Alvarez's x-raying of the Gizeh pyramid
  • Thread starter Thread starter DrDu
    Pyramid
DrDu
I had a fascinating read about Alvarez "x-raying" the great pyramid in Gizeh in the 1960ies using cosmic muons:
www2.lns.mit.edu/fisherp/AlvarezPyramids.pdf
The technique has been refined and used even to make tomographies of a volcano in Japan.
What I wonder: To obtain the direction of the muons, one needs two ionization events. Isn't the probability for two ionizations in the spark chamber very low for muons which are so energetic that they can run unscattered trough the whole pyramid or a volcano?
They are not unscattered, but their scattering angle is very small over the whole length.
Ok, I just read that the muons have on the mean 4 GeV of energy when they reach the surface and that they loose about 2MeV per g cm-2. So they can travel about 20 m in e. g. water. On the other hand, this makes still about 1 keV loss per cm of air. Given that ionization requires some 10 eV, there should be about one ionization event every 0.1 cm.
Every 10µm?
For pyramids or mountains, you need the high-energetic muons.
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
