the 3Cu would stay the same.
b) 12.7/63.5 gr Cu= 0.2mol Cu
0.2mol Cu x 2Al/3Cu = 0.13mol Al
0.13mol Al x 27gr/mol = 3.6gr Al for 12.7gr of Cu
How does that look?
Where is it stated?
How does that look?
Much better.
Hey Borek,
I was assuming that 3CuCl2(aq) meant there was 3 mol copper present, but I'm guessing that isn't the case (I'm very new to this). So my original assumption is the better one?
Yes. Coefficients don't say anything about the amounts - only about their ratios during reaction.
Thanks for the help :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
