Amount of 6M H2SO4 to lower pH of pool from 7.0 to 4.0
  • Thread starter Thread starter Terp
    Ph
To lower the pH of a swimming pool from 7.0 to 4.0, approximately 2.2 liters of 6M H2SO4 is needed, considering the diprotic nature of sulfuric acid. The pool's volume is calculated to be 265,643 liters, and the required concentration of hydrogen ions at pH 4 is 0.0001 M. The calculation involves balancing the moles of hydrogen ions from the acid with those in the pool after addition. The discussion highlights the importance of accounting for both dissociation stages of H2SO4. This approach ensures accurate pH adjustment for the pool's plaster curing process.
Terp
[SOLVED] Amount of 6M H2SO4 to lower pH of pool from 7.0 to 4.0
A new swimming pool is filled with fresh, clean water with a pH of 7.0. The width is 25 ft, the length is 60 ft, and the depth linearly ranges from 3.5 to 9 ft. How much 6 M H2SO4 must be added to reduce the water pH to 4.0 so that the plaster liner in the pool can be cured?
kw = ka*kb, pKa = -log(Ka) and for pOH and pH, any the usual concentration formulas.
I'm honestly not entirely sure how to tackle this. I first started off by finding things I may need. I found the capacity of the pool to be 265,643 liters. The molecular weight of H2SO4 is 98.065 g/mol. Ka of H2SO4 is 10^3.
If you guys could bump me in the right direction it'd be appreciated. Thanks!
Nevermind, got it figured out :).
Well since you figured it out, maybe you could tell me. I have not got to that section of the book yet in school, so I just read ahead. The way I saw it being done was this: Since you want a pH of 4, I computed Molar by using wanted pH 10^-4 = .0001 Molar. Then I took the equation M1V1=M2V2 solved for V1 so I got (.0001M * 265643L)/6M =4.43L
I have a feeling that is not correct because H2SO4 is diprotic. What answer did you come up with?
Well, if you want a pH of 4 then you will need a [H+] = 1 x 10^-4 M ([H+] = antilog (-pH)
I assumed that the moles of H+ ion that will be present in the swimming pool after adding the acid will be the same as the number of moles of H+ provided by the acid. So I came up with an equation:
moles of H+ from acid = moles of H+ in swimming pool after the acid is added
H2SO4 is for all practical purposes completely ionized into the H+ ions and SO4-2 ions according to the equation:
H2SO4 --> 2 H+ + SO4-2
so the moles of H+ for acid = volume of acid added x molarity of the acid x 2 H+/acid molecule
= x L (6mol/L)(2 H+/molecule)
the moles of H+ in the pool = molarity of H+ in the pool x volume of the pool
= (1 x 10^-4 M)( 2.66 x 105) L
Plugging the values in for H+ yields:
x L(6mol/L)(2 H+/molecule) = (1x 10^-4M)(265643L)
I just solved for X and got 2.2L. I'm not 100% this is correct but it makes sense to me. It's basically a molarity balance thing. Moles of [H+] for the ace = moles of [H+] after it's in the water. I think what you did is correct for one stage of the dissociation, but not both, since the only difference is that I multiplied the 6M by two from the chemical equation above.
Good luck and godspeed. Engineering majors like me need it! haha
Yeah that makes sense. I think I messed up by not accounting for the H2, hence my number was 2x. Thanks for clarification. Funny you ask for help and end up giving it :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
