Among Simple harmonic oscillation, simple pendulum and physical pendulum
In summary: Thanks alot, also does the period have any m dependence in the simple pendulum? No right since its a masless rod. Also under what condition does the theoretical formula hold for the simple pendulum, would it be only for larger angles and amplitudes?Also there is a mass dependence in the physical pendulum right and does the theoretical formula hold for small angular displacements?Yes, the period of the physical pendulum does involve the mass distribution.
parwana
182
What is the similarity between Simple Harmonic Oscillation(SHO), simple pendulum and a physical pendulum? I never understood it. Like what's the physical significance of SHO, or the energy and momentum change in oscillating motion?
I don't understand your question. Simple Harmonic Motion is just that, simple-harmonic-motion.
In this idealization, no energy is lost to the system; therefore, it is converted from all potential energy at the top of the arc to all kinetic energy at the bottom of the arc. This is known as Rayleigh's energy method.
Simple harmonic oscillation is a system described by
[tex]\ddot{x}=-\omega^2 x[/tex]
where [itex]\omega[/itex] is some constant, and [itex]x[/itex] is usually a displacement variable. We can solve this equation in general, very easily. An example of this is the spring-mass oscillator.
Simple pendulum
Another example is the simple pendulum, where [itex]x=\theta[/itex] the angular displacement, and [itex]\omega^2 = g/l[/itex].
Physical pendulum
As for the physical pendulum, if we are careful, we find that it is not a true simple harmonic oscillator; instead it obeys the following equation:
[tex]\ddot{x}=-\omega^2 \sin(x).[/tex]
In the case of small displacements:
[tex]\lim_{x\rightarrow 0}\sin(x)=x[/tex]
and we find that in this case, the physical pendulum is well approximated by the simple pendulum. This is useful since the SHO equation is solved much more easily than the equation for the physical pendulum.
Not really, masudr.
The only difference between the "simple pendulum" and the "physical pendulum" is the mass distribution; the simple pendulum consists of a massless rod ending in a bob with mass.
An example of a "physical pendulum" would be a rod of uniform density.
Note that this difference in mass distribution makes for different moments of inertiae, and therefore different periods of the pendulae.
Simple harmonic motion is not present in either case, but for small angular displacements, that approximation is justified.
thanks alot, also does the period have any m dependence in the simple pendulum? No right since its a masless rod. Also under what condition does the theoretical formula hold for the simple pendulum, would it be only for larger angles and amplitudes?
Isn't this merely a case of definition? I'll accept, however, that you know that in the literature the common usage is as you described.
can someone answer this please
hmm
pawana,
do you go to stonybrook? these questions sound reeeally familiar..
Of course it is just a matter of definition. I furnished the one I'm used to.
Near any stable equilibrium, the 2nd degree Taylor expansion of the potential is the simple harmonic oscillator, so any oscillation near a stable equilbrium can be approximated by simple harmonic motion.
And also, the differential equation is linear and very easily solved.
There is no m dependence in the motion of a simple pendulum because the restoring force is due to gravity and is proportional to the mass. This is similar to the situation for projectile motion. Since F = ma, when you have a force that is proportional to mass, the mass divides out.
One can (and people have) engaged in debate over whether the gravitational mass in GMm/r² and the inertial mass in F = ma are the same thing, but for all the situations you are likely to encounter, they can be safely treated as being the same.
The mass dependence neatly drops out for the simple pendulum if you treat the mass as a point object that has no rotation. If the mass is distributed, then the distribution of the mass comes into play. Even a small spherical bob would have some rotation, so you could treat it as a physical pendulum and find a slight difference in the calculated period compared to the simple pendulum. However, if you look at the equation for the period of the physical pendulum it involves the ratio I/m and I is always proportional to the mass of an object. So the mass divides out for the physical pendulum as well, but the factors in I that depend on the shape of the object do not drop out
http://hyperphysics.phy-astr.gsu.edu/hbase/pendp.html
1. What is the difference between simple harmonic oscillation, simple pendulum and physical pendulum?
Simple harmonic oscillation refers to the motion of an object back and forth along a straight line, where the restoring force is directly proportional to the displacement from the equilibrium position. A simple pendulum, on the other hand, refers to the motion of an object swinging back and forth along a circular arc, where the restoring force is provided by gravity. A physical pendulum is a more complex system where the object oscillates around a pivot point that is not at its center of mass, resulting in a combination of rotational and translational motion.
2. How do the periods of these systems compare?
The period of a simple harmonic oscillator depends only on the system's mass and the strength of the restoring force, while the period of a simple pendulum depends on its length and the acceleration due to gravity. In a physical pendulum, the period depends on both the length and the distribution of mass around the pivot point. Generally, the period of a simple harmonic oscillator is shorter than that of a physical pendulum, and the period of a simple pendulum is shorter than that of a physical pendulum with the same length.
3. Which system experiences the most damping?
Damping refers to the gradual decrease in amplitude over time due to the dissipation of energy. In a simple harmonic oscillator, damping can be controlled by adjusting the strength of the damping force, so it can be either underdamped, critically damped, or overdamped. In a simple pendulum, air resistance and friction at the pivot point can cause damping, but it can be minimized by using a low-friction pivot and reducing the area of the object. A physical pendulum typically experiences the most damping due to the combination of rotational and translational motion, resulting in multiple sources of energy dissipation.
4. Can these systems be used to measure time?
Yes, the period of a simple pendulum is independent of its mass and only depends on its length and the acceleration due to gravity, making it a reliable timekeeping device. However, the period of a physical pendulum can vary based on the distribution of mass and the amplitude of oscillation, making it less accurate for measuring time. Simple harmonic oscillators can also be used to measure time, but they require a precise method of determining the amplitude of oscillation.
5. Are there any real-world applications of these systems?
Simple harmonic oscillators have many real-world applications, including clocks, springs, and musical instruments. Simple pendulums are used in pendulum clocks, seismometers, and even swings at a playground. Physical pendulums can be found in objects such as metronomes, measuring devices, and toys. The principles of these systems are also important in understanding more complex systems, such as the motion of molecules or the behavior of atoms in a solid.
  • Classical Physics
